1951 Phillips 3 speed
hello, i have as the title says a 1951 phillips 3 speed. I have an issue with the chain case there is a piece at the back that goes over the rear hub sprocket, this is held on my one screw but will not tighten and keeps falling out. is there someone out there that can help with this i can post photos if needed
Quoted: 887 Post(s)
Liked 335 Times
Is it a sheet metal screw or a machine screw? If it is a sheet metal screw, one size larger should grab and hold. If it is a machine screw you'll need to re-tap the hole.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
I think a '51 would have had a Whitworth threaded bolt and not a screw but I've never had one that age. Maybe someone in the English three-speeds thread could help you?
it is a machine screw, the threads are fine, there is a piece that goes from the upper chain case to the lower there is a u shaped piece that fits between, the machine screw screws in from the back into this piece, i will post pics
Quoted: 331 Post(s)
Liked 332 Times
Lower section fixed nut
The main casing that your corner piece sits on/in should have a nut fixed permanently that the corner piece bolt engages. If one or both are deformed the bolt hole and the fixed nut may be out of alignment. Check if the fixed nut is still Insitu.
Quoted: 1299 Post(s)
Liked 103 Times
Since the threads look good, I'll guess somebody lost the original screws and tried to replace them with screws that were close, but not exactly the correct thread. British threaded screws are next to impossible to find here in the U.S. Might be more available there, but I think I would just re tap and use similar sized modern stainless screws.
Inflate Hard
Inflate Hard
i would like to add some pics but it will not let me says i need 10 posts to add urls
Last edited by SGB123; 06-04-20 at 03:29 PM. Reason: tried to add pic got this message You are not allowed to post URLs until you have at least 10 posts
this does not help, if this forum will not allow pics then so be it thanks for what ever help you have offered but it was of no help
