Help a touring guy find a light comfy gravel bike
I'm heading for retirement and considering treating myself to a light and comfortable all purpose bike. That led me to gravel bikes of which I know little.
I'm a C&V guy with an assortment of mid 80's pretty top end touring bikes that I ride for recreation and an occasional tour. My knowledge of the new bike tech hasn't advanced much beyond STI levers. Based on some online perusing I've found the Cannondale Topstone Ultegra RX or RX 2 and Specialized Diverge Comp as viable options. I'm certainly not locked into those so other options would be appreciated but I know when this COVID-19 ordeal is beyond us I will likely be able to find those to test ride locally. I've never thought I'd spend this amount on a bike but I guess I'm looking in the $2K to 4K range.
Criteria:
Light - I don't own or have ever ridden anything under 23 lbs so I'm hoping to find a sub 20 lb bike. My touring bikes give me all the comfort I need but cutting about 10 lbs off the ride would the main reason for the purchase. I'm thinking carbon is a must to get to this weight range but am not opposed to aluminum at a similar weight.
Comfort
- as I age I like more height on the bars so help me out with something with higher stack height and upright positioning. I ride in the drops some but don't want a ton of hand pressure when riding on the top.
- I'm a fan of wide tires but some type of additional vibration reduction would be nice. Probably more on the bar/hands unless they are up high enough.
Utility - I know it defeats the weight criteria but the ability to add a rack for lighter touring or just extra gear is kind of a must. Fenders would be nice but probably not a deal breaker. Unless I'm touring or get caught in a shower I generally don't ride in the rain.
Quality - I want a bike the company will stand behind and I have access to parts/service. At 66 the number of years and miles I'll be putting on it shouldn't be an issue with the longevity of the wear and tear of most parts.
I would greatly appreciate any suggestions based on experiences with the couple I'm considering or what you may suggest. I have a 2004 Specialized Sequoia with Shimano 105 and find the components fine but if anyone feels Ultegra is well worth the upgrade please let me know also.
Thanks in advance for helping me find a ten pound lighter, wider tire version of my 84 Miyata 1000 :-)
Criteria:
Comfort
Nothing compares to the simple pleasure of a bike ride - JFK
Quoted: 1872 Post(s)
Liked 692 Times
I'll throw Salsa Warbird out there as a bike that fits the bill.
2019 Salsa Warbird
2019 Salsa Warbird
A few threads ago there is a discussion on carbon bikes which can take a load. In the reading there you'll also find a CyclingAbout link to other models.
Quoted: 3238 Post(s)
Liked 2,085 Times
The Cannondale carbon frame has a rear wheel dish that is not standard, has to do with the rear suspension system. If you desire longevity, maybe don’t go with a frame that uses a proprietary suspension system such as the Specialized or carbon Topstone. Maybe go with something that allows larger tire sizes, 45mm or so and maybe a carbon bar, stem and seatpost to soak up a bit of shock.
Lots of bikes, Giant, Trek, Ibis, Niner, Salsa. Also maybe aim for a bike with GRX, allows greater option on the rear gearing to 46 on the cassette, as well the crank will be 48/31or 46/30 which would be a better choice than a 50/34.
Likes For wheelsmcgee:
Gravel Rocks
Criteria:
Comfort
Criteria:
Comfort
You might like a Lynskey gravel bike. They have had a long sale at 30% off. Gravel
Gravel Rocks
Quoted: 1221 Post(s)
Liked 629 Times
If you're considering the Carbon Topstone I'd go with the RX2, it has the aluminum wheelset vs carbon. I've read a few reviews about the carbon wheelsets on the RX needing to be trued regularly. The Topstone frameset isn't the lightest out there either. My Carbon 105 weighs roughly 25.5lbs ready to ride; bone stock and setup tubeless, with one full water bottle, empty seatpack and 1lb front lamp+battery.
The Carbon Topstone is also fairly "racey" with a 61mm BB drop. It fits and acts like a road bike, very nimble and responsive but still very stable on the decents.
