Why so much hate for Gatorskins?
Likes For noodle soup:
#77
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
For all the obvious reasons, I haven't ridden Gatorskins for years, but for a long while I rode Conti 4 Seasons on most of my road bikes (I still do on one of them). I considered them a good compromise between flat protection and performance, and I still think that's true. Then I switched to 5000s, and though I absolutely love their performance, I get quite a few more flats. I think I've had 5 or 6 this spring/summer, and I'm not doing extraordinary mileage (about 800 miles/month). For the improved ride quality, the trade-off is worth it to me, but definitely in my experience the Conti 5000s are more flat-prone than tires with more protection.
I notice that when I get a substantial flat from wear in the center of the rear tandem tire, still nowhere near the cords, that I definitely get more flats. I don't know why. I swap tires and put new on the front. I think it's interesting how quickly we get that flat on the tandem compared with my single. I bet riders who put down a lot of power go through more tires than we duffers do.
Results matter
Results matter
#78
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
IME depends on the type and quantity of road debris. But yes, true. When we ride the tandem in the wet in winter, I do get more flats from flints which accumulate if they sand the roads after freezes or a bit of snow. The flints stick to the wet tires. I used to put on 4 Seasons or similar, but I've quit bothering and just change the flats if we get them. They're rare enough to make that a smaller bother than running special winter tires. We always carry a spare, so changes are really quick. In summer the difference is not noticeable because the stuff I need to miss is more obvious. I've made lots of mistakes, ridden right over glass or auto debris and not flatted or had a piece of embedded glass to pick out later - usually. That's the amazing thing about the Conti rubber on the 4K and 5000. They also don't cut as easily as many tires do.
#79
Quoted: 822 Post(s)
Liked 1,960 Times
I'm not racing anyone so why do I give two cents what tire you choose to go faster? So what I lose some watts. I'm in it for my health and with arthritic hands, the last thing I want to do is be changing tire tubes on the side of the road. Since I switched to 28 mm tires from 25 mm and adjusted the psi to 85 front and 95 rear, I do not find the ride harsh but firm. I got 8,000 miles out of one set and still had miles to use on the front without one flat. Hard to beat that.
Likes For CAT7RDR:
#80
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#81
Liked 3,016 Times
Do whatever floats your boat, but what I don't get is your tone that apparently judges other peoples' choices and priorities.
Likes For MinnMan:
#82
Quoted: 18883 Post(s)
Liked 10,646 Times
#83
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
Well, no, steel drum testing is not actually relevant to real road conditions. That is the lesson we've learned over the last few years, and it's why many, many cyclists have reduced their tire pressures. We now know that if the road surface has any sort of roughness, then a hard, high-pressure tire will cause a loss of speed from bouncing over the irregularities on the road.
The reason people have reduced the tire pressures a little is to compensate for vibration losses - and this is primarily a factor of tire pressure, and not the actual tire itself (although the suppleness of the tire casing plays a role here: the more supple the tire casing, the lower the vibration losses. And guess how supple the Gatorskin sidewalls are? Not very). The effect of vibration losses holds true across tires, and does not invalidate the rolling resistance side of things.
Gatorskins are about 20W slower than a fast tire like the GP5k. And they are most miserably lifeless, dead-feeling tires I have had the misfortune of riding. If you are commuting or riding in crap conditions, sure, it doesnt matter. But for typical sports cycling, there are so many better options where you trade off a little bit of puncture resistance for a much, much more enjoyable ride. To say that "no one can feel the difference" is absurd. Plenty of us can. We didnt just wake up one morning and decided to beat up on this tire for no reason at all.
Likes For guadzilla:
#84
Quoted: 325 Post(s)
Liked 109 Times
I may not have worked for Oscar Mayer, but I know bologna when I see it. If you don't have anything of value to add to the discussion, please stop posting. My point still stands: the person I was responding to is operating on lame assumptions & guesses instead of actual data. Gatorskins are a fine tire that provide soft, supple grip when inflated correctly, and they deliver best-in-class flat protection. That's why they are so popular in the community.
