ATF as general purpose bike oil?
Passista
Quoted: 890 Post(s)
Liked 754 Times
I've been using it and it seems to work OK. What do you think?
I've used it for both mtn and road bike chains, and stopped due to the amount of crud it attracted. Seemed to work OK for friction, but grabbed the grit.
Dumond Tech now.
Dumond Tech now.
Likes For NVFlinch:
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 190 Post(s)
Liked 215 Times
No.
While it does lube a bit it is hydraulic fluid not made for lubrication; and it smells bad.
Last new bike 1991
Last new bike 1991
Habitual User
Quoted: 5120 Post(s)
Liked 8,456 Times
What is a “general purpose bike oil”? This implies that there are multiple places on a bicycle to use oil. Besides the chain, where else are you putting it?
Personally, I’ve moved away from oil-based chain lube.
Likes For Eric F:
Passista
Quoted: 890 Post(s)
Liked 754 Times
Cables, brake lever pivots, brake pivots, derailleur pivots, kickstand pivots, nipples when wheelbuilding, threads in general / under bolt heads and nuts when assembling... etc.
Habitual User
Liked 8,456 Times
A high-quality synthetic grease is a better choice for most of those parts. For others, oil-based lubes just attract grit.
Likes For Eric F:
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 269 Post(s)
Liked 184 Times
Dry graphite lubes are also good for some of those applications and they come in spray form as do some synthetic greases that Eric F suggests.
Cheers, Mike
Cheers, Mike
Not that I'm endorsing ATF as bike lube, but it's both hydraulic fluid and lube. I had a GM car with a manual transmission and it used Dexron ATF as lube, possibly for line standardization, as planetary gear automatics have gears in them requiring gear lube; so they must have figured it was easier to use ATF in the manuals than use gear lube in the automatics. Also, both engine oil and transmission lubes were beginning to go lighter weight at that time, for reduced friction. Better engine manufacturing tolerances made that possible for engine oil without low oil pressure. Manual transmission design and tolerances were also improving.
Likes For Duragrouch:
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 126 Post(s)
Liked 216 Times
I've used it as I'm one apt to try things for the experience. It works as well as any other oil based lube, and the key with any oil based lube is wiping it down after every ride, plus the rings and cogs. I put some in a small clear drip bottle, but don't remember if I diluted it with some mineral spirits or not. I think I did though, but how much I don't recall, doh ! Yes it attracts crud if left to accumulate, so don't let the lube that is expelled from the chain accumulate. I ride on the road, no muddy or sandy conditions around here. I "clean" the chain on the bike with some bulk from the can WD-40 by dripping it on and wiping 'till relatively clean. Reapply the ATF, wipe as dry as I can at that time.
I really resisted using heavier oils on the bike because as I grew older, I read so many negatives about it attracting dirt and thus ruining drivetrains. I bought it hook, line and s(t)inker So I used all manners of the usual speciality thin lubes because they supposed to be "better". Better for who ? The ones selling it of course. At some point I just started using some heavier oild to find out for myself. Air tool oil works just fine also. I ran across some post of people using ATF fluid, so I tried that too. I used Chain-L too, which is heavier and sticky-er, but like any oil frequent wipe downs keep dirt from accumlating. I suppose most any oil intended for moving parts will work okay with wipe downs. I won't pretend any lube(even wax) is some miracle, because it's not. Everyone uses what they can live with. A "miracle" would be a chain is self-lubricated and lasts forever, always clean and fresh.
Likes For Garthr:
(above) Road biking only, environmental dust contamination of oils has never been the issue; It gets pasty after a month of long daily rides, due to fine chain metal powder forming a colloid suspended in the oil. Doesn't matter if ATF, 75W-90 gear lube, motor oil, 3-in-1 oil. All eventually paste up the same, then I clean off with on-bike cleaner with mineral oil as solvent, wipe dry, relube. Planning to switch back to wax as I used decades ago on my pristine road bike.
Dirty Heathen
Quoted: 897 Post(s)
Liked 950 Times
I’ve used ATF for certain applications on some of the bikes; I primarily used it to soak the stiff, slightly rusted chains on used bikes that I was reconditioning for sale. It definitely made them run quieter (mostly old 5-7sp bikes) and kept the chain in a decent state, even if they sat in storage for a few months before they got sold.
I started doing the same with the kids’ bikes and the “loaner” beach cruiser and townie, since they often get pulled out at random, after they’ve been sitting for a while.