I think a more mtb oriented machine like the Warbird, cutthroat would be nicer for laid back touring. The Niner as well has much more stack vs reach.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 2,085 Times
What I was thinking. I weigh without rear bag, tools, lights or computer and certainly not a full water bottle. My aluminum Topstone 105 is 22.6 lbs thus, with SPD pedals.
@wheelsmcgee - what does your Warbird weigh? I can't seem to find any weight info for Salsa bikes anywhere. It is a nice looking bike and good suggestion as well as the Cutthroat.
Thanks to all for the good comments and recommendations.
Liked 692 Times
Thanks - good info. I took a beating on a gravel/road tour in Idaho a few years ago on my Specialized Expedition with 38mm tires and wider is definitely in the cards for me.
2019 Salsa Warbird
2019 Salsa Warbird
Unless you're hooked on carbon you may want to try the Specialized Diverge Comp E5.
I have one and just am wowed by the Future Shock feature. It does make daily rides a lot
easier, taking the bounce out of small road ripples. It has the latest Shimano 105 features
including hydraulic brakes. It sounds like you already somewhat satisfied with Specialized products
and may even have an LBS that could give you a bike to try out.
I'm kind of locking in on the carbon GRX 600 versions of Warbird with 650b, Cutthroat, or Diamondback Haanjo EXP as my main options based on tire size and gearing. The Diamondback is in the mix because of the 21 in. stock low gear but the mechanical brakes are a negative. I'd like to wind up around 20 gear inch ideally but with the GRX 810 RD on both Warbird and Cutthroat I don't think I can get much below 24. Any comments on people that have gotten lower would be appreciated!
I don't know if something like a Wolftooth Roadlink was used but I did see something about a 46/30 crank and 11/40 cassette working on the Warbird. If so that would get me to a 20 GI.
Can you order the Warbird from a retailer like REI with 650b as a delivered option? I'm wondering how much they would be willing to swap out and avoid purchasing a second set of wheels.
Liked 692 Times
Are you running 700c or 650b?
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 353 Post(s)
Liked 92 Times
I'd go with the cutthroat. It's made to haul and go for the long haul while still being light. You might find the Warbird too racey as it is their gravel racing bike after all.
Quoted: 101 Post(s)
Liked 41 Times
Coming from a steel touring bike, it seems light as a feather. It’s the only bike I own that I can easily grab by the top tube and flip up over my head and onto my garage ceiling bike hooks!
Likes For shoota:
Well I thought I'd update all of you who gave me some great suggestions and information.
As much as I liked the Cutthroat with the higher stack height I opted for the Diamondback Haanjo 5C EXP. If I had fewer bikes I might have been able to justify double the price for the Cutthroat but as it stands the $1739 for the Haanjo was a great value that pretty well checked all my boxes. If times were different and I could have tried out the Cutthroat maybe I would have felt differently.
So far with a couple rides and about 50 miles on both pavement and gravel I'm very pleased. It handles great, rides quick, and is comfortable. The lower bar height than my other bikes doesn't seem to be an issue and I have the impression I'm riding pretty upright. I guess if I have future issues I could go with a stem with more rise or a stem extender.
It has quality components and I really like the WTB Byway tires. It didn't bother me on the first ride but after the second ride the saddle just wasn't as comfortable after some distance so I put my Brooks B17N on it. I wish it had additional fork mounts and maybe the top tube bag mounts. My gear should I decide to use this bike for touring is all panniers so no issues with missing the other frame bag mounts.
Anyway at this point I'm happy with my choice and would highly recommend the bike. A great price point for a quality bike to get into gravel riding.
Liked 629 Times
Wow great setup and killer price! I immediately switched my saddle before I left the store, I wonder why they even spec saddles on bikes. For me the saddle on my Topstone was the exact model I had ridden and didn't like, so although I was a pretty good buyer I got a little pushy on swapping saddles immediately
Post some pictures
Post some pictures
I don't have a picture after the saddle swap but this is how it came stock.
