Go Back  Bike Forums > Bike Forums > Fatbikes
DIY fatbike mud guards
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 12-13-19, 04:27 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
I was planning to order some PDW mud shovels since they aren't expensive, but given that winter opens up to some free time. I'd like to make a few for fun. Planning to use reflector brackets for the the rear and just zip ties for the front. Anyone done this, care to share some advice such as what type of plastic to use or designs?
qclabrat is offline
Old 12-13-19, 04:43 PM
PdalPowr
PdalPowr's Avatar
Bikes: Norco hybrid
Quoted: 287 Post(s)
Liked 26 Times in 19 Posts
Nope,but only because I am having a brain flatus right now.🤗🙄🤗
I had a good idea for fender material last year.
Its gone right now but will reappear when the air clears.
I do like your idea about using a reflector bracket.
PdalPowr is offline
Old 12-13-19, 04:54 PM
PdalPowr
PdalPowr's Avatar
Bikes: Norco hybrid
Quoted: 287 Post(s)
O.K. the brain blockage has partially loosened.🤗😀🤗
Your mentioning mud buckets like the ones below helped clear the air.😉
I was thinking of using polypropolyne windshield washer jug plastic as fender material. Its a little thin so you may have to layer it. Three thicknesses to two thicknesses to one. You may even be able to do two to two to one thickness.
A very good pair of scissors or a utility knife will cut it. If you get it to the right temperature you can make a mold and add a nice curve into it too. Angles would take some practice methinks. Dirt cheap,light and if one does break its easily replaced.
PdalPowr is offline
Likes For PdalPowr:
