Light Bicycle Wheels
#576
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
Depends a bit on location (winds) and weight and speed.
For the general rider 35mm is likely better. If you pump higher speeds, a deeper profile is likely better.
Wheel mass matters more for the general rider as the general rider is going under 20mph.
In all and every case a tubular will provide the better ride. It may not be worth the learning curve dealing with them. But in no case will a non tubular out perform a tubular except maybe a constant speed super smooth surface.
If you are a general rider - 25mm-35mm with an alloy clincher 25-28mm will give the best ride/$.
Carbon if you want to give up a bit of quality and performance to get the very best.
Tubular - carbon.
#577
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
I actually was referring specifically to LB wheels in 25x35 and 25x45 and have updated last my post to reflect this. My question is, what's the difference in ride quality between the two sizes? You commented that alloy wheels give the best ride/$. Can you explain?
The OP was @robbyville. I started along your topic and was corrected that this was about a brand.
Tubular - carbon.
Tubular - carbon.
#578
Quoted: 20810 Post(s)
Liked 9,456 Times
I don't follow why it's hard to understand. It's a manufacturer-direct brand and there's not a lot of spilled ink to be found on them, so this is a place for buyers to share their experiences and provide their thoughts for the benefit of others that are curious about the brand.
Likes For WhyFi:
#579
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
#580
Liked 371 Times
As alloy rims are extruded the thickness of the metal can be well controlled and makes a nice pronounced hook can be made to hold the tire well. Carbon is not extruded. The degree carbon takes bends or has differeent material thickness is based on the mold and hand layup. It is not unusual to have carbon rims with alloy brake tracks.
Then the brake track. This is more of an issue using rim brakes, but grit and rough pads are squeezing the outside of the carbon tracks while the air is pushing the walls out. Same is true of course for alloy, but this fatigue can cause side/brake tracks to splinter/blow out over time. So typically the carbon wall are thicker (or alloy) than the alloy ones to account for this. The clincher distance from inside the rim to the outside is further for carbon. The tire may be leaning on the edge of the rim more. Could you feel this? Don't know. It just doesn't mentally seem as right.
The net is in low profile clinchers - 25mm or so alloy rims are often lighter than the carbon ones, due to the brake track issues. Tubulars, not having the brake tracks are lighter in carbon.
Ride quality is based on the tire case material, tread, and width which affects the the cross section area, then the PSI. The width thing as another poster mentioned is having the same area of air in the cross section. Adjusting the PSI accordingly. Leaving the actual case material and where the air is is a mistake IMO. We also generally leave the PSI part out of many discussions. I think it is implied, wider gets lower PSI, but most the rolling resistance tests I have seen you have to be careful and see if the PSI was the same, or adjusted for cross sectional area. Also having air between rigid brake tracks vs floating on top of the rim can be felt.
Having air between rigid brake tracks vs floating on top of the rim can be felt.
#581
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Clinchers need a hooked brake track. Two things here - the brake track and the hook.
Vittoria - ENVE Compatiblity
#582
Liked 371 Times
Do think the characteristics you mention have something to do with the Vittoria/Enve 'spat'? OT: was there any further followup on this?
Some tires have a more pronounced bead that will slip in better under a smoother carbon hook. I use Veloflex Master 25s on my Mercury M5 carbon clinchers. They hook in better.
I do not know about these Light Bicycle Wheels but often wheel manufactures will swap out suppliers for one component to the next. The same Asian made rims will find their way to multiple brands, and the same model wheel may have a different rim from one year to the next.
#583
Quoted: 562 Post(s)
Liked 64 Times
#584
Liked 371 Times
I'm bigger and like 50mm. I ride mostly tubulars but have 50mm carbon clinchers too. My 25 clinchers are alloy. I own 25mm carbon, and I think they are inferior to the alloy.
#585
Quoted: 562 Post(s)
Liked 64 Times
For low profile - yes. The Ardennes are robust. I have the cheap Shimano, Mercury, DuraAce, and Ultegra in alloy. For hi profile you pretty much need a carbon rim. Maybe with an alloy brake track (Zipp, HED). Low profile alloy will be lighter and fit tires better.
#587
Quoted: 4717 Post(s)
Liked 1,882 Times
How is it possible that there’s a large thread, and he has nothing to add?
I have nothing to add, so I'll change the topic.
#588
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
For the sake of posterity, here is the progress of my order so far:
Monday 6/17: two rims ordered - RRU35C02 3k matte with grooved graphene brake track
Wednesday 6/19 (two days): Paypal charge appeared on bank account
Friday 6/21 (five days): Informed that rims were not in stock in North America and would be manufactured and shipped from China. Order status changed from Pending to step 1 of 10 "Material Prepare."
Wednesday 6/26 (nine days): Order status changed from step 1 of 10 "Material Prepare" to step 4 of 10 "CNC Machining."
Hubs still have to come from Poland so I'm not in a rush. Just posting for additional data points.
We now return you to our regularly scheduled argument. As you were, fellas. Carry on.
-Tim-
-Tim-
#589
Liked 1,882 Times
-Tim-
-Tim-
#592
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
In other words, I'm saying you're probably overthinking it a little. Go 45mm.
#593
Quoted: 18883 Post(s)
Liked 10,646 Times
I've had mine for 2 weeks and have about 550 miles on them. Right now, I'm loving them. Haven't ridden them in the rain yet, but I quickly switched out the LB brake pads for Swisstop Black Prince and the dry braking is just fine. I've hit some potholes hard without a problem. It's my first pair of carbon wheels, and compared to more conventional alloy rims (I was riding HED Ardennes), the differences are very noticeable, especially above 25 mph. I'm not sure how much different the performance may be from your Reynolds.
I have a set of Ardennes, they came with the bike. I have a pair of $$$$$ carbon hoops and feel the same way about them that you described. Even at lower speeds they just feel like less work.
I would like to have another set of hoops, and do far everything I've read here is very encouraging.
#594
Liked 10,646 Times
How much do you folks weigh?
#596
Quoted: 1975 Post(s)
Liked 232 Times
I would love to hear more about this, maybe it's hard to describe though.
#597
Quoted: 850 Post(s)
Liked 344 Times
Don’t mind me. Just excited that my wheels are done.
492g and 494g for the (internal nipple drilled) rims. 1592g for the wheelset. Pretty much on the dot.
Likes For smashndash:
