Does grease kill a rim brake pad?
If you get grease on a rim brake pad is it ruined? I just heard that it is, that nothing can save it. I never knew that. I'd think you could just wipe it off and wash it then use it a bit and it would come around. I assume that I've gotten WD40 and other lubes on my pads before. Hmmm... never knew grease could kill a pad. ??
Quoted: 4197 Post(s)
Liked 3,849 Times
Agree. There's so much road contaminate of the liquid type that drips off cars and trucks and the rims are so close to the road surface that if this was a real issue it would have been made known a long time ago. I've worked in shops that clean the repairs with WD40, rims and all. Their customers were able to stop and their pads didn't seem to be bothered long term by this cleaning.
What's motivating your to question the pads and grease? Of course if you lube the braking interface the friction will drop down big time for a little while at least. But cleaning with a true solvent removes any lube and pretty much restores the friction. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1818 Post(s)
Liked 1,693 Times
Rubber based rim brake pads have a pretty good tolerance to being rehabilitated after having been exposed to greasy contaminants unlike disc brake pads. Clean them off using a product that doesn't leave an oily residue and they will be fine
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,211 Times
Disc brake pads are a phenol/formaldehyde resin that is also sintered. That means the pad is much more porous. Grease that gets into the pad gets sucked into the inner part of the pad and never really wears off. You can use solvents to remove the grease from rubber but solvents would just drive the grease deeper into the disc pad.
Stuart Black
Stuart Black
Quoted: 836 Post(s)
Liked 1,060 Times
Agree with all the previous posters. It may be a problem with some pads and using them on a mountain descent on a hot day but if cleaning the pads and rim doesn't work just sand down the pad surface to fresh material.
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
If you REALLY want to be sure there's no residual contamination, do this:
1. Wipe the brake pad off with liberal amounts of isopropyl alcohol on a clean rag.
2. Sand or grind the surface of the brake pad enough to expose fresh, unadulterated (UV light, ozone) brake pad compound.
This advice applies best to road or cantilever pads with adequate material. "Slim" v-brake pads may not apply. This DOES NOT APPLY to any disc brake pads!!!!
I sand or grind brake pads when servicing bikes. Easiest way to renew the pads to as "new" a condition as you can.
This, however, assumes there's enough material there to start with. AND that you do so sensibly. Make sure the surface stays flat and perpendicular to the mounting post/bolt. And that you preserve any "pre-toe" the pad may have (KoolStop). Observe and heed any "maximum wear" lines that may be printed on the pad.
If you can't do this to a pair of pads because they have so little remaining material left, then they're too toast to use in the first place.
Use this advice only if you know what you're doing.