#85
Liked 1,938 Times
#87
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Incorrect. The data from steel drum testing does translate into real world results as well, as per RChung (and if you wanna tell him he is wrong, be my guest. I know enough not to argue with RChung, especially when he has the data and I dont).
#88
Liked 10,646 Times
Likes For Seattle Forrest:
#89
Quoted: 4717 Post(s)
Liked 1,882 Times
#90
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
#91
Quoted: 325 Post(s)
Liked 109 Times
I have only been talking about things I know a great deal about. I have not said anything that is factually incorrect.
Citations needed. You can't just make those claims without showing the actual measurements from the actual tires via a rigorous study.
I never said aero power was linear. What I said, and what still is true (and always will be) is that the power needed to travel at a certain speed has much more to do with air resistance than it does rolling resistance of the tires. The 10W some other poster claimed Gatorskins cost is on the order of magnitude of changing your hand position and tucking in your elbows. The power differences you are talking about, going from 20 to 30 mph, are an order of magnitude larger. The tires simply get swamped by the aero factors at that point.
And now you've lost all credibility due to ad hominem attacks and absurd claims. If you actually own everything "short of a wind tunnel" then why are you buying Gatorskins instead of top of the line, premium tires for your precious TT bike? Gatorskins aren't marketed to your ilk, because they aren't designed for TT bikes. They are designed for people that want a reliable, durable, flat-resistant tire that can still be supple and grippy in the corners, all while staying budget conscious. If you're out for pure performance, no, Gatorskins are not top of their class, but if you want to save some money and spend less time fixing flats, all while getting racing-quality grip, then Gatorskins are for you. It's literally just that simple.
Gators versus Vittoria Corsa TL is easily over 20w a pair. Maybe closer to 30w. 30w is 10% of a strong rec rider’s hour power.
Blah blah blah, power argument that is a repeat of what BoraxKid already said. Aero power is nonlinear.
You have zero clue. Give up. {No, I don't think I will} Some of us race time trial and do the weird experiments you see places like the GCN show screwing up for the sake of entertainment. I own all I need short of the wind tunnel.
Try again home slice.
#93
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Likes For Bah Humbug:
#94
Quoted: 325 Post(s)
Liked 109 Times
I guess I haven't done any precise testing on the speed, but I'm not making any assumptions when I say that they're "stiff." Here's me a few minutes ago holding a Pasela and a Gatorskin in my hand:
Not massively different in tire size, both wire bead. The Gatorskin feels a lot stiffer pushing on it with my fingers.
And it's not like I haven't ridden Gatorskins before.
#95
Liked 1,882 Times
That doesn't look like an actual Gatorskin tire in your hand in the first picture. Also, what the tire feels like in your hand, off the bike, means less than nothing to performance. That's a pretty obvious fallacy you've just fallen into. Like I said, when properly inflated, Gatorskins are quite supple and grippy--just as several others in this very thread and elsewhere around the world have reported.
Likes For Reflector Guy:
#97
Quoted: 550 Post(s)
Liked 325 Times
I've seen so many derogatory comments on these. What are the qualities that they exhibit that are so horrible? Not saying they're good or not, just curious.
I put a 700x28c Gatorskin on rear of my cyclocross bike and a 28 Vittoria Ziffiro IV on the front to turn it into a road bike this year. The Ziffiro was a little more than half the price of the Gator, and has lower rolling resistance in reference charts. My flats are almost always on the rear, so I wanted something tough back there.
I like that the Gator doesn't pick up grit; a quick wipe with a paper towel after a ride to look for cuts or embedded objects and it looks like new. The Ziffiro has enough tread that it picks up enough grit that I have to scrape bad spots with a plastic tool to make sure there's no glass or metal in there.
I realize I'm running inexpensive tires (the Gator is the most expensive tire I've ever bought), but what's so bad about the Gatorskins that they inspire so much hate?
Likes For Drew Eckhardt:
#98
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Likes For shelbyfv:
#99
Expired Member
Liked 5,431 Times
#100
Liked 3,016 Times
Likes For MinnMan:
