Gatorskin vs. GP 4000 Height
Old 11-17-18, 06:34 PM
Davednconfused
Hi -
I've been searching around but haven't found any conclusive information. Maybe I'm looking in the wrong places?
Everyone claims that Conti tires run large. Additionally, I own a 2012 S5 which all owners will know was made for 23 width tires.
However, I am currently running 25mm Gatorskins on them. They're old and worn, but they fit perfect. No rubbing (anymore). I also have brand new cheap Conti Ultrasports in a 23 that I use on the trainer, and those don't even come remotely close to rubbing.
Are GP4000s a good amount taller than Gators? Definitely don't want another set of lead tires.
Davednconfused is offline
Old 11-17-18, 08:12 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
Yes the GP4000 II S's typically run large. My 28mm's measure 32mm wide which is great if you have the clearance.
Elvo is offline
Old 11-17-18, 10:26 PM
dvai
Quoted: 106 Post(s)
Liked 4 Times in 4 Posts
They do run large. So be careful if you have limited clearance.
dvai is offline
Old 11-19-18, 09:10 AM
Afdica
GP 4000 II S 25mm did not fit my 2012 Cervelo R3. The back was tight and the front tire did not clear the crown of the forks.
Afdica is offline
Old 11-19-18, 11:19 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
Originally Posted by Davednconfused
Hi -
Wow....that is close!
jadocs is offline
Old 11-19-18, 02:59 PM
Davednconfused
Decided to just give it a shot. GP4000s are most definitely taller than Gatorskins. I tried the 25mm and they would have fit, but it was even closer than this. Way too close for my liking. I got 23mm's instead, since they'll fit more like a 25mm anyway.
Old 11-19-18, 03:06 PM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
uh are those chunks of CF missing from the seat stay?
redlude97 is offline
Old 11-19-18, 10:06 PM
Davednconfused
Figured someone would mention it. Yeah, probably. It’s fine. The inner arches get chewed up all the time. At least if they actually get ridden.
novemberhotel
Road Cycling
17
11-18-17 11:59 PM
maartendc
Road Cycling
7
08-04-17 02:53 PM
scuzzo
Road Cycling
61
04-19-16 08:04 PM
lawnchair bes
Road Cycling
11
09-12-14 12:06 AM
titani
Road Cycling
1
10-19-13 08:14 PM
