Can't find a creak
Can't find a creak
My road bike has been creaking for some months and recently it became worse. I'm having lots of difficulty locating the origin.
It creaks in all the following situations:
- When pedalling hard while seated.
- "Jumping" on the pedals while standing up.
- "Jumping" on the saddle with the feet outside the pedals.
- "Jumping" on the saddle while hands free.
- When I push down hard (hard enough to make the post flex) on the saddle being off the bike.
- When I push down hard on the top tube being off the bike.
So far, I have greased the headset bearing seats, put carbon paste on the seatpost, lubed the saddle rails, put a drop of lube on each spoke nipple and crossing, greased pedals, cranks, BB and chainring bolts, disassembled the frame and fork (frame is alu, fork is carbon) and inspected for cracks, greased both thru axles and even the derailleur hanger.
Everything I check seems to be OK. Am I missing something? Any idea?
Thanks!
Thanks!
Liked 2,968 Times
handlebar tight?
-Oh Hey!
-Oh Hey!
Liked 2,968 Times
remove the seat with post, what does it do then?
-Oh Hey!
-Oh Hey!
Liked 2,968 Times
leaving the post out along with the seat, remove just the front wheel assembly. Does it still have the noise?
-Oh Hey!
-Oh Hey!
Likes For dsaul:
Clark W. Griswold
Quoted: 4351 Post(s)
Liked 3,989 Times
Have you used a proper torque wrench and check every bolt and made 100% sure everything is properly installed and tightened. Thru-Axles and QR skewers can be the cause sometimes as well.
Make sure you aren't missing something as well. Sometimes a washer or seal or something is gone and can cause some issues.
I also wouldn't jump on anything but you could Jump Around
The only thing I haven't disassembled so far is the pressfit BB. I'm starting to think it may be creaking even when I'm not touching the pedals. Is that possible?
Man I hate creaks - they can be so hard to track down. I really feel your pain.
I'll be interested to hear how that goes. My road bike has a press-fit BB which, so far, hasn't given any trouble, but if it ever needs a new BB I'll certainly consider one of the Wheels Engineering thread-together BBs.
Quoted: 4559 Post(s)
Liked 2,802 Times
Check the wheel spokes too. A couple of years ago after overhauling everything on one bike I finally traced the creak down to friction between black-coated spokes at the crossings. Smearing a bit of wax between the spoke crossings fixed it. I redo that once a year or so. Some folks use grease or oil but wax seems to work better with less mess. An old candle will do, or a crayon.
Likes For canklecat:
Well... this is becoming harder to track. Now it seems it only creaks at "low" temperatures. Inside my home, at 21ºC it doesn't creak.
Outside, at 13ºC it starts to creak after a while (when the bike cools down, I suppose).
Quoted: 194 Post(s)
Liked 204 Times
OK, my penny's worth:
Do you always wear the same footwear, like you are not changing into the same gear to ride it outside?
Have you started to remove major items from your bike, like wheels or forks? I used to have axle stands and large blocks of wood I could stand my bikes on.
However, my bike no longer creaks, because I can blame it all on my knees...
Liked 2,968 Times
Did the noise return again?
-Oh Hey!
-Oh Hey!
Pedals? also is the front wheel tight, is the mech hanger tight?
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,095 Times
I’m not sure of the details on thru axles but I had an elusive creak once that was solved with a drop of oil on the rear dropout.
Clark W. Griswold
Liked 3,989 Times
I already checked (and greased) that.
Everything is correctly torqued with a torque wrench. I have almost disassembled and reasembled the entire bike while looking for the creak.
Quoted: 211 Post(s)
Liked 199 Times
mmmmmm
The OP stated that when he put the bike inside there is no creak. I wonder how many degrees the difference is ?
Example....30 degrees outside......65 inside.
If the OP has " gone thru" everything, except BB, maybe it is just a " warm " weather bike.
Temperature affects everything, especially steel, which expands and contracts with the temp changes.
I hope the OP, the expert help here, can/will figure it out and share
