Experience trying road bikes
I currently been riding a hybrid bike , but n+1 has been calling and wanted to try /buy road bike.
after trying several, the issue I’ve been having is discomfort in the privates area. I was told that bike shorts Would help, but I feel it shouldn’t be that way.
do you recall when you first tried road bikes , how did you get past this if you had such issues ?
Quoted: 3289 Post(s)
Liked 2,122 Times
I was never planning on riding in blue jeans and underwear. I always assumed padded shorts were recommended and worn by experienced riders for a reason. Its part of the comfort equation. Obviously its a long learning curve finding a comfortable saddle but thats a road you need to travel on. On a first road bike from a local shop, they should work with you on a saddle alternative and should be able to recommend an alternative to whatever ass hatchet you did not like.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
Padded shorts will help with the contact points in your butt, but you really shouldn't be experiencing discomfort in your scrotum or penis. I would guess the bikes you have tried have not had the saddles adjusted to where you need them.
Likes For Chuck M:
Quoted: 347 Post(s)
Liked 418 Times
I got bike shorts or bibs. Then I got butt cream for really long rides. You also need road bike miles on that butt to really feel comfortable so start off with 30-40min rides and work up from there.
If you don't like the look you can get mountain bike shorts which are a little less formfitting but have a chamois inside.
I would say I'm fairly typical but this being bikeforums you'll get a few of, "Well shucks, I just ride my grandfather's Schwinn Paramount in my old dungarees and horse hair underwear 12,000miles every year and I'm perfectly fine." But most of us go the bike shorts route.
Likes For billridesbikes:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Coming off of a hybrid, a road bike will place you in a position that will take some getting used to. Chamois cream, a padded liner, a firm, well-adjusted saddle, and some hours on the bike should help. Be patient.
Likes For Rolla:
Quoted: 20810 Post(s)
Liked 9,456 Times
"discomfort in the privates" is rather vague. It could be something that a different saddle would remedy. It could be something that cycling specific clothing would remedy. It could be something that requires both in addition to a dollop of cream.
Klaatu..Verata..Necktie?
Quoted: 10497 Post(s)
Liked 12,023 Times
It also depends on what you're wearing now - gym shorts? Jeans with undies? Briefs or boxers?
The first place to look is the saddle. Not just the shape, but also the height, setback, and angle. Ideally, your weight should be carried on your sit bones. If not, you'll have issues. I've had saddles that allowed my sit bones to sink in too far, which led to the middle of the saddle pressing on the perineum, causing numbness where I don't want it. I've had others where the top of the saddle was straight from front to back, which doesn't work for me because I'm low flexibility and roll my hips forward, rather than bending at the waist, so I need a 'wave' saddle, which is higher at front ant back than the middle. If your saddle is too high for your leg length and pedaling style, that can be a problem. and on and on.
Regarding what you're wearing, mostly what padded cycling shorts do is less about padding and more about fitting to you so well that the shorts provide a good interface between you and the saddle, with no rubbing, chafing, or lumpy seams. The snug fit also helps keeping the jewels out from between you and the saddle.
LR÷P=HR
Quoted: 876 Post(s)
Liked 1,222 Times
Shorts
+1
Go to Padded Bike shorts.
If you really must... padded MTB shorts are not nearly as tight.
But.... self respecting road cyclists won't ride with you.
Barry
Barry
Likes For Barry2:
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 85 Post(s)
Liked 57 Times
get a good bike fit, ride more, be patient and if the discomfort does not go away, start looking into getting a saddle that fits you better, padded riding shorts help,
Likes For Eds0123:
Quoted: 5234 Post(s)
Liked 3,602 Times
what are you comparing it to? can you show a photo of your current hybrid saddle?
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 259 Post(s)
Liked 379 Times
If I'm riding more than 20 miles, I'll wear padded shorts, but most days I ride 15-20 miles, no padding, and no problem. As others have said, either you need to do some more riding to get used to the new bike, or there is a problem with the saddle/fit on the bike. We don't know what the problem is, but from my experience, you don't NEED padded shorts to prevent discomfort when you ride a road bike.
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 171 Post(s)
Liked 399 Times
You have tried several road bikes so I'm assuming that this was with multiple stock saddles on each bike. My first suggestion would be to use a padded short. I prefer the gel shorts as they don't use their shape as a chamois pad does and seem to be a little thicker. If you don't like the road bike type of bike short you get a bike short liner. Basically it's underwear with a chamois pad inside. Then you can wear whatever type of clothing you want over it. The next thing I would try is a saddle with a section that is cut out in the middle. That helps to relieve any pressure in the center. You can also find different types of saddles in regards to the "hardness" or "softness" of the saddle.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
When I first rode a road bike it was over 50 years ago, I rode in cutoffs and Jeepers. The first time I tried riding shorts was in 1983 and I had a leather chamois.
Funny, I had cleated cycling shoes before I had cycling shorts.
You should look into adjusting the saddle or looking for a better fitting saddle.
It took me nearly 2 years of riding 40 miles a day (2hrs) on the skinny saddle on my new Bianchi (1985) road bike 3-5 days a week before my butt got hardened up enough to not be in serious pain, and I always wore bike shorts with padding.
Now, 35 years of riding later, my ass only hurts after about 4 hours of hard riding. By the time I finish a 5hr Century I can’t feel my butt at all!
It’s a process your ass must go through to get toughened up when you switch to a skinny seat.
Liked 9,456 Times
I only do a couple centuries a year, maybe you ride the TDF?
OM boy
Bikes: a bunch
Quoted: 539 Post(s)
Liked 671 Times
Been wanting to bring up Sheldon's Wisdom again...
OP, this:
https://www.sheldonbrown.com/real-man.html
Ride On
Yuri
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I ride a century every Saturday about 8 months out of the year. I've never had butt pain or numbness. I don't think numbness is normal and would indicate something is wrong with your setup.
Likes For livedarklions:
Disco Infiltrator
Quoted: 3131 Post(s)
Liked 2,112 Times
It takes time to HTFU and you can lose it fast too. Some people never build up the mileage either. Don’t be ashamed to take some comfort in the meantime. Hurting yourself is macho but not actually beneficial to your heart or lungs or muscles. Try cycling shorts or softer saddles or cutout saddles. A wide saddle isn’t going to help as you sit on a narrower part of your sit bones when you lean forward
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
I didn't take from the OP that his pain was in the keister. I assumed it was more frontal.
Quoted: 1952 Post(s)
Liked 2,191 Times
If you ride a hybrid now without bike shorts and without pain, I think it is more about the saddle setup or the saddle itself.
As you bend over more to lower handlebars you are going to compress things. I have found that saddle tilt, and the right saddle, is pretty important on a road bike, at least for me. But too much downward nose tilt can put too much weight on wrists and shoulders.
Years ago, no one made cut-out saddles and few had channels. Brooks was, and still is for some, the saddle of choice to conform to your shape. Today saddles are designed to reduce perineal pain.
John
John
Liked 9,456 Times
For me, the worst isn't long rides at a hard pace, but when I'm accompanying someone that's riding at a slower pace - less pressure on the pedals, more weight on the ass. Even so, that's only a mild discomfort after 6+ hours.
As mentioned above, what you're describing indicates something not right.
Quoted: 511 Post(s)
Liked 646 Times
Agreed. I rode from Michigan to Seattle to SFO in cutoff jeans and tighty whities. Bike shorts are much better, but not necessary for comfort. And of course even with bike shorts it does take some time to "toughen up."
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 88 Post(s)
Liked 132 Times
