Cheap rear rack for vintage road bike
Anyone have any suggestions for a cheap rear rack for an 80s road bike? All the local shops are closed here so was hoping there may be a good online recommendation (for Canada)
Thanks!
Thanks!
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
I like round stays better. They have more adjustment and are easier to mount. The Sunlite Gold Tec Lite is a good rack. Racktime Foldit is a good rack. The Racktime Standit is a bit better because it is welded. It’s also a bit more expensive. The Racktime racks are Tubus racks cheaper brother. If you want the ultimate, look at Tubus. They are the heirloom quality racks, expensive but worth the extra money. The Vega is an excellent rack for a lighter rack from Tubus that is still capable of carrying more weight (55 lb) than the all the other racks I’ve linked to. If you need to carry up to about 90 lbs, the Tubus Cargo is the best rack around but that’s overkill for everyday use.
Stuart Black
Stuart Black
Liked 4,219 Times
I really question that capacity. I trust Tubus’ numbers and they list the Tubus Vega’s capacity at 55lb for a steel rack. It’s far stronger than aluminum racks. There’s a lot of inflation and bogus numbers on rack capacity. Axiom lists their rack capacity at 110 lb which is far too high.
Stuart Black
Stuart Black
