New to Racing? Here's a tip or two
#251
1337
Bikes: CAAD10
LP/Bariani is fun for me because it's like a mini-omnium. The crit is fast, except for those two pinch points on the backside that require some thought and skill. The road race is wide open, flat (apparently even more so this year), and totally exposed to the wind. Racing in the wind is a skill that every racer needs to learn, especially in NorCal. You will learn so much in two days: about fitness, about following wheels, about when to get in the wind (rarely), about when to stay out of the wind (almost always), etc., etc.
#253
ride lots be safe
Quoted: 13 Post(s)
Common things that I still see riders doing wrong, even cat 1 riders... but more so in the lower cats:
1) Eating too much wind, for a variety of reasons. Listen people, mass start bike racing's central defining characteristic is DRAFTING. If you want to be a bike racer you must acknowledge, internalize, and LIVE IT. If you have some sort of secret internal conflict where you think drafting is for losers and wheelsuckers, guess what: you will never win anything except Strava segments and people will always say about you, "gee he's so strong but he just never can get a result in the races". Is that what you want? No, didn't think so. SO LEARN HOW TO DRAFT.
1a) riding "near the pack" is NOT THE SAME as drafting. You should focus on drafting one particular rider, not "the pack".
1b) Drafting means, being in the sheltered spot that's usually directly behind the rider (in calm air). NOT 6 feet back... more like, your front tire is about a foot from their back tire. Yes, you have to pay attention. NOT 3 feet to the side... stay in the draft.
2) Taking turns WAY TOO SLOWLY. You worked really hard to get going so fast, so why are you coasting halfway down the straight, dragging your brakes and entering a wide flat smooth turn at 16mph???? Jeeeeeesus.
- Learn proper posture for cornering, and DO IT
- Quit touching your Goddamn brakes when the road is 60 feet wide!!!!
- DO NOT COAST into a turn where you can pedal at full speed. FertheloveofGod.
- Honestly... in typical American crit and road racing there are very few turns where you even need to touch the brakes... and don't worry, everybody else will be sure to let you know where those are.
2a) Taking HORRIBLE LINES into and through corners. Really. If you want to go as fast as possible (and you always should, because IT'S A RACE), then you need to take the path thru the turn that allows you to go fastest. This involves setting up ALL THE WAY on the outside. Not in the middle of the street, wasting half of your space. ALL THE WAY. Then, you don't begin diving / leaning into the turn until very late... later than that... not yet.... because when you get antsy and "turn in early" you're wasting all the room for your turn and then you'll end up at the exit with a bad line having to scrub your brakes then jump again... why do that to yourself?
3) Half-assed attacking. This one really gets me. Listen, buddy, I'll be straight with you: it's REALLY REALLY HARD TO BREAK AWAY FROM THE PACK. Therefore, your measly little "jump 100 meters and look back" is NOT going to do the trick. You have to KEEP GOING. YOU HAVE TO "BREAK" THE PACK.
Get it? BREAK THE PACK. Does that sound easy? No? Good, it's not. So KEEP GOING. STILL KEEP GOING. YES I KNOW IT HURTS. KEEP GOING.
Thanks for listening. If you do these things and do them well, you might still suck... but then you might not.
#254
ride lots be safe
Quoted: 13 Post(s)
buy this book. read it. make your teammates read it. do it.
https://www.amazon.com/gp/product/193...?ie=UTF8&psc=1
#255
Announcer
Thanks for that tip! And the corresponding review!
I read Prehn's book and the Wenzels' book before I started writing this one. I don't want to off-put their efforts, but I think RtR goes a lot deeper into the sport. And my two biggest lessons are:
1. The draft is your friend. Always.
2. Counter-steering is your other friend. It helps you A. corner better, and B. avoid crashes.
#257
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
I spent some time today reading all of this thread. It has a lot of wisdom in it. Chapeau to botto for starting it.
#258
Elite Fred
Quoted: 60 Post(s)
Liked 42 Times
Bad lines through corners is a Racing 101 blocking technique.
#259
Making a kilometer blurry
+1 My best friend (J)'s first win was because of this, in a backwards sort of way. He and a seasoned racer were OTF for 30 minutes in a crit. Every lap, the veteran would take a bad line through this chicane and squeeze him out. J was onto him, but let him continue to do it for the entire break. Until the last lap. On that lap, J charged through on the good line and his break partner was taken extremely of guard after the previous 15 times through that corner the same way. They bumped elbows, then J gapped the veteran racer right there and took the win.
For the first 5 laps or so, the technique totally worked, and J was out of sorts with what was going on. Same thing lap after lap, and he learned, then schemed. If that technique had been used only on the last lap, J would have had 2nd. We're good friends with the veteran and rehashed all this after the fact. Was pretty interesting. I happily got 3rd that day
#260
Bikes: Trek 1.2
Quoted: 25 Post(s)
I never ride outside when it's under 40 degrees, and it seems like for next weekend, March 1st, the first race is expected to be 20 degrees below normal, maybe about 15F at the start. Is there any way to manage this? Should I just try to take it easy since it's cat 5 and I just have to finish without getting lapped? (not going to happen, it's 4 6-mile laps around central park). I don't even have gear that's suitable for riding in weather under 35 degrees, unless I put on a fleece, a shell, maybe 2 pairs of pants, and gloves, maybe a gator. This winter sucks.
#261
Throw on a ton of clothes and get after it. Your race will only take about an hour, so you won't be outside in the cold for too long.
Also, have to ask, what's the gator you are referring to?
