New throttle without lock doesn't work
Hi! I broke my old throttle which had a key lock and i bought the same kind of throttle but without a key lock. The problem is that it had 5 wires and the new one only has 4. So now i have one unconnected wire that went to the key lock and the throttle doesn't work. If anyone knows what to do i would appreciate the answer very much. Thank you.
Quoted: 883 Post(s)
Liked 823 Times
Not the best solution but can you hook up the old throttle's key lock wire to the controller? If that works, try to simulate the connection by grounding the wire or whatever.
