Panaracer GravelKing SK 27,5" x 1,9" on 27"
Old 01-09-20, 10:27 AM
ollo_ollo
ollo_ollo's Avatar
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times in 267 Posts
Haven't shopped new 27" tires for a long time. My Super Course with 27" concave weinmanns needs tires. Unfamiliar with the size: Panaracer Grave lKing SK 27,5" x 1,9" Knobby Tread Tire, Black & Brown Sidewall
Really like my 700c Gravel Kings on other bikes, Question is, can these mount on the 27" rims of my Super Course?
ollo_ollo is offline
Old 01-09-20, 10:34 AM
CO_Hoya
Señor Member
Quoted: 284 Post(s)
Liked 296 Times in 149 Posts
Nope 27.5 = 650b (584 mm) is not equivalent to 27" (630 mm)
CO_Hoya is offline
Old 01-09-20, 10:43 AM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Liked 256 Times in 165 Posts
The 26"/27"/27.5"/28"/29" nomenclature is pretty obsolete, as it's supposed to refer to the OUTSIDE tire diameter. These days the ISO number (559/622/630) is the only one that you can depend on.
Hudson308 is offline
Old 01-09-20, 10:45 AM
stardognine
Partially Sane.
stardognine's Avatar
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times in 468 Posts
Aha, I’ve been wondering about that. I’ve been seeing 27.5 mentioned, a lot more recently, and have been curious, but didn’t want to ask, because I might sound like an idjit. 😁😉 I think I’ll stick with the more common sizes, until someone proves these oddball sizes have any real benefits. 🤔
stardognine is offline
Old 01-09-20, 12:58 PM
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
Liked 522 Times in 367 Posts
as others have said look for the ISO sizes, tires sizes can be confusing ISO helps compare apples to apples also for 27" tires check out the dedicated thread here
ryansu is offline
Old 01-10-20, 12:55 AM
verktyg
verktyg
verktyg's Avatar
Quoted: 1036 Post(s)
Liked 1,238 Times in 654 Posts
Not sounding like a noobee
There are ways of asking questions that will keep your reputation intact...
For example: "I've been around bikes for a long time but I'm not familiar with this fill in the blank. Likelihood of getting an intelligent respectful answer are pretty good.
The old saying in school was, "The only stupid question was the one not asked"...
verktyg
Chas. ;-)
verktyg is offline
Likes For verktyg:
Old 01-10-20, 01:06 AM
jackbombay
Quoted: 457 Post(s)
Liked 462 Times in 270 Posts
This!
My mountain biking buddies get really confused when I tell them that my 27" rims are larger than their "29er" rims.
Based on how arbitrary MTB rim/wheel size designations are its obvious that MTBers have all hit their head too many times ;-)
jackbombay is offline
Old 01-10-20, 02:28 AM
HTupolev
Quoted: 1974 Post(s)
Liked 1,298 Times in 630 Posts
It's a good thing we have inaccurate inflated diameter proxy marketing gibberish to keep things simple. Imagine the chaos and confusion if wheels and tires were sold by something complicated like bead seat diameter!
27.5" refers to a bead seat diameter of 584mm. 27" refers to a larger bead seat diameter of 630mm. Similarly, 700c refers to a bead seat diameter of 622mm. The bead seat diameter of a rim and tire must match exactly for the combination to work correctly: even though 27" and 700c rims are only 8mm different, their tires are not interchangeable. Similarly, you cannot mount 27.5" tires on a 27" rim, because 27.5" rims are smaller than 27" rims.
HTupolev is online now
Old 01-10-20, 07:17 AM
Pompiere
Pompiere's Avatar
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times in 514 Posts
The only reason they chose 27.5 was because it was in between the common 26 inch mountain bike size and the 29er size. 27.5 was supposed to be a compromise between too big and too small. Like most bike tire common size names, it didn't have anything to do with actual measurements.
Pompiere is offline
Old 01-10-20, 07:45 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
You need to be concerned about tire width as well. There is no way that 1.9 (50mm) tires will work on your Super Course. The widest I've been able to fit on my 1972 Super Course were 35mm, and they were very close to the chainstays. At present, I have Panaracer Pasela 27 x1 1/4 (32-630) on the bike. I like them a lot. The choices for 27" tires are not extensive.
Moe Zhoost is offline
Old 01-10-20, 09:48 AM
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
There are more 27" tires out there than you might think, we can debate if the selection of top tier tires ala Compass type tires is exhaustive but there is a whole thread dedicated to all the 27 inch tires, Like you I really like the Pasela's and have them on my Moto GT and a Trek 520, and for a bit wider tire I love the Swift (panaracer) Sand Canyons in 27 x 1 3/8 which I run on my Nishiki Cresta GT touring bike.
ryansu is offline
Old 01-10-20, 11:51 AM
ollo_ollo
ollo_ollo's Avatar
Quoted: 467 Post(s)
Thanks all, I know of ISO sizes, but see ads on CL and eBay that don't use them. Old enough to not worry about what people think. Was going to go with the Pasela Panaracers, but hoped there might be something fatter that would fit. Don
