Rivendell seems to have changed
#52
One of the things Rivendell does right is to offer bikes with wheels that are more proportionately sized for the frames. 559 for small frames, 584 for slightly larger frames, and 622 for the largest frames.
GP long tried to get a new tire size built with a bead seat diameter of 603mm. He could get the rims built but not the tires. I wouldn't be surprised if in a few years one of the big players announced the new ideal tire size, 603mm.
#53
Quoted: 38 Post(s)
#54
Quoted: 18409 Post(s)
Liked 15,530 Times
The LHT has 46" stays. So does the Disc Trucker. ECR 29+ has 45.1" stays. REI has at least one touring model with 45.5" stays.
#56
Liked 15,530 Times
Likes For indyfabz:
#57
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
I think the Rivendell/Jones comparison is apt. Both companies are reflections of their respective owners, who are definitely iconoclasts.
Rivendell reflects an older sensibility while Jones is more modern but both go their own way.
I have a Riv Atlantis -one of the older Toyo manufactured frames - and a Jones Plus. Both are great bikes, comfortable to ride and fairly versatile, but not interchangeable. I hope Rivendell can keep going and I wish Jones further success. I think all Jones stuff is Taiwan produced.
I've talked to Grant on the phone, and Jeff in person, both are friendly and easy to talk with and both seem to have a mission to change, maybe in small ways, the cycling world.
#58
"Peterson outright rejects things that are pretty clearly "better" for most riders: indexing, STI.." I disagree with the statement on indexing and STI. Just don't see how they are better for most riders. I just built a commuter bike for a 25 year old kid using it to commute with. Set it up with friction thumbies for absolute reliability. Once set, they never need adjustment. Once the movement of the lever is learned there is no reliance upon the adjustment to get to the next gear. I see this as better for all riders.
#59
I don't disagree with you, in that Rivendell bikes are fairly unique. Still, the Specialized AWOL, that company's most Rivendellesque bike, is pushing 44" in the larger sizes.
While Rivendell occupy a singular niche, to quote Jan Heine, "When Bridgestone USA closed in 1994, many mourned the loss of what they saw as the last bastion of sensible design in the quickly changing world of bicycles. They rejoiced when later that year, Bridgestone’s marketing manager Grant Petersen started Rivendell Bicycle Works. ... Everything that followed – the steel bikes from Surly, Soma, All City, etc.; the renewed popularity of handbuilt custom bicycles that since has swept the world; the comeback of classic components; even Compass Cycles – can trace its roots to the moment when Grant Petersen stood up and said: “I love steel and lugs. Why not?”"
Grant's ideas have been instrumental and have informed many of the designers producing "adventure" bikes. The tire clearance, fenders, racks, relatively low gearing and geometry of my Specialized AWOL all owe a big debt to Grant Petersen's ideas (although he would probably be able to write a compelling and well-crafted article against its disc brakes). While you're right, in that Rivendell bikes are fairly unique and no one else is making bikes just like them, I am appreciative of the fact that Grant's ideas have spread and have pollinated other minds.
#60
No disc, 1" headtubes? No interest for me.
#61
Sunshine
Quoted: 10955 Post(s)
Liked 7,483 Times
#62
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
Sure, like that. Grant's ideas probably influenced Surly, as evinced by the Jan Heine quote I provided. The LHT isn't a clone of the Atlantis, as some have claimed, but the general ethos of Surly is not without the influence of Grant Petersen's ideas.
#63
1” headtubes were a great standard for years, and still are. There really wasn’t a good reason to change except for marketing (IMO). As for disc brakes, I can stick with rim brakes. Simple, effective and they give me more wheel options (radial spoking for example).
#64
Quoted: 233 Post(s)
Liked 165 Times
https://cyclingtips.com/2017/08/orig...bikes-forever/
#65
Quoted: 38 Post(s)
I think you mean cm, not inches. Those bikes in your examples are about as long as you’ll find, and they still don’t match what Rivendell is making. The mid sized Clem Smith Jr, for example, has chain stays of 52 cm, and there are Rivs with stays as long as 56 cm. On a bike like the Clem Smith Jr, that means that we’re looking at a wheel base of 117 cm on the model I rode while the LHT has wheel bases in the 105-108 cm range.depending on size.
#66
1" might be good for road, try loaded touring or bikepacking with a big guy( me) and a 60 lb bike or so. I dislike rim brakes for rain, mud and winter rides, way messy. Wheel options? Like plus and fat tires? Only disc with those. We'll see how Grant weathers the storm, if at all.
