single speed to 6 speed-- townie cruiser
howdy,
i have this old Taiwan single speed step-thru that i acquired before the pandemic. it rides great...i luv it...already replaced alot of parts...now i want a few more gears.
strangley, this bike has already got a 126mm drop out spacing.
but wheel is a 110mm single speed hub with extra spacers.
it has horizontal (track style) drop outs.
i can find a cheap 6 speed wheel, 6 speed derailer, and shifter.
only problem potentially i see is the lack of braze-on for the cable. w/o brazon, the cable housing will have to be full length and zip tied to the chainstay and down tube.
Can it work without brazon for he cabel housing?
i found all the parts online...
Track drop out derailler 6 sp.
heres what the derailleur would look like on a track-drop-out...
Quoted: 2026 Post(s)
Liked 1,096 Times
Sure, you could use full length housing zip-tied in place. Use good quality lined housing and good die drawn cables to minimize friction. An option is to find some clamp-on cable stops to minimize the housing run.
Quoted: 581 Post(s)
Liked 921 Times
Another thing you didn't mention is brakes. I assume the original setup has a coaster brake, but coaster brakes and derailleurs don't work together. You'll likely have to run full length housing to the rear brake, assuming there is a hole in the brake bridge that will accept a brake.
it has "band brake". it works with derailers. ( see pic in post #3...left side of hub is the brake)
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Clamp-on cable stops are available in a range of sizes.
Quoted: 980 Post(s)
Liked 582 Times
According to Sheldon Brown's site (John Allen's work HERE), the hub needs to be threaded the same as for a freewheel (on the non-drive side) in order to mount the brake.
the ones threaded on both ends, here, now, are flip flops for 2 different sizes of single speed freewheels..
& back in the 70's ~ 80's tandems used a screw on drum brake made in Japan , Arai , with lots of heat sink aluminum fins.
Quoted: 2337 Post(s)
Liked 2,821 Times
not a good idea.....rust etc and frames have cracked with this approach....at least on top tube, I know i had a favorite bike (miyata 1400) die this way
this is my second set. First set's pad broke apart after 6 months. It is draggy when new. Difficult to adjust. Makes wheel remove much more difficult.
i really cannot phanthom why they are being used at all. i rather have any cheap caliper brake instead.
Quoted: 980 Post(s)
Liked 582 Times
Cheers!
Rear "roller" brake with huge, unnecessary heat sink. Weather-proof, though!
