How does one oil a shimano 333 hub?
Old 01-23-08, 10:26 AM
mavimao
mavimao's Avatar
Bikes: Custom Mercier - Velo'v - Peugeot FG conversion
I'm doing some repairs on my girlfriend's bike and I was wondering how one oils it? Do you just drip some in the hole where the shifter pin slides in? Thanks!
mavimao is offline
Old 01-24-08, 11:22 AM
DMF
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
[redacted to suppress ignorant advice]
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Old 01-24-08, 12:16 PM
well biked
well biked's Avatar
Quoted: 140 Post(s)
Liked 162 Times in 89 Posts
Originally Posted by DMF
No.
And you don't "oil" a bike, anyway.
Look at the sticky thread at the top of this forum for how-to pointers.
The Shimano 333 hub is an internally geared hub, not as good as a Sturmey Archer. I suspect you do oil it, much like you do a Sturmey-Archer, but I don't know for sure. The OP's question is certainly not a dumb one regardless.
If you're not familiar with something someone is asking about, why pretend you are? Just let someone who knows about the hub answer the question. Hopefully Sheldon, or someone else who's actually serviced one of these things, will answer the OP's question-
well biked is online now
Old 01-24-08, 12:19 PM
n4zou
Scott
n4zou's Avatar
Bikes: Too Many
Yes; you got it.
n4zou is offline
Old 01-24-08, 12:39 PM
TimJ
TimJ's Avatar
I had one and it had an oil port. Weird that some versions don't.
fun facts: Psychopaths have trouble understanding abstract concepts.
"Incompetent individuals, compared with their more competent peers, will dramatically overestimate their ability and performance relative to objective criteria."
TimJ is offline
Old 01-24-08, 12:43 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
That's the way I did mine.
Bill Kapaun is offline
Old 01-24-08, 12:53 PM
DMF
Elitist Troglodyte
DMF's Avatar
Whatever hub it is, you don't "oil" it through the skewer hole. And examine the context. The OP asked about "oiling the bike", which I take to mean the whole bike. I'm aware that some parts of a bike do take oil , but a 3-in-1 can won't do #### for the other 95%. I therefore conclude that the OP needs to do a bit of research.
Besides, I dredged the thread - unanswered - off page three. Better some post then none at all. Agreed?
- Will Rogers
DMF is offline
Old 01-24-08, 01:04 PM
well biked
well biked's Avatar
Quoted: 140 Post(s)
The only service you did for the OP was bringing the thread back to the top, which apparently has now provided the answer he was looking for. FWIW, it was headed back down the page when I drug it up, too. I think a more appropriate answer for you to have given would have been something like, "I have no idea, but I'll bump the thread for you." That would have been nice. Because if the thread had ended with your "answer," the OP would have clearly had some bad info-
Old 01-24-08, 01:10 PM
mavimao
mavimao's Avatar
Thanks everyone and to you TimJ for the clarification
VVVVVVV
mavimao is offline
Old 01-24-08, 01:11 PM
TimJ
TimJ's Avatar
Yes you do. Stop saying that and confusing the issue. You didn't realize what hub he was referring to, now you do so you should stop the semantical berating, it's not helpful and it's incorrect, anyway.
If a 333 3-speed hub doesn't have a port then yes, you would put oil where the skewer goes. The skewer is the shifting mechanism and the only opening into the hub unless you take it apart. These are bolt-on hubs.
TimJ is offline
Old 01-24-08, 01:26 PM
Sheldon Brown
Gone, but not forgotten
Sheldon Brown's Avatar
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times in 5 Posts
That's correct, just lay the bike on its left side and drip the oil in where the pushrod goes.
See also: https://sheldonbrown.com/333
Sheldon "Oil" Brown
Sheldon Brown is offline
Old 01-24-08, 03:45 PM
jgedwa
surly old man
jgedwa's Avatar
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times in 18 Posts
No. To everything you said. Please do be careful in doling out advice like this. It is wrong, and the tone is insulting.
jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
jgedwa is offline
Old 01-24-08, 05:35 PM
Sci-Fi
Sci-Fi's Avatar
Quoted: 16 Post(s)
Sheldon "Oil" Brown
Yep...that's what I do besides adding oil to the hub. That's just part of basic maintenance for that hub.
Sci-Fi is offline
Old 01-24-08, 07:08 PM
mavimao
mavimao's Avatar
Wow, I got Sheldon to answer my question...I feel privileged! :-)
mavimao is offline
