School me on bearings
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
I am about to start tearing apart my bottom bracket on my 1985 Specialized Sequoia and was wondering what
bearings to get.I know I need to get the same size but is there a certain material or brand I should look for?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Who manufactured your bottom bracket?
The dropped
Liked 1,014 Times
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 206 Times
If you want to utilize the bottom bracket you have and want to simply overhaul the bearing, then you need 1/4" grade 25 (or better) replacement ball bearings and good waterproof grease. Do not reuse old ball bearings if you can avoid it. Plus, the old ones were probably grade 100 or worse, so the higher grade replacements will result in longer life and smoother operation.
This, however, assumes the spindle bearing surface is not pitted (or worse, the cups). Given its age, I'd be surprised if it weren't - unless you've taken really good care of it.
And IF you plan to utilize this type of bearing (considered "non-cartridge" BB), you may want to have the BB shell faces milled flat and parallel. Chasing threads isn't a bad idea either, however, a small round wire brush on a drill will clean up the BB threads beautifully.
If you simply want a durable replacement bearing and don't want to deal with potentially expensive frame prep, then just replace it with the appropriate Shimano UN55 BB. Cheap and long-lasting.
To match what you have, you have to get the correct two dimensions: BB shell width (68, 70 or 73mm) and BB spindle length. Taper has to match also, but almost all are JIS, I think. (This has always kinda eluded me, I'm embarrassed to say! See Sheldon Brown, which doesn't even mention Campy... https://www.sheldonbrown.com/bbtaper.html)
Did I help or just confuse you?
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 279 Post(s)
Liked 206 Times
Ha! That's pretty funny you mention "Specialized Sealed" because I just happened to pull the Specialized titanium bottom bracket out of my city bike. Finally decided to retire it after about 20 years. Finicky BB prone to wearing out cartridge bearings prematurely. Sick of clunking & slight chainring wobble. This is the one made by White Industries, branded Specialized. It most certainly isn't the one you have. I replaced mine with the aforementioned UN55, 68 X 122.5.
Thinking of putting it on Ebay. A nice vintage lightweight BB, but not idiot-proof or very durable.
Quoted: 283 Post(s)
Liked 262 Times
Here are some specs on yer bike:
1985 Specialized Catalog
Get a caliper and take some measurements of the axle length, how far it sticks out of the drive side, and the width of your BB shell, etc. There are probably some codes engraved into the old one. Give us a full report with pictures and someone will be able to point to a modern BB that will work. Some model of a Tange LN-3922 or Shimano UN55 will probably fit. This may be the type of tool you'll need:
https://www.parktool.com/product/bot...ttom%20Bracket
If you have a cup and cone bottom bracket, the bulk of these used bearing retainers. While I generally like loose bearings, this is one place where bearing retainers really make life easier, and I'd recommend you get a full replacement if this is what you have.
Really though, cartridge BBs last incredibly long, are easy to replace, and are cheap and I would generally always err on replacing with one unless the original is especially high end or collectable.
