Chainring alignment on crankarm
Stooge
Bikes: one of each
I've got a single chainring to install on a single speed bike. The current install is not aligned perfectly, thus there's a "high point" and "low point" while pedaling and it makes for a serious tight spot, only ridable if there is slack chain tension.
My question is, does Park or another company make a tool that helps to help align the chainring on the crankarm? Are there shims which can be used to get the chainring perfectly in the center?
If it matters, it's a Surly ring on old Suntour X-1 crankarms.
God bless you for your answers
Quoted: 1572 Post(s)
Liked 643 Times
A trick is to loosen the chain ring bolts so they are just finger tight. Then install the chain and spin the crank several times. The idea is to get the chainring to move away from the tight points. After you get the crank spinning smoothly, snug up the chainring bolts and you're done.
Stooge
Bikes: one of each
Sorry it's been a while since I replied...this didn't work. The motion of the chainring moving kept pulling the chainring out of alignment. So I removed the chain and started again to try and get the chainring perfectly centered. This worked ok, it's better, but not perfect. What kind of shim could I use to get this thing on perfect-like? I'm riding my other bikes for the moment, and it's driving me crazy I can't ride this one as it's my favorite.
Really Old Senior Member
I think I'd repeat the first "technique", but with the bolts just a bit snugger.
When the chain is at maximum tension, tap the very front of the ring toward the rear with a rubber mallet.
Repeat, using lighter blows.
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 30 Post(s)
Liked 82 Times
i know this can be tough. i started doing conversions a couple years ago and have since done about seven for myself and family members. there are some chainrings and cranks that are less round than others and although the sheldon brown method of centering the chainring on the spider will help a bit - it won't solve significant runout. its hard to tell ahead of time which cranks will have less runout. in my experience the shimano 105s and 600s were less round than the few sugino crank/chainrings i've worked with. i also hate to say it but generally the nicer the cranks/CRs the less runout you'll experience. in the end i realized spending a little more money to save myself the hours of hassle is worth it. plus i've thrown a few chains that were too loose too avoid binding - a big downside. hope that helps.
Stooge
Bikes: one of each
Once again, Sheldon Brown thought this out long before any of us had the problem
Thanks to everyone who posted, I've got options now