#262
Quoted: 2952 Post(s)
Liked 3,106 Times
#263
The "gator" is actually a (neck) "gaiter." And, yeah, I think you're doing well on the bottom half (if "pants" means "tights"). The top half, I'd wear SS jersey, arm warmers, LS jersey, and a vest, maybe the shell to warm up, and shove it under the back of your jersey assuming you get warm enough to remove it before the start. Get hand warmers for your shoe covers and for your hands (wear them on top of your hand and on top of your shoes). Fill your insulated bottle with hot water or hot tea, and roll it in a towel inside your gear bag for insulation during transportation.
#264
In the Pain Cave
Everyone is different. My 15f
Bibtights
ls base layer ls jersey jacket
lobster gloves
booties w/ duck taped vents and chemical warmer
wool socks
balaclava
glasses
Bibtights
lobster gloves
wool socks
balaclava
glasses
#265
Bikes: Trek 1.2
Quoted: 25 Post(s)
Rain is expected all night so either the course will be soaked and it may be raining during the road race. People on here say to lower tire pressure. I usually run 100 front, 110 rear and I weigh 160. Should I do 90 in front and rear? Should I give more room or draft the usual distance? Will my water bottle get filled with road gunk?
#266
#267
Bikes: Trek 1.2
Quoted: 25 Post(s)
Question about doing a Crit where the first lap or two are at at controlled pace and then the race officially starts.
I did a race a month ago where the first two laps were controlled and people were riding along around 16 or 17mph on the flats for the first lap (1 mile each). Then on the second lap it got a little faster with a few people ramping up the pace and while the race didn't officially start, it seemed people were trying to get to the front and jockey for position. Is there a certain etiquette on these preliminary laps? In the next race I do, should I try to stay at the very front even if I have to exert a decent amount of effort before the race officially starts? Do people ever go too hard on these laps and then get chastised by others in the race? I don't want to get stuck again in the middle where the accoridan effect tires out my legs and lungs before the race is over.
#268
Ninny
Quoted: 686 Post(s)
People definitely jockey for position on neutral laps. No particular etiquette, except for not being a jerk (and not passing the pace vehicle).
Having said that if you want/need good positioning at the start of the race, the first 5 seconds after you clip in is really key.
#269
Bikes: Scott Foil 10, Di2
Quoted: 148 Post(s)
Hey y'all. I had my first crit race last night, held in the group no problem the whole way, and was feeling great going into the last corner for the sprint (the 3/4 women were racing with the 4/5 men). But coming out of the last corner, someone took out my front wheel and I went down hard. I'm okay, but missing a lot of skin. Are there any tips for how to "protect my front wheel" in the last turn of a crit? Specifically, are there ways to make it less likely that someone who doesn't hold their line (especially someone on the outside who cuts back in) will take you out?
I know that some of the advice is to be in about the top 10, but that's really hard if you're a 3/4 woman racing with a bunch of 4/5 guys. But maybe I should try harder on the last lap to be closer to the front (I was in the top 20 in the last corner).
#270
gmt
Quoted: 45 Post(s)
you have to learn to modulate the brakes enough to change your position while leaned over. Additionally, you have to learn to use counter-steering to adjust your lateral position while leaned over. These techniques will allow you to make subtle changes to your position while in close quarters and respond to immediate situational changes. If someone has the high ground on you (meaning they are already in front of you) then if they move into you, you have little choice but to change your position to stay safe. I suppose you could try pushing off them elbow-to-hip, but that seems iffy at best, especially if they have more mass.
#271
Quoted: 148 Post(s)
I guess it's confusing because everything else I read says not to touch your brakes in the turn (and the turn was easily wide enough not to use brakes). I should maybe note that it was really irritating last night because people up front were touching their brakes into this turn a lot (when it was totally unnecessary). So maybe I should just care more about my own safety, brake if I get out of position, and stay upright? I guess I'm just a little worried about getting yelled at by people behind for braking.
#272
gmt
Quoted: 45 Post(s)
they say that because they don't know how to modulate. when applied properly, those little levers can be used to simply move you from being crashed to being in a perfect position to get lead out for the sprint from the sketchy guy in front of you. But you need to practice it so you don't overbrake and take yourself out.
#273
Quoted: 148 Post(s)
OK, this gives me some confidence. I was perfectly fine with my body positioning, and I know how to counter steer, but I wasn't confident in it being safe/permissible to even feather my brakes ('modulate' as you say). It helps that I have carbon rims that the brakes are a little forgiving in not grabbing quickly for sharp braking, which makes modulating easier I think. Thanks. This is helpful. My next race is Sunday.
#274
Bikes: Yes
Quoted: 9 Post(s)
As Grumpy says it's a combination of counter steering and braking. When I'm winding up I'm not using my brakes so it's all counter steering and closing holes. You also want to put yourself into a position where others can't take you out. If it's a mad scrum to the line, that may mean eating some wind.
#275
Quoted: 163 Post(s)
Another thing, canuckbelle, (and this may not apply, I wasn't there, and I'm not "blaming" you for your crash...) -- anticipate that outside-to-inside move.
As a new racer you may be tempted to enter the corner near the inside, the pocket of clear space looks tempting - but it's an invitation to be cut off.
To prevent the problem in the first place, be in the racing line that others are using, which is usually the outside-inside-outside line. If you start your corner inside of other riders, expect them to come in to the apex - and be ready to either brake to keep them from sweeping you out, corner harder, or accelerate so your front wheel is in front of theirs.
Also w/r/t braking during a race - don't ever slam on your brakes, but given the choice between being yelled at for braking and crashing, brake.
Edit: by the way - congrats on being top 20 in a race with 3's and 4/5 men! That's huge, you are going to progress really fast, especially with your good attitude.
