Help,divine guidance, further instruction on removing freehub body
Old 01-21-08, 10:33 AM
Don777
Bikes: Cannondale R600 and Beater MTB
Quoted: 9 Post(s)
I have a 9 speed freehub body that I am trying to remove. With 20K miles I would like to flush it out. Checked the Park site for instruction. Seems mostly clear. I used the 11 MM Allen wrench with and 18 inch pipe for leverage. The Park site said it would be difficult. That is an understatement. I am attempting to turn the thing counter-clockwise, all to no avail. I feel that I might break something, warp the wheel, etc. and I do not have a back-up wheel. Any wisdom is appreciated.
Don777 is offline
Old 01-21-08, 11:41 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
11mm? All of the Shimano freehub bodies I've worked on use a 10 mm Allen wrench. They can be TIGHT but they unscrew counterclockwise just as you are attempting.
HillRider is offline
Old 01-21-08, 12:23 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
I vaguely remember having to find an 11 mm wrench for one but, like hillrider, most of the Shimano freehub bodies that I have removed have been 10 mm. An 18 inch breaker bar would freak me out too. I've never needed to use anything like that for removing a freehub body bolt.
Retro Grouch is offline
Old 01-21-08, 12:40 PM
Sheldon Brown
Gone, but not forgotten
Sheldon Brown's Avatar
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times in 5 Posts
You don't need to remove it to flush it. My advice is to leave it on the hub, unless/untill you decide to replace it for some reason.
Put the wrench in a vise, that way you can apply balanced torque to the wheel with your two hands 180 degrees apart. This minimizes any risk of damaging the wheel.
Sheldon "Couple" Brown
Sheldon Brown is offline
Old 01-21-08, 01:17 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
I have a Bontrager freehub that takes an 11mm hex wrench. I couldn't find an 11mm, but found that 7/16" is pretty darn close. Riding torque is not exerted through that bolt. Rather, the bolt holds the freehub body so it engages a mechanical lock.
That screw holding the freehub body to the hub shouldn't be on that tight. Installation torque is probably in the 30 ft-lb range.
What brand freehub do you have? If it's Shimano, then it's probably 10mm. An 11mm in a Shimano may be catching on something other than the freehub body bolt.
Also, I use 3/8 drive hex bit socket tools. These are stiffer and provide a more positive engagement than typical L shaped wrenches.
MudPie is offline
Old 01-21-08, 05:16 PM
Don777
Quoted: 9 Post(s)
Thanks for the responses. Yes, it is an 11 MM. The Park site said a Shimano hub would be 10 and some others will be an 11. I tried the 10, but it was too small so I ordered an 11 from my hardware store. The 11 fits good.
I may try the vise method as suggested by Mr. Brown and if that does not easily/comfortably remove the pin, I will take Mr. Brown's advice and try to flush it out while still on the hub. Again, thanks
Don777 is offline
Old 01-21-08, 05:27 PM
tellyho
Your mom
I'd definitely just leave it on there and flush.
tellyho is offline
