Sore Butt
Bikes: Trek 7.2 FX
Quoted: 15 Post(s)
Liked 19 Times
Sore Butt
Newbie biker just starting 3rd week of owning bike (1st bike in 20yrs+). I'm riding 6 days a week. So far I've logged 119 miles this month, and just upped the effort by starting an 8 week training plan.
I've been riding in dri-fit athletic shorts/tops, not biking specific gear. Have had zero problems getting used to saddle until these past 2 days when my riding time has hit 1 hour per my plan. Now by the end of the ride the butt is getting a bit sore. Soreness goes away within minutes of getting off bike and getting my land legs back.
Is this just normal getting used to riding for a longer time? How long will it last?
Will cycling shorts make a big difference? I'm somewhat self-conscious about wearing them (plus I've spent my budget on bike/gear) so I'll stick with what I've got unless it's a big benefit.
daily 8 miles each way , I wear regular clothes (shopping runs) . when touring, riding all day, I wear bike shorts ..
even as Underwear with other stuff over them , (cargo shorts Etc.)
for the sweat absorbant seamless smooth surface against my crotch skin..
A clean Pair, daily..
Bikes: Trek Domane 5.2, Ridley Xfire, Giant Propel, KHS AeroComp
Quoted: 1648 Post(s)
for rides getting into an hour and longer I would switch to biking specific shorts. Cheap ones like house brand from nashbar or performance bike will likely work ok for 2 and 3 hour rides, but longer than that go to a higher quality short.
Bikes: 2012 Specialized Camber Expert, 2012 Specialized Roubaix Expert, 1996 Specialized Stumpjumper, 2014 Electra Tiger Shark.
Bikes: Old rusty bucket of bolts
As we ago mussel tisue, skin, and your body reacts differently. Or does not tolorate as much abuse and discomfort as when you were in your 20's. My other half was a nurse 40+ years, she says no one ever died from a little pain.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Cycling shorts make a difference in comfort. The longer the ride the more important comfort in the saddle is.
Bikes: All-City Space Horse
Could be a number of things, but most likely you are still getting used to the saddle. It should get better, but if it doesn't, padded shorts should do the trick. People are different, so some people can last longer than others, but it doesn't seem like you have any weird issue.
Do dri-fit shorts wick moisture away (sounds like it does)? If so, the wicking effect of bike shorts probably won't help, IMO.
Modern bike shorts might help. The most comfortable shorts I've ever worn were wool with real chamois. 2nd best was polyester with a polyester fleece-type pad (Avocet & Cannondale from the '80s). I'm not really happy with the thick pad in a pair of Serfas shorts. Padding today is much thicker than my old stuff, and I think it just spreads out the pressure to areas that aren't normally affected when sitting/perching. Butt soreness is an individual thing, though, so maybe thick padding will work for you. If you want thin padding at low price, try out Aerotech Designs basic shorts: Mens Basic Padded Cycling Shorts on Sale now $24.95. (They have a wide variety of clothing at good prices.)
Sometimes a saddle is good only up to a point. What saddle are you using?
Quoted: 5781 Post(s)
Liked 2,578 Times
Will cycling shorts make a big difference? ...
FB
Chain-L site
FB
Chain-L site
Quoted: 2952 Post(s)
Liked 3,106 Times
The last time I bought a new saddle, it probably took 119 miles before I broke it in. Or rather, it broke me in. I suspect you're still getting used to it. I also think a proper pair of shorts will benefit you, not so much because of the pad, but because you won't be sitting on any seams or hems. I don't mind a short commute or shopping trip in regular clothes, but once I'm going to be in the saddle for more than an hour, I wear bibs.
Bikes: Fuji Sportif 1.3 C - 2014
Quoted: 5 Post(s)
Get some biking specific shorts/bibs.
I got these, and they are very comfortable: Performance Ultra Bib Shorts.
GH
GH
Liked 208 Times
There is a huge variety of saddles you can look into. it isn't so much padding as size and shape that matter, IMO. I have been using a Brooks B17 for 3 years now. I know they aren't for everybody but I am generally very satisfied with my Brooks.
Bikes: Trek 7.2 FX
Quoted: 15 Post(s)
Liked 19 Times
My LBS had some baggy bike shorts on sale so I picked up a pair. I'll give them a try in the morning and see if it helps solve my problem. Thanks.
Quoted: 3352 Post(s)
Liked 1,056 Times
You see so many people go out and buy a bike, only to see it hung in the garage and not ridden because of butt pain. Then 5 years later it is sold on a garage sale for $40. OTOH if they had bought a bent bike or trike, they would probably still be riding it.
I would rather folks ride what they enjoy and not worry about what other folks think...if a bent is your thing, go for it...stigmas are in people heads, not on a bike. I ride what I like, because I like it, not because of what other folks think...I have 4 bikes, each a different brand, and each a different style...I ride which ever one best suits the ride I plan on doing that day...
As for the OP, if you haven't rode a bike in that many years, you need to build up your sit bones and muscles in your butt again. I haven't been on a bicycle in 15 years and the first time out my butt was so sore and so much pain due to my sit bones and muscles there not being used to being on a saddle.
Bikes: Berthoud Randoneusse, Curt Goodrich steel road, Zanconato Minimax road, Jeff Lyon steel all road,
Quoted: 15 Post(s)
it takes a while to build up to comfort. i do ok up to 40 miles. rides of 40plus i wear cycling shorts. I found Sugoi brand shorts to be the nicest so far, smaller pads, better fit. on sale at sierra trading post now too. much nicer than the rei brand. the other big thing is saddle. i have tried 5 diff saddles now and want to keep trying. I have settled on brooks b17, the classic. tried brooks pro and one other brooks, and they were not quite right. I want to try brooks Cambium next, the c17. bit more narrow than b17, but not as narrow as the pro. folks seem to love that saddle.
so if you are serious about the bike, go hunting for a saddle. if you have a good bike shop they can help, if not, its musical saddles like me. also, on your saddle now, a slight tip up or down could help.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Good to hear ... and there is just simply some getting used to longer distances. The fitter you are and the more time you put into it, the more comfortable you'll be.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Bikes: Trek 7.2 FX
Quoted: 15 Post(s)
Liked 19 Times
Further Update: Just finished 1st 2hr+ ride. Really glad I had those bike shorts. Stood up on pedals a few times to stretch out and readjusted my position on the saddle a time or 2 but no significant butt soreness at all. Thanks for all the helpful suggestions.