I don’t use it for things like brake pivots and DRs, since it seems to like to spread out in to a thin, sticky film on flat surfaces. I like a spray white grease for that kind of application. Blue grease, too, particularly for things that would need to be disassembled to re-lube, like jockey wheels and canti pivots, since it stays where you put it, and it lasts
My regular “sporting” bikes (road and MTB) get much more frequent pre- and post-ride service and inspection, so they get lighter, high performance lubes like White Lightning and “dry” PTFE (mostly because it keeps it cleaner during the ride)
Quoted: 1112 Post(s)
Liked 1,055 Times
OP: ATF, get full synthetic, it isn't much more and doesn't smell the same way, it is good for internally geared hubs. Otherwise, most of the things you mentioned are best dealt with using a lithium grease or a graphite lube.
Mad bike riding scientist
Quoted: 6295 Post(s)
Liked 4,331 Times
I’ve worked on bikes that were drenched in either ATF or motor oil. It’s never a pleasant task. The bike below even had oily dirt on the grips, shifters and brake levers. It’s like they just opened a can of 10-40W and poured it over the bike.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 417 Post(s)
Liked 603 Times
Puhleeezzz ! ! It's the 21st Century, dude ! ! You have the advantage of a multitude of task specific lubricants and you use TRANSMISSION lube on your bike ? ! ?
Likes For Steel Charlie:
Quoted: 3663 Post(s)
Liked 3,099 Times
It always amuses me that people who spend $5,000 on a bike can't crack their wallets open for a $5.00 bottle of Tri Flow.
Likes For smd4:
Passista
Quoted: 890 Post(s)
Liked 754 Times
None of those items need lubrication for more than a couple of times over a decades lifetime of the bicycle. If cables need lubrication, they most likely need replacement. Brake pivots never really need service and pouring oil over them is likely to exacerbate any issues you have with them by attracting dirt. Same with derailer pivots. Kickstands don’t need anything done to them and will work for decades (maybe a millennia or two) without doing anything to them. Nipples on wheels do need oil but a lighter oil will do the job better. Threads should be greased which is semisolid vs liquid like automatic transmission fluid.
Passista
Quoted: 890 Post(s)
Liked 754 Times
Ok, apparently ATF isn't too well liked around here. Maybe I try to oversimplify things - if the trend toward super specific lubes goes on, soon you'll get a RD pivot grease and a FD pivot grease.
Liked 3,099 Times
Likes For smd4:
Quoted: 2649 Post(s)
Liked 2,004 Times
Liked 3,099 Times
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista Vitus 979
Quoted: 3141 Post(s)
Liked 6,851 Times
Quoted: 6387 Post(s)
Liked 4,982 Times
I think you'll find that the bikes requirements for oil really don't care what oil you use. There'll likely be good and bad points to all and you just have to decide what you'll put up with.
If you are willing to put up with any of the drawbacks to others for that oil, then it's fine. Nothing on a bike turns at the speeds engines that use the same grade bearings. Nor does anything on a bike create the heat to destroy the surfaces needing any special lubrication that does a combustion engine. Or heat up from the efficiency loss of power transfer or simply from friction.
However I too think that mostly the only part that needs oil is the chain. And that doesn't have to be petroleum based products.
As mentioned by another, when you get to putting oil on cables and other things on a bike, you are already in need of new soon. Especially if you oil them before they show that need. If we are just talking about wiping some oil as a preservative on cables where they run bare or other places, then not so much a issue than if you drip oil into the cable housing. But with modern cables and housings you shouldn't need too ever. At least for the common environmental conditions bikes are operated in. Perhaps on a old bike with regular steel cables that rust you might eek out some more life from them.
Quoted: 2407 Post(s)
Liked 2,999 Times
I simply don't understand the constant search for alternatives to simple cost effective, proven bike focused lubricants
All you need is tri-flow, a tube of phils waterproof grease, Phills tenacious oil (drip into freewheels), your choice of chain lube (Silca super secret liquid is my new go to)
add a penetrating olil for recalcitrant parts (I like Freeze off) and wd40 is not a penetrating oil
50/50 ATF/Acetone is a great penetrant though if you are dealing in high volume
Life is too short not to ride the best bike you have, as much as you can.
I like using atf+acetone to loosen up derailleur pivots without removal and other pivots. Yes it may be wrong but I have a stash of the stuff from long gone cars, and all cars take weird atf variations now-a-days. IMO just try it out, if you don't like it go use something else. Oh, and I used gear oil in my freewheel. Maybe an evil play but it works nice and I don't mind the smell.
Admittedly my last bike was 40usd and I ride and use sub-optimal equipment/lubrication.
Likes For slow rollin:
Quoted: 190 Post(s)
Liked 215 Times
Summary here:
https://www.rx8club.com/attachments/series-i-tech-garage-22/202003d1398023610-machinists-workshop-penetrating-oils-test-machinists-workshop-penetrating-oils-article0001.pdf
