Dust cover removal 1987 Schwinn Tempo
Quoted: 211 Post(s)
Liked 199 Times
Wondering how to remove this dust cover.
I have never seen one like this.
Does it pop out or unscrew?
Has 2 small holes about the size of a common pin
See pic
Any and all help
appreciated
See pic
Any and all help
appreciated
I think a small diameter pin spanned would be the tool for this. Be sure and dribble some lube in there first!
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
bikemig
If you don't know the history of this bike, don't try to unscrew without putting in a bit of penetrating oil and letting it soak in - especially if you don't have the proper tool. I've had them crack or the holes widen on bikes that haven't been maintained. Same goes with the dust caps with a hole for an allen key (they usually strip and the allen key simply spins). Finding correct replacements can be a challenge.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
WD40 works great for taking apart all sorts of old plastic parts, things like this cover or things like the plastic push-in fasteners used on car door inside panels and bumper covers, etc.
Also when taking apart plastic hose or electrical connectors under the hood, those plastic pieces (some with a metal clip) that don't come apart even after the clip is pulled out need a bit of soaking time and wiggling but finally come apart without damage.
Quoted: 211 Post(s)
Liked 199 Times
I used a set of spanners I have !!!
Worked prefect !!!!
Thank you ALL !!!!
GREAT and knowledgeable people on this forum !!!!!!!!
Worked prefect !!!!
Thank you ALL !!!!
