does more float equal more relief for pads of feet
Quoted: 5 Post(s)
i read that somewhere in my metatarsal pain research today. so i was thinking of getting some cleats with more float. if so can anyone recommend some of those for a SPD cleat.
i use Time Xpro on one bike but its 3 cleat. Amazing float. So I need a pedal solution for 2 cleat.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Float is for your knees. You need firm soled shoe and proper insoles is my guess. The specialized dealers used to have a deal you stood on to know which of their insoles would fit you. I use only their medium insoles no matter what bike shoes I buy.
Likes For c_m_shooter:
Expired Member
Quoted: 3661 Post(s)
Liked 5,408 Times
Sorry about your foot impediment but.... BF etiquette hint- you've started three separate threads today about your feet. If you keep it all in one thread you are less likely to get repetitive replies. Appropriate caps are appreciated as well, a sign of respect for those you are asking to help you.
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
Specialized Retul makes custom insoles. They're great, but they're spendy. If your toes burn or go numb, shim your cleats.
Quoted: 3352 Post(s)
Liked 1,056 Times
What you may be feel in the way of foot pain may be coming from your shoes being too narrow. Try cycling shoes that actually fit the width of you foot.
Likes For rydabent:
Likes For GAtkins:
Likes For rydabent:
Quoted: 118 Post(s)
Liked 88 Times
Before, they would get numb after about 10 miles or so; now, not at all over any distance I ride.
Glenn
Likes For GAtkins:
Quoted: 2236 Post(s)
Liked 1,314 Times
I like clipless because it allows me to lift my foot more often off the pedal and wiggle my toes while riding. Helps (along with looser laces). I don't think the brand of clipless matters though. It's all about the shoe. The sole should be stiff enough that you could use egg beaters if you wished.
Likes For Happy Feet:
I think we need a better description of the pain. Top, bottom, along the length, at the ball, all metatarsals or 1, 2, 3, or 4, both feet or just one? How far do you usually ride between breaks (if any)? When does the pain show up? How tight is the shoe on the foot/feet that hurt(s)?
Quoted: 164 Post(s)
Liked 44 Times
your shoe might be too flat on the inside causing pressure points , there is no real solution , other than find an insole that can mold to your foot , or a mold-able shoe , but those are usualy carbon and not very durable !
