Crank arm backing off the spindle
Quoted: 5 Post(s)
I suspect I will need to replace the crankset and bottom bracket, but I'm looking for a less expensive option.
The free crank arm backs off the spindle of the bottom bracket. The result being that the crank and pedal would fall off, if I let it.
I retighten everything and am good for 5 miles before the crank starts to work itself loose.
Loc-tite on the crank screw has not worked.
Suggestions appreciated.
Thanks
Chip Roth
Thanks
Chip Roth
Senior member
Quoted: 943 Post(s)
Liked 659 Times
Thanks
Chip Roth
Thanks
Chip Roth
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times
More information is needed. Manufacture and model of bike and of crankset. What is the crank/BB interface? Is the crankarm or spindle visibly worn? How many miles on the bike, is it getting worse, did it just happen suddenly and since then every 5 miles?
Quoted: 1074 Post(s)
Liked 295 Times
Usually, once a crank arm starts to wiggle, it quickly destroys the fit between BB axle and arm. Getting it to stay on after that often turns out impossible. As luck would have it, manufacturers have realized this and it’s often possible to purchase only the left arm.
The BB axle - being steel - will usually not be damaged.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
If there's a bike co-op near you, they'll have a bin full of crank arms, maybe even sorted by length, for a few bucks each.
Likes For andrewclaus:
Quoted: 1438 Post(s)
Liked 1,092 Times
Good advice. The crank arm does not need to match exactly, just the length (should be stamped on the inside of the arm, likely 170mm+/-) and orientation of the taper, "square" or "diamond." Might get a used or takeoff one cheap at a bike shop. Don't forget to torque the attaching bolt/nut sufficiently, and the pedal too, so they don't come loose again.,
Quoted: 1324 Post(s)
Liked 927 Times
I've managed to get quite a few extra miles/kilometres from a worn square taper crankarm by using a gel cyanoacrylic glue to glue a shim to each of the flats on the bottom bracket spindle. That works until I can find the matching crankarm.
Cheers
Cheers
Clark W. Griswold
Quoted: 4360 Post(s)
Liked 4,001 Times
Just for those stumbling in the thread was started on 10/25/2020 at 11:50am and the final post was that same day at 1:47pm. Not saying that CA glue might or might not help just for folks thinking this was an active new thread.
Likes For veganbikes:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
He started three threads about three different problems. All together, it sounds like a complete cluster ****.
Likes For SurferRosa:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I have used a triangle file to flatten the taper. It has worked on 2 different NDS crank arms. You need to get any and all burrs out of the taper with an eye to preserve the taper. I had to do this on all 4 flats.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Quoted: 514 Post(s)
Liked 451 Times
Or you can buy a new one at your local bike shop for $15.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
