Where is the best place to lighten this bike
Bikes: Scott scale 29er, Gary fisher Rig SS 29er, Fuji Cross pro, Novara Randonee, Scattante TI custom build, Fuji Team
How you get those sub 15 lb bikes, Ill never know... but what is the best/most effective upgrades to lighten my new ride?
https://fujibikes.com/2008/bikes.asp?id=394
I started with the wheels (ksyrium SL), where next?
and do carbon seatposts really make that big of a difference?
Bikes: 02' Fuji Team, 85' Miyata ninety SS, 18' Citizen Rome
check this site:
https://weightweenies.starbike.com/
15LB is currently at the low extreme... It's my believe anything extreme and yer gonna have to compromise on other aspects... goodbye wallet.
Bikes: 2004 Cannondale R600
Bikes: '07 Trek 520, '09 Gary Fisher Triton, '04 Trek 8000, '85 Trek 500, '84 Trek 610, '85 Trek 510, '88 Trek 660, '92 Trek 930, Trek Multitrack 700
Quoted: 19 Post(s)
Si.
That wasn't his question, and why do so many people assume everyone on here needs to lose weight? He could be 120 pounds! How dare anyone want to cut some weight off their bike
Full carbon fork never crossed my mind. thanks guys!
I already know how to drop my own weight, I wanted to know how to drop the bike's weight. Aside from urinating/defecating while riding to continually lose weight, do you recommend I avoid carrying waterbottles, or will the urinating offset this? FYI I already shaved my head to cut back a quarter pound.
6'3" 180
6'3" 180
post-ironic
Bikes: CAAD 12, Lemond Maillot Jaune
Quoted: 75 Post(s)
Get teeth extracted at the dentist (make sure to specify carbon fiber replacements). You know what? I hear that they provide prosthetic limbs made out of carbon fiber you can use. In all honesty, the rider + bike weight needs to be well under 60lbs to have ANY chance of enjoying yourself whilst biking.
Stratiotika ktemata
Inflate your tires with a lighter-than-air gas like Helium. You will save a ton of total weight and think of the rolling resistance benefits.
I'm that guy
Bikes: Cervelo RS, Mountain Cycle San Andreas
Lose the feet. Get cleats that screw directly to your leg bones. You'll save some weight, and notice a lot better acceleration at the same time.
you definatly need water if you want to bike........ a full carbon fork will drop it quite a bit... the alloy on my felt was mad heavy.... why do you want to go through all the extremes to drop the cycling weight... just get your power to weight ratio up by doing squats at the gym
Bike ≠ Car ≠ Ped.
one good leg
nothing wrong with wanting a light bike. IMO, you can shave a lot by going to lighter wheels. Expect to pay though, going to 16-17 is easy, getting to 15, will cost much more. Anyway, a nice pair of brakes can also probably shave a bit.
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
6'3" 180
6'3" 180
Man, just ride your bike...
If you want a weight weenie build, you started wrong. Sorry.
Luggite
Unfortunately it's a lot harder to start with a full bike and go down in weight, than to start with frame and then build to a weight limit. You have to basically look at every single part that you hang on the thing, which on your bike basically means replacing virtually everything. OEM bikes are hung with heavy cheap parts in most cases. Not worth it. I think a better goal might be to shoot for high 16s to mid 17s.
I started with a 3.3lb frame (not light at all) and built up from there. I ended up hanging a few heavier than I wanted parts on it that I already had to save money and ended up at 16. I'll replace them if I can get deals on them, but for now I'm satisfied at 16. Helluva lot lighter than the old 21lb bike.
The seat post and saddle weighs a lot, you can swap to lighter ones. Wheels are probably the next big weight next to the frame and fork.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
slow up hills
Bikes: Giant TCR, Redline CX, Ritchey Breakaway, Spec S-works epic
