126 OLN hubs
126 OLN hubs
Hello,
Whats the current options these days when it comes to the 126 hubs. Should I just go with used maxi cars? The freewheel situation seems to bit restricted with the french threaded hubs. I was planing to run a compact douple at front so it would nice to get at least bit wider casette to the back than the normal road casettes.
I have a campy c-record hub already waiting at my spare bin but I'd rather have something with higher flanges to look more balanced with a dynamo hub in the front. Or maybe I should just use the campy? I noticed that J. P. Weigle used a low flange hub at the rear for Concours de Machines.
All the best,
Toni
All the best,
Toni
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
For your project, it's hard to go wrong with Maxi-Cars.
The CdM bike used a Bitex hub in the rear for lightness and one of the goals for that project was to use modern, current-production parts.
My 126mm bikes get 7-speed Shimano freehubs since I like them so much.
Hello,
All the best,
Toni
All the best,
Toni
Quoted: 786 Post(s)
Liked 517 Times
Campy high flange Record hubs are still relatively affordable, and, when in good nick, will perform great. Just find an English threaded one, and you'll have lots of freewheel options.
Quoted: 603 Post(s)
Liked 1,062 Times
You could always check out eBay, I’ve found many NOS 126mm hubs from Campy, Ofmega, Suntour and Shimano, just to mention a few, listed there. Everyone I bought came in the original box, built up beautifully, and look properly correct on a CV bike. Awful hard to beat the quality of those vintage hubs, when comparing them to new ones
Tim
Tim
Quoted: 1136 Post(s)
Liked 650 Times
Are you looking for new hubs? I recently purchased a set of Velo Orange Grand Cru hubs (100mm/126mm) and I am in the process of evaluating them. I built them with DT Swiss double butted spokes and 36 hole Sun Cr18 630 rims and Pasela 27x1 1/8 tires. I couldn't find much real-world info on these hubs so I decided to test them out myself. I initially envisioned a torture test of these hubs by subjecting them to all-weather commuting and little maintenance but I must (somewhat sheepishly) that these hubs have spent more time in the garage than on the road so I can't really comment on their durability. They do appear to be good quality and they are attractive high flange hubs that look the part.
I have a VO Grand Cru rear hub from about 3 years ago that developed a problem with the freehub within a year and a half of use. A couple of the pawls broke and the freehub would lose engagement periodically when being driven. I never ended up trying to warranty it with VO, so I'm not sure if this was a widespread issue or a fluke.
Quoted: 796 Post(s)
Liked 522 Times
Likes For TenGrainBread:
aged to perfection
Quoted: 829 Post(s)
Liked 1,241 Times
I did not (personally) have good luck with MaxiCar hubs and the French freewheel threading would put me off them for sure - except maybe on a display bike. They do have some interesting features and the "keyhole" spoke hole is a neat idea. There are a few MaxiCars out there with English threading but I am not sure how they are marked.
In 126mm OLD there are many nice choices for hubs, the Campy for sure, and you can set up an axle with exactly the right spacer configuration for minimum dish with your freewheel.
The Phil Wood hub is another great choice that is very strong and will last essentially forever.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
I'm not sure why anyone would pay $160 for a VO rear hub when good quality vintage Campy hubs can be head for far, far less. The VO is an aesthetic knock-off of vintage hubs that looks good from 20 feet away but up close is pretty chintzy (aesthetically).
Are the grand bois hubs essentially same as VO?
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Also useful to remember that any 640X, 6500, 6600, 7700, 5500,5600 or 5700 hub can be made into a 126 7 speed hub with the correct HG/UG freehub body- they all interchange- and the correct spacers. Axle can be trimmed. It's not an expensive conversion if you really like 7 speed stuff.
Likes For rccardr:
Quoted: 378 Post(s)
Liked 1,409 Times
There's actually a 126 8/9/10 modern hub being produced. It was covered on BF a while back, maybe a year or a year and a half ago. I was going to get one for my Teledyne Titan.
I have a set of Suzue hubs just sitting here, bronze, laced to Araya rims. I keep them around because I just like them. Like Doc, I'm a tricolor 600 fan, have a set of those here, too.
Quoted: 1361 Post(s)
Liked 423 Times
For freewheel, the USED bargain tall flange 5345 Sansin (also known as Sanshin, Sunshine and made for others: SunTour). Trapezoid cutouts and or drilled. Easily polished or available in anodized.
Same available NEW but in freehub for cassette Sun XCD.
Liked 2,563 Times
Haven't gotten into Dura-Ace stuff, though. Some of it is really cool, but I don't want to sign myself up for the heartbreak of unobtainable replacement parts.
