Noisy Hydraulics Cause?
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
Hey Guys,
Bike is a few weeks old. Discs has been tweaked already. They are 2010 Formula RX hydraulic disc brakes.
Front Brake (Hard stop): Brakes make a grinding sound (as if there were no pads installed) + squealing.
Rear Brake (Hard stop): Brakes make a sqealing sound.
Any ideas?
Any ideas?
Quoted: 5790 Post(s)
Liked 2,581 Times
Regardless of whether these are hydraulic or mechanical disc brakes, it sounds like grit imbedded in the pads. Sometimes it works itself out others you need to clean the pads.
Given the age of the bike I assume it's still under warranty, so let the folks at the LBS service both brakes, and have them give you a few care and sevice pointers for the future.
FB
Chain-L site
FB
Chain-L site
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
Went to my LBS today. Both mechanics use the same model brakes and both complain of the same sounds...they've tried everything, and they believe its just how the Formula RX's are.
With that being said, we did use some rubbing alcohol on the rotors to clean them. I am hopeful my braking power will return soon.
Its all in the PADS!!!!!!!!
I had put some new metallic pads on my XTR M970 dual controls and were they CRAP!!!!!!!!!
They were so lousy I could hardly get my front forks to compress even a little when braking, and a death grip
on the front or back brakes would not lock the wheels. The last 3 feet of stopping produced a squeal that would
scare car drivers, and if they got wet they would SQUEAL constantly (I was embarrassed to ride it). I had no trouble on my XTR M960
set up so I thought maybe the 970's were the problem,I chamferred the edges of the pads and added no squeal compound to the back
IT DID NOT HELP.
As a last resort I bought XTR M07 resin pads, and they are a dream Super strong super quiet, a pleasure to ride.
If the advantage of metallic pads are they last longer, who the H*** would want to have crap brakes for twice as long.
IT DID NOT HELP.
