Colnago C60 Headset Bearings
The lower headset bearing on a C60 seems to have some sand/grit in it because I can hear some grinding noises while I turn the bearing. Unlike most headsets when you remove the fork and the bearings and cups just slide out, the headset cups and bearings on C60’s are already pressed into eachother at the Acros factory and then Colnago presses the combination into their frame. I was able to take the bottom seal off in hopes of washing out the bearings but couldn’t get passed the second seal which seems locked into the races.
I have decided the best thing to do is just replace the headset with new ones as they seem very affordable (the bottom only needs replacing but I guess they only come as a set). A quick google search turns up these replacement bearings .Would anyone know if this is the only option for C60's? No Chris King or Cane Creek? The bearings on the C60 now which came preinstalled from the factory are Acros branded.
Thanks
Thanks
I recently bought a Colnago G3x and have run into the same issue. The factory acros bottom headset bearing gave out after about a 1500km. I had it replaced by an LBS...not sure what bearing they used but it worked well for about 600km and same issue....gritty etc etc. I just had it replaced by another LBS who used a canecreek top and bottom bearing and its not right at all. The preload is way to tight and if you back it off just a bit its too loose. The steer tube seems to be sitting on the cup now as well. Cant see to find any info anywhere...
Quoted: 836 Post(s)
Liked 1,059 Times
