Newbie Question on rim brakes.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
If you ride a bike with rim brakes long enough, will you eventually wear through the rim itself?
How many miles does that take?
I could see that being an advantage if you wanted a -forever- bike, just change pads and rotors.
Quoted: 20810 Post(s)
Liked 9,456 Times
Depends, but a lot.
Well, it's still the same bike if you change the wheels, innit?
Likes For WhyFi:
Quoted: 2604 Post(s)
Liked 1,933 Times
Likes For pdlamb:
More interesting, perhaps, is the number of sets of pads one would go through before the rim would be considered worn out.
Likes For Reflector Guy:
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Ok. Thank you.
So if I’m coming up on 40. Full time job. Don’t commute on a bike. And only started getting back into bikes to ride with my kids- I’ll never wear out rims through braking.
If I want a disc brake bike for other reasons that’s a different subject.
Do disc pads last longer than rim brake pads?
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Ok. Thank you.
Otto
Likes For ofajen:
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Yes. No. Maybe. How long a pad lasts depends on how often you use them. That goes for disc pads or rim brake pads. People have posted here on the Forums that they have to adjust their brakes after each ride. I can’t remember the last time I replaced a pad (of any kind) because it wore out. I’ve never adjusted a disc pad for wear. It all depends on how you use your brakes. If you latch on the brakes at the top of a hill and drag them all the way to the bottom, you’ll wear the pad as well as the friction surface (disc rotor or rim) more quickly. If you pulse the brakes on a down hill...hit the brakes hard, slow down, get off the brakes, rinse and repeat...you won’t wear parts out as fast. You also won’t heat up rims and/or rotors as much either.
Stuart Black
Stuart Black
Quoted: 6199 Post(s)
Liked 4,816 Times
All the other comments are spot on. I just had to rip you on -forever bike.
Do you really want to be riding the same bike forever? Are you going to be happy foregoing all the improvements (arguable in some cases) that 50 years of cycling will bring?
Wheels will be an expendable item if you ride enough miles. I've never really ridden one bike enough to wear out the rims. I've got some that are close, but then I stopped riding that bike because newer bikes superseded it and were more fun to ride.
As for how many miles that might be, I don't know, the bike with the almost worn out rims is of unknown history. But it's a lot more miles than most will ride. If you wear the rim out, then be proud, post a pic and I'll clap for you. I'm sure a lot depends on how much you have to brake.
Quoted: 1062 Post(s)
Liked 665 Times
Anecdata here: Family fleet of bikes, used daily for commuting and around town plus weekend recreational rides. In my entire life I've replaced exactly one worn-out rim, and it was on a bike being used year-round in a particularly gritty area by a rider who was only using the rear brake and neglecting its adjustment.
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
I don’t ride bikes enough to wear a bike out.
Joined the forum to learn stuff because now my kids ride.
If they really get into riding, we all might upgrade from big box store bikes to LBS bikes and get fitted.
I pulled the springs out of my big box MTB fork and welded the stanchions together. Will probably do the same for my firstborn until we get different bikes.
The failure is an extremely gnarly blow-out. The failure of the rim sidewall generally causes the rim's hook to separate from the rim base along a section. The tire finds itself no longer laterally contained by the rim, so it blows off. It sounds a bit like a gunshot.
The big exception is if you're living somewhere where the regional gunk eats bicycles. Some people in the PNW burn through rims in just a few thousand miles if they're riding in wet conditions.
Sunshine
Quoted: 10971 Post(s)
Liked 7,498 Times
Consumables are consumable.
Brake pads, rims, rotors, handlebar tape/grips, tires, bottom bracket, cables and housing- all of that is meant to be changed as it wears.
Quoted: 645 Post(s)
Liked 797 Times
there’s really no such thing as a “forever bike” if you actually ride it. Almost everything bar the frame set is a “wear item” - some items simply wear slower than others. I’ve ridden the “same” bike for ~18 years/60,000 miles. However, I think only the frame, headset, seat post and one shifter are original - things wore out or I upgraded stuff as better versions became available. Wheels (rims) are one of those wear items. People who commute in bad weather will tell you they go through rims every couple of years. In contrast, I used the same wheelset for ~55k and there was still >1mm of brake track all round. I only replaced them because I wanted something a little blingier, but they’re still a perfectly good backup wheelset. If you ride in mainly decent weather and clean the rims/brake pads regularly, Al rims will last for decades
yeah, that would be a LOT of miles! By that time, your bigger problem would likely be spoke nipples (difficult to turn). You would have ridden so many miles by that time.......keep riding!
Liked 9,456 Times
Quoted: 581 Post(s)
Liked 921 Times
If ridden in wet and dirty conditions (like a commuter bike) and cleaning of rims and brake pads is infrequent, you could possibly wear the sidewall of the rim thin enough that it cracks in a season or two. I have had one rim worn so far that the pressure from the tube split the side. Another wore down enough that it was starting to break and the spokes were losing tension and the rim would not stay true.
Disc brakes are the perfect solution for this, but regular cleaning of the braking surfaces is a decent preventative.
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
It is possible, yes.
Depends extremely heavily on the context. What conditions you're riding in, what rims, what pads, your maintenance habits. In most cases, tens of thousands of miles.
If rim wear is an issue for you, then yes, disc brakes can be nicer to deal with. Or, alternately, they can remove a reason that you weren't using nice rims.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Liked 4,816 Times
When it's worn out, usually on many of the rims today, it'll look like a depression in the braking surface of the rim. Simply the outer wall of the rim getting thin and beginning to collapse. Some have wear indicators.
(Obviously you should replace a rim long before this happens.)
I don't know if I've ever heard of anyone having such a failure, unless maybe a high dollar carbon which I'm not into yet.
I've been in the room when it's happened, but I also live in the Seattle area where we have rim-eating road grime. Even here it's a pretty rare occurrence.
Likes For HTupolev:
Liked 9,456 Times
One of my clubmates had his (aluminum MTB) rim explosively blow out on him a few weeks ago - a combination of thin brake track and a poorly-timed bunny hop.
Liked 4,222 Times
Theoretically, yes. In practice, seldom. The ones I have worn through have failed relatively slowly. I’ve even had strips of the rim fracture off and the result was just a pulse at the brake lever. Most of the time, however, the rim just splays out due to the pressure the tire puts on the rim.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 1821 Post(s)
Liked 1,697 Times
I once had a steel rim on a Raleigh 3 speed bike split right down the middle of the spoke bed. The rim simply rusted through from the inside. The bike was ridden several winters on snowy salted roads. Not a spectacular failure, the rim split slowly and the wheel turned mushy. Was able it ride it most of the way back home
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I think a far more common problem no one talks about is a rotor warping. You can true them yourself and rotors are cheap but it does happen.
Liked 9,456 Times
Yeah, it happens, but it's an incredibly minor issue that's straightened out (ha ha) without much time or effort. The Shimano IceTech rotors, in particular, are super easy.
Likes For WhyFi:
