Light pedal or free-spinning pedal?
Quoted: 1562 Post(s)
Liked 1,734 Times
On my current bike I have Wellgo MG-8 SPD pedals, which are pretty light at 240g /pair, but they are plain bushed and feel like they are riding on molasses.
For my other bike I am thinking of going with pedals with ball bearings. But I notice they tend to be heavier. The Ultegra 6600 SPD pedals for example weighs 340g. Which is more important? light weight or less friction?
Expired Member
Quoted: 3674 Post(s)
Liked 5,432 Times
You won't notice the difference in weight or bearing type. You will notice a difference in SPD and SPD-SL, aka "road" vs "mtb" style.
Quoted: 645 Post(s)
Liked 797 Times
As I understand it, you don't want pedals to spin super-freely - you want them to be sufficiently free for hang down, so they're easier to get your cleat into, but not so free that they start spinning if you miss the first go. I degreased my very old Ultegra SPD-SLs last year, but I don't believe there were any ball bearings in them - I think they were all bushes
Quoted: 1743 Post(s)
Liked 1,281 Times
Speedplay Zeros have worked well for me for close to 20 yrs.
As others have said. Weight and friction are pretty negligible. Float and surface contact are usually the big factors in selecting pedals for me. Making sure there is enough “play” from float to accommodate your knee/ankle anatomy while spinning will give you more benefit in the long run.
Quoted: 1814 Post(s)
Liked 923 Times
I used those or like that for a while, & AIR they were so light that they didn't hang consistently,
making clipping in more of a bother.
I think those have roller bearings, & cleaning & regreasing would likely make them spin nicely.
More float is only better if you need it. if you have no complaints about your current 4˚ cleats, more float is not likely to feel like an improvement.
it’s really dependent on how much lateral movement your knee has through the stroke. Don’t get too technical about it and any float is better than zero. Then again some people are completely fine with zero and others develop knee problems. You should be good
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
I'll take free-spinning over lightweight every time. That's independent of retention systems, (which I mostly forgo).
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
+1 for free-spinning. Depending on just how like molasses your current pedals are, there's a good chance you actually will notice the difference.
