What does an expensive frame get you?
#126
Mark, for about $1200 I upgraded the wife's 2005 Roubaix pro DA7800 to Ultegra DI2. After demonstrating that everything was going to be fine I drilled the frame and routed the wires internally. It has been a great improvement for her (somewhat shifting challenged) and no more requests for a new bike (more important to me) and less mantenence. I can't tell the difference from my DA DI2. This is an example where more buks don't really help that much.
#127
Quoted: 645 Post(s)
Liked 797 Times
For a crit bike AL is as light and stiff as required. It will be very lively as AL is the densest material available will will transmit every shock. The better AL bikes try to replace as many AL parts as they can with CF. Comfort can be improved with geometry but you are still fighting the properties of the material. For the record CF has an unlimited fatigue life as opposed to AL with has a short fatigue life followed by titanium welds (also virtually unrepairable along with AL due to the need to autoclave the welds. There are choices out there for CF repair and it is not difficult or unreasonably expensive.
#128
What on earth do you mean by "autoclaving the welds"? An industrial autoclave might get you a couple of atmospheres evaluate pressure and temps up to maybe 160-180C - great for composites, but neither of which will have the slightest effect on most metals. If you're talking about heat treating Al, this is usually done anywhere from ~260C to 500C - in an oven, not an autoclave. Ti is heat treated at even higher temps. In any event, while Ti welding/repair might be technically trickier, Ti is so far from "unrepairable". People repair Ti frames routinely.
#129
Quoted: 83 Post(s)
Liked 157 Times
#130
Quoted: 645 Post(s)
Liked 797 Times
#131
Quoted: 645 Post(s)
Liked 797 Times
My friend crashed badly his Ti Motobecane and the downtube slightly bent and cracked. He could not find where to repair it for any reasonable money so he bought a new carbon bike. He chose carbon because the carbon fork in the Motobecane seemed did not suffer any damage in the crash.
#132
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
Then it would get packaged up and sent in for an inspection.
Likes For Andy Somnifac:
#133
You're gone from "virtually unrepairable" to "unrepairable for a price I'm not willing to pay" - slightly different. The are commercial entities that repair Ti frames, so clearly repairing Ti has some economic viability. In any event, I agree that carbon has excellent fatigue resistance (although I'm not sure that I'd take "unlimited" to the bank), and you may be right that steel and Ti will, given enough cycles, ultimately fail. However, I'm pretty sure that, if the elastic limit of the material is not exceeded, a well-made steel or Ti frame will outlive the rider. To my mind, how long the frame survives after that is academic.
#134
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 460 Post(s)
Liked 539 Times
Popeye:
nothing lasts forever. I have seen issues with decay of the potting that rugged electronics are often encapsulated in when exposed to high humidity and temperatures over 65C. So maybe don't store your bike in a hot shed in Alabama?
Please see: https://journals.sagepub.com/doi/abs...99802761675511
Abstract
The degradation of an IM7/997 carbon fiber-reinforced epoxy exposed to ultraviolet radiation and/or condensation has been characterized. Based on observations of physical and chemical degradation it has been established that these environments operate in a synergistic manner that causes extensive erosion of the epoxy matrix, resulting in a reduction in mechanical properties. Matrix dominated properties are affected the most, with the transverse tensile strength decreasing by 29% after only 1000 h of cyclic exposure to UV radiation and condensation. While, the longitudinal fiber-dominated properties are not affected for the exposure durations investigated, it has been noted that extensive matrix erosion would ultimately limit effective load transfer to the reinforcing fibers and lead to the deterioration of mechanical properties even along the fiber dominated material direction.
#135
Quoted: 645 Post(s)
Liked 797 Times
Myth: A carbon frame won't last as long as a metal one. Reality: As long as you don't crash hard or take a hammer to the frame, a carbon bike can theoretically last forever. In fact, steel and aluminum last only so long before the metal fatigues and can no longer be used safely, but carbon remains stable indefinitely.Mar 10, 2014
#136
Bikes: 2017 Specialized Roubaix Comp, 2019 Cannondale Synopse 105 SE, 2015 Cannondale Quick 5, 2019 Specialized Fatboy
Quoted: 37 Post(s)
Liked 49 Times
Popeye:
Abstract
#137
Quoted: 741 Post(s)
Liked 412 Times
Popeye:
Abstract
#138
Quoted: 460 Post(s)
Liked 539 Times
I personally have had a carbon fiber seat post on my trail bike "assplode", and it was not a fun experience. So I replaced that post with a Thompson aluminum post and put the warranty replacement on my road bike, which also has a carbon fiber fork. I have no issue with carbon fiber components. But saying that carbon fiber in an epoxy matrix will "last for ever" sort of is a trigger event.
By the way, if one of my Lynskey frames break, I will send it to them for repair or replacement. My guess is that they can do the repair fairly easily. If my one of my Ritchey bikes breaks, I will take them to the LBS and they will braze or weld them. No doubt there are people who can repair CF stuff, but the complex shape items like most high end frames are probably going in the bin if they break in one of those fancy areas.
#139
You should look up a podcast VeloNews did with Ruckus Composites on how they repair CF. It’s not that complicated. They grind away the affected area, then lay up new CF sheets and cure them. They said there’s little they can’t repair.
#140
Quoted: 20791 Post(s)
Liked 9,436 Times
Popeye:
Abstract
Likes For WhyFi:
#141
Quoted: 741 Post(s)
Liked 412 Times
Right you are. And I have been in a factory in Alabama where the lights which had over temperature shutdowns set at 65C were blinking off and on. Or under the hood on a dozer. Or a few other places I could mention. My real point is that even though the carbon fiber might last a long time, the goo around it will degrade over time, and most likely heat, humidity, and UV will accelerate that process.
#142
Quoted: 83 Post(s)
Liked 157 Times
Why do you think Moto is not worth fixing while Litespeed is? A genuine question. One of my bikes is Ti Moto and I like how it looks and how it rides. I've never tried Litespeed though.
#143
Quoted: 645 Post(s)
Liked 797 Times
As to your last comment, Litespeeds remain well-made Ti frames, although I don't know that they have the cachet that they once had when Litespeed was an independent company (mine was made at the tail end of the transition). There's a thread here somewhere entitled "My Litespeed Classic" or something like that, and all these people came out of the woodwork for no other reason than to show off their old LSs - a great thread. However, if I were in the market for a new Ti frame, I'd probably look at Lynskey (the original owners of Litespeed) first.
