Who uses those lil' wire TIRE SAVERS?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1084 Post(s)
Liked 1,820 Times
I had them on my old Holdsworth. But they were on both wheels, so scientific method doesn't really apply here.
Then I recently saw some on one of the old Faema team bikes at a museum recently and it was raced with them.
Also saw on a website, some called "Tire Frog brand." They looked light and less obtrusive. Made in USA.
Speaking of which, other than Tire Frogs, nothing is made in USA anymore. I was walking through COSTCO and looked at all the flat screen TVs, most made in Korea or Taiwan.
One said "Built In Antennae" ....... I don't even know where that is!
Anyway, who uses them and who swears by them.
Also
Who thinks its a bunch of hooey.
Also
Likes For Robvolz:
Quoted: 4806 Post(s)
Liked 3,932 Times
They work. Don't do everything but do prevent a fair share of flats from glass picked up by the thread. I used them for decades when I was commuting on sewups and fenders since I could not access the rear tire with my hand. I'd install the rear at the chainstay bridge, pointing down so the defected grime pretty well stayed off the bike. Sometimes I'd just use my hand for the front, other times I'd bend the brake bolt eye the other way and run it under the fender.
Tread pattern is a big influence in how desirable they are. Ribbed treads are nice. File treads less so. Knobbies? Never tried, but no.
Now that I'm going back to sewups on my good bikes and the weather is changing, I'm going to have to consider going back to those glass catchers. Still have a few somewhere. And they aren't hard to make. Plastic tubing and spokes. Never made them from scratch but I "re-shod" the tire element many times with old spokes.
Quoted: 1829 Post(s)
Liked 3,376 Times
Not sure how much it matters, but when tubulars were the standard tire for going fast, it may have been worthwhile.
Steve in Peoria
Likes For steelbikeguy:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
My only flat in the last year:
I was rolling along on tubulars and thought I'd caught some crud in the brake blocks - slight sound once every wheel revolution.
Was about to stop and check when the front tyre went flat.
Found a 1.5mm glass shard 'hammered' into the tyre by me rolling on it. But I'll know that sound next time.
Now using Orange Seal, maybe I should consider tyre savers too.
Quoted: 3513 Post(s)
Liked 2,927 Times
Quoted: 1608 Post(s)
Liked 2,216 Times
Jury is out on effectiveness. No data to pull from.
I have them on the Colnago. Kindo difficult with hidden bolt brakes.
I flattened the loop to turn it into washer like feature then put it under the forward nut.
PA132333 on Flickr
PA132335 on Flickr
PA132333 on Flickr
PA132335 on Flickr
Likes For SJX426:
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
I've never flatted on the ones I use on my '71 Paramount, made by our own, rootboy, may he RIP.
Look closely, and you can even see that they work with loose debris that I picked up rolling the bike to its parking place.
Bob
Bob
Likes For pastorbobnlnh:
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
I have them on my Redcay. I used Problem Solvers Sheldon fender nuts:
That said, I've always found the sound annoying, so have mostly not used them. I recently reinstalled them on the Redcay when I let a friend use it on a ride so he could get the full tubular effect.
Likes For smontanaro:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
I had used them briefly long ago. Any idea of how much additional drag they incur?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
I had forgotten about these things. Any suggestions for how one might rig these up on a tour bike with fenders?
Quoted: 2333 Post(s)
Liked 2,097 Times
I used to use them many years ago when I commuted to college and then to work early in my career. I got a lot of flats back then
I have not had a flat over 7,000 miles but typically have one every 3-4,000 miles on average. So, I see no need for them anymore
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
Those and flick stands...very useful.
Likes For jdawginsc:
Bikes: many
Liked 1,395 Times
A buddy of mine has them on a fendered bike. Can't recall how he mounted one in back, but the front was just attached to a hole he drilled at the front of the (aluminum) fender.
There is no discernible drag with these, nor is there any discernible weight. Basically, no downside, and a great upside of fewer flats!
Liked 2,216 Times
WRT to drag and the sound, you can adjust how far the wiper is from the tire by bending the mounting legs. I set mine so they just clear the highest point on the tire. Figure that is good enough.
you can bend to the curvature of the tire too for covering more than just the center of the tread.
WRT fenders, I have seen some cut the fender around the that area. Weather that works is determined by the distance between the fender and the tire, duh!
Liked 3,932 Times
I never ran my savers off the front of the brake bolt but I like, other than the looks. I used to use the rear nut but orient the saver running forward so the action was right at the front caliper and most of the road junk cleared the brake and missed all the headset. I also always squeezed the contact portion of the saver in to better fit the tread.
And those Sheldon nuts. Yeah! On all my recessed brake bikes.
Quoted: 964 Post(s)
Liked 1,451 Times
I used the tire wipers for a couple years on my touring rig. It had the file-tread Compass "barlow pass" tires. Like Gravelkings and Pari-Motos, basically. I never got a flat, but the noise slowly drove me crazy, so I bent them away from the tires and eventually removed them altogether.
Well, the noise didn't exactly directly drive me crazy. I could ignore it well enough when I was alone, and secure in my belief that they really did something. I was first really made conscious of the noise when I was at French Fender Day and people kept asking me what was that sound my bike was making, to which I had to apologetically reply that they were tire wipers and then have a purely conjectural debate about their utility. Having the same conversation over and over again when there were much nicer things to talk about was what really drove me to remove them!
I commuted on the same set of tires for three years without tire wipers and only recently got my first flat in the back one. For what that's worth! We don't have goatheads in new england, and boston suburbs are crazy about street sweeping (which goes by some draconian schedule that I think is just a scheme to squeeze non-homeowners who are forced to park on the street for parking ticket money). No joke, I heard that somerville pays their entire parks & rec budget with parking ticket money. I guess the side effect is that I don't need tire wipers because they sweep up the glass on the even side of the road on Tuesdays but only when the first Tuesday of the month is an even number, and on the odd side otherwise but that happens on Wednesdays, except when there's a holiday and then it gets pushed to the third Thursday .. I think? I never park there, I just ride my bike through.
Likes For scarlson:
Quoted: 1104 Post(s)
Liked 1,825 Times
I always used a quarter of a yogurt cup wedged in between my seat tube bottle and the cage. But, this thread also reminded me of the "flick stand".
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,928 Times
Someone here, maybe Rootboy? Was making and selling some nice looking ones.
I have some but they don’t seem to be on any of my bikes. Between the rounded wire and struggling to mount them on the short recessed mounting bolt and the tight clearance on the frames, and those lovely Monoplanor brakes I love so much, I just loose patience setting them up.
I wouldn’t have trouble putting them on my Volpe or Project with their canti brakes, but the fenders get in the way.
Oddly back in high school years I believe I had some on my old Royce Union.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 96 Post(s)
Liked 292 Times
Ive had them save my tires. With no sound. Nor should there be ANY drag. You adjust them so they don't rub. Just off the surface.
I’ve seen them remove glass and other things from tires before they had a chance to be embedded deeper the second time around. They truly are
tire savers.
I bought a 73 Nishiki that has them on it.
tire savers.
Liked 3,932 Times
