A trick to replacing campy pads?
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
Earlier Chorus dual pivots (BR 14RE clone) with metal holders...is there a trick to removing the pads and installing the koolstop salmon C89??
Quoted: 1303 Post(s)
Liked 1,911 Times
Try a pair of channel lock pliers. Always worked for me. Smiles, MH
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
I usually use wide jaw pliers with one jaw on the lip of the holder at the open end and the other jaw on the other end of the pad. Squeeze and viola! To install, lots of times I’ll put a drop of lube and then either do the reverse with the pliers or press the pad in with a bench vise.
Try to tap them out backwards in the holders on the bike. If they don't move then...
Most common old school method was:
Remove shoes from bike,
Squeeze the rubber part only in a vise
Tap off the holders with a big dull punch and a hammer, or something like that.
Reverse procedure to tap in the new rubber, or just squeeze them in.
Reinstall pads and holders and readjust as necessary.
Use a hack saw to cut a groove along the centerline of the old pad.
Squeeze with a pliers and remove pads.
Remove the rust you are likely to find which is causing the pads to be so hard to remove.
Quoted: 3464 Post(s)
Liked 2,829 Times
A year ago I started finding OLD pads pretty challenging to remove- I assumed beyond the flex date.
the hack saw slit or dremel slit might just do the trick.
I have a section of angle iron with two 6mm plus holes- remove holders from brake affix to angle and tap them out with a drift.
copper jaws in vise and wind the fresh in.
at some point Campagnolo went with a floating pad holder bolt- that required an upset to clear the fastener head. Water soluble Goose grease helps press them in- rinse off.
Likes For repechage:
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
Take a pair of pliers and rip the old ones out. If they're old, they might tear and you just keep working until all the pieces are out. I've run Campy my whole life and I've never had old brake pads push out easily.
For the new ones, apply a liberal amount of dish soap and slide in. The torque/friction of the braking surface of the wheel on the new pads will fully seat them if needed.
Bikes: Masi, Olmo, Miele, Masi, Masi
Quoted: 40 Post(s)
Liked 34 Times
Edumacator
Liked 3,128 Times
Awesome suggestions all! I appreciate it. I got one out the wrong way by mistake, but it didn't deform the shoe. The pad seems to not wish to seat without popping up a little and so I backed it out and posted this.
Bench vise for installing with a bit of Dawn. Great ideas.
Removal...working on that one!
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
If you haven’t pinched a finger or drawn blood with a screwdriver you’re doing it wrong
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
