Garmin Edge - What a POS
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
It's spun up vent time. I'm sitting at home at 8:30 in my cycling gear, waiting for my Edge 520 to charge.
I've owned this thing for 4 years now so I should know better but this is the second time in that period that I've forgotten the fact that for whatever asinine reason, Garmin programmed the Edge series to turn on when plugged in and then not to turn off again when unplugged. So, I charged my computer but apparently forgot to turn it off and a block from home it was already dead. I would much rather need to turn it on when plugged into USB if I want to access data (which I never do thanks to bluetooth) than have to remember to turn it off after charging.
If you search this issue on line, there are dozens, maybe hundreds of complaints like this to Garmin but clearly they have no interest in changing a line of code.,
36%....
Add this in to their data hijacking fiasco, and the fact that since then (and again, I'm not alone) I can no longer change the gear used for a ride without going in to their website, and I really have to wonder how much longer I need to keep using this thing. Once it dies, wahoo?
38%....
(no, I'm not very patient)
36%....
38%....
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Using the desktop computer (Windows 10) is what I do and before that Windows 7. Never had that problem.
But I do that extra step. On my screen, at the bottom right, there's some icons. One will show a USB icon. when highlighted by my mouse, it will say "Safely Remove Hardware & Eject Media".
That' how I eject the Garmin device. I don't need to press the Garmin button on the upper left. The device will know that the USB charging and data trasfer cable is being removed with no "juice" being transfered.
By the way, the Garmin USB cable has a dual purpose: as a charging and as a data transfer line. Some USB cables only do charging. For example, the more modern cars will have an upgraded sound system. They don't call it a radio anymore; its a head unit. Today's head unit is equipped with a USB cable that does both: data transfer and charging. Why data transfer? Because a flash drive with music data can be played from that head unit.
Quoted: 148 Post(s)
Liked 119 Times
This is an issue when plugged into a wall wart. When you plug it in, it turns itself on. You can turn it off, which then allows you to see charge status on the screen nice and big. As soon as you unplug it, it turns itself back on so if you don't notice or forget its stupid habits it'll just sit there powered on until it dies.
53%...
Good enough to head out
53%...
Likes For CyclingFool95:
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
53%...
53%...
Likes For Sy Reene:
Likes For colnago62:
Advocatus Diaboli
Liked 1,531 Times
Likes For Sy Reene:
Likes For noodle soup:
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
When mine's unplugged, it says 'Turning off in 10 seconds; Ok: Cancel" but holding down the power button does it quicker.
EDIT: I always plug it in after every ride, because, yeah, I did forget to turn it off one time, left it thinking I was still riding while the bike was hanging on the wall, and next ride, it died in the first mile.
So I rode without it.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
5he 530 turns off when you unplug it
Advocatus Diaboli
Liked 1,531 Times
Not sure about the 530, but the OP is referencing turning off the unit while it's charging, which is fine.. you get a Battery% indicator. However, when you unplug from this state, the unit turns back on. This has always annoyed me -- not sure what Garmin's logic was that when you're done charging the unit and unplug, you'd want it to turn on by itself.
Anyway, after the OP's unit turns on after unplugging from the charger, his does not evidently ever turn itself off. Mine turns off after the 5 minutes that the Auto Sleep does. Wondering if OP hasn't updated unit firmware in a long time?
Quoted: 347 Post(s)
Liked 418 Times
As we say in the electronics industry, “it’s not a bug, it’s a feature”.
My Edge stays on the bike all the time during the summer riding season. There is no real reason to ever remove it. When it rolls into the garage I have a charging cable for the edge and a charging cable for the lights. Next day, disconnect, the Edge wakes up, and we’re ready to roll.
Likes For billridesbikes:
Likes For Germanrazor:
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
It's really simple for me. Bought my 800 in '10, never had a problem with it. I NEVER plug it into the computer. Everything's on a card - I use a reader. I have several cards with different maps and routes for different places and usus. When I come home, I plug the Garmin into a charger. I upload and download all info with the card reader.
Results matter
Results matter
Non omnino gravis
Either the OP doesn't have Auto-Sleep on, or he's a victim of Garmin not having Auto-Sleep as a global setting, but having it instead set to each activity profile individually. I think in 2+ years I used my 520 in something other than "Outdoor" like 5 times, so it was never an issue for me.
Beyond that, the 520 works just fine while plugged in. Many a ride did I finish with a USB battery pack strapped to the handlebars with whatever I could find, because in it's old age (and hundreds of charge cycles) my 520 was good for maybe 4 hours on a full charge.
Expired Member
Quoted: 3657 Post(s)
Liked 5,393 Times
I think OP will be pretty happy if all he has to do is enable auto sleep. Update?
Quoted: 20808 Post(s)
Liked 9,450 Times
Likes For WhyFi:
Liked 9,450 Times
Likes For WhyFi:
Expired Member
Liked 5,393 Times
I hope I can forever resist the urge to vent on BF. It rarely ends well for the OP. We've got the recent threads about Trek and Wiggle, not to mention the year long (yep one year) derangement about Canyon in the M,R,S and C Feedback section. Cautionary examples for us all.
Likes For shelbyfv:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Learn to use your equipment.
Likes For Bah Humbug:
Likes For adamhenry:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
I just took my charged 520 (which was on the main [RIDE] screen) off the charger to take to my bike for the morning. It immediately started a 15-second countdown and turned off just fine.
Quoted: 237 Post(s)
Liked 177 Times
For more than two decades I've found the marketplace around cycling data to be under-realized. Given the landscape changes (tech advances, ubiquitous connectivity, acceptance of renewable revenue models) you'd think someone would "pull and Apple" and make an attempt at a well funded market consolidation by designing a great piece of hardware and back-ending it to a reliable and well designed app/site platform.
I'd be very eager to shell out for that.
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I have an older 520 that has been relegated to indoor trainer use only. But I would guess that four times or so I have encountered a dead 520 for the reason stated by the OP. If there is a reason for 'doing this on purpose' I have never heard it. I agree with the OP - it is really irritating. If someone were to ever publish what 'no activity' means (the thing that initiates an auto sleep) I might reconsider, but for now I don't use Auto Sleep because I don't understand it and simply do not want to do a bunch of experiments to figure it out.
dave
dave