#67
Compass cycles has a $40 a year Quarterly magazine VBQ
they promote their stuff in ... That cult devotees quote from every issue..
#68
Quoted: 3236 Post(s)
Liked 2,080 Times
This has been discussed to death, but the Aheadset design is an improvement over the 1” threaded. MUCH easier to get adjusted, easier to change stems, which makes fitting easier. Getting the 2 locknuts of a 1” at the correct tension took some experience, but once you learned it you never really had issues.
Still, it’s been 25 years ?, since the threadless design took over and I’d rather deal with a Soma, etc.... that uses 1-1/8” then a Rivendell with 1”, so at some point you just deal with the fact (as a dealer/manufacturer) that a standard is a standard for a reason. You reject that standard at your own peril.
#69
Quoted: 233 Post(s)
Liked 165 Times
#71
Sunshine
Liked 7,483 Times
the tubing has been plenty stiff and i cant say i want wider tires than the 37mm ones on there.
I get people not liking canti/brakes, but even those are fine for me, but I rarely ride in the rain for more than a few hours due to how i tour.
to each their own and all and all choice that are thought put are cool. Just posting this as a balance.
#72
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
I've owned 4 Rivendells, (Atlantis, Roadeo, Sam Hillborne, and an Appaloosa which has become my favorite bike ever) and can say that they are not sluggish or slow bikes. Very neutral handling, not twitchy and not slow turning, even with loads and move when I put power to the pedals. The framesets are quality made, and I can see that when I take the bike down to the bare frame to change it into some other configuration yet again. You can tell someone designed it, put it together, built it with a lot of care. I really think they are some of the best bikes being made today.
It's rumored Grant is coming out with a new model, which will be his version of a mountain bike, with threadless headsets (on and mtb I do prefer threadless over threaded, but touring or roadie I prefer quill), canti bosses, and of course the new long chainstays. I'm very much looking forward to it. It won't have disc brakes but I still ride my '96 Stumpjumper with cantis and haven't had braking issues. If Velocity keeps producing rims like the Cliffhanger, rim brakes aren't a deal breaker for me....the reality is that I wouldn't ride a Rivendell in the same manner I ride my Santa Cruz.
Rivs aren't for everybody, and I don't think Grant and company would ever say they are making bikes for the masses or are following trends just to follow trends, but they do a good job making bikes for those of us who aren't racing, don't pretend to race, like to carry stuff on our bikes, like to wear regular clothes when riding sometimes, like to tinker on their bikes, and see the value in sticking a $24 rear derailer on a $1500 frame that happens to have Paul Component cantis and friction shifting.
It is my understanding that Riv has never been shy about selling bikes made in Taiwan and many of his frames are built over there. You can still get the American built ones like the Roadeo and the American version of the Atlantis with the shorter chainstays, but it takes a phone call to them and the prices have gone up over time...quite a bit, actually. My Taiwan Rivs don't ride any worse than the American ones I've had, so I really don't see the value in paying more for that. The Taiwan bikes are priced right, IMHO.
#73
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I dunno.
I am a year round commuter, long distance tourer and basic all around bike guy and I don't always think those things are better solutions (even though I use a mix of them for various applications). I would say most people don't even know different and are attracted to new tech for a bike they ride a handful of weekends in the summer and are completely dependent on the lbs for guidance and servicing. Most wouldn't know how to adjust indexed shifters or disc brakes and have bikes so expensive they dare not try anyway. While clipless is great for longer rides they require two shoes for local commuting etc unless you want to walk around in cleats which some places don't even allow in the door... Not everything new is better all the time.
I think Grant gets it that for a certain class of people what is needed is not a CF go fast tech advanced bike but rather a simple, dependable, reliable, understandable machine. I get that too as I regularly rebuild bikes and enjoy something I can completely strip and assemble/service myself. From an aesthetic perspective I also like the classic look.
One can suggest Riv owners are posers but from what I see on the weekend scene that also extends to a lot of new road bike owners as well - most of whom do not look remotely fit enough to need the advanced technology they are riding.
#74
smelling the roses
Liked 901 Times
I redeemed my giftcard, plus an added, free giftcard just this week.
#75
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
Oh Snap.
1337 p0wned.
LolZ0r.
Commence to jigglin’ huh?!?!
