How bad can this be?
https://cgi.ebay.com/ws/eBayISAPI.dll...%3DI%26otn%3D2
I think it looks pretty cool and the specs don't sound bad. But how bad could it really be?
****** (can I say this?)
I dont understand the whole inverted fork thing (Trek 69 comes to mind). The bottom part of my fork gets scratched from when I fall and other stuff brushing against it, so with an inverted fork wouldnt the part that slides into the fork get scratched? Seems like a bad idea to me.
What's "Zoom Rockshox"?
NEW 2008 ZOOM FLIGHT 1000 (BY FOXRACING) INVERTED FREERIDE/DOWNHILL FRONT FORK, THIS IS ONE BOMB PROOF FORK !!!! FEATURES: FOR 26' WHEEL, CROWN PITCH 133MM, ADJUSTABLE PRELOAD WITH TEFLON BUSHINGS, ADJUSTABLE REBOUND DAMPER, HYDRAULIC DAMPING CONTROL, MCU+SPRING+AIR PRESSURE SYSTEM, HUGE ONE PIECE MAGNESIUM UPPER, HUGE 37.5MM STANCHIONS WITH HARD ANODIZATION, AL 6061 T9 TUBE, UNCUT 1 1/8 STEERTUBE AT 10" LONG, "20MM AXLE" , DISC BRAKE ONLY, 2.4KG WITH 120MM TRAVEL !!!!! GET IT NOW WHILE YOU CAN !!!!!! LOTS OF OTHER PARTS IN OUR OTHER LISTINGS) SO CHECK THEM OUT !!!!!! THANKS"
Wait, springs, and MCU, and air? So it's a coil/elastomer/air hybrid? Interesting.
Also, why does it say: NEW 2008 ZOOM FLIGHT 1000 (BY FOXRACING)
But under the brand it says Zoom/Rockshox?
Edit: semi-ninjaed by Benli
Edit, edit: I also dont like that I cant find an official web site for "Zoom".
I think its along the same lines as when people put "huffy NOT kona trek banshee transition foes ect..." so it pops up in more searches.
Umm sorta, I was sorta thinking along the lines of the guy who sells bikes on here under the brand name Neo, but they are from the factory that makes the frames for other companies that can't be mentioned. Its talked about a little bit here
Old School Rad
Bikes: Blur LT
That thing is hot. I'd buy it.
Like a circus monkey on a stolen Harley......
use your best eye
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
ca7erham-
Here's a pic of Maverick's inverted fork with the stanchion guards, you probably didn't know about 'em because you don't see inverted forks that much:
How bad can that Ebay fork be? Probably pretty bad for $135. What do think you get for that amount of money?
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
Bikes: Cannondale Six Carbon 5 and Gary Fisher Wahoo
Te mortuo heres tibi sim?
Bikes: hardtail, squishy, fixed roadie, fixed crosser
to get the same stiffness out of an inverted fork, they have to be made heavier. most inverted forks are less stiff than their similar use and travel non-inverted counterparts.
yes, it's true. poke around a bit and you'll see.
(cue the maverick fork lovers in 1...2...3...)
yes, it's light. it's also leaky, flexy, and has craptacular damping.
Truth be told, the only inverted fork I've ever seen in person was on a trek 69er that was being built up at one of the local shops. It defiantly had no guard thingy on it.
That would have been the dual crown/larger travel Maverick fork. Meh. Better than the singel crown, but not by much. The single crown is...noodly, to put it mildly.
Señor Member
Bikes: CAAD10CAAD10CAAD10
Then they just hadn't put them on yet. Three of the guys I work with at the LBS have 69er SS, and they all have stanchion guards. Well, those that didn't stick a rigid fork on.
