Will a Park Tool TS-2.2 fit a 29+ wheel with tire?
Bikes: 1973 Raleigh Professional, 1993 Raleigh Technium Olympian, 2006 Cervelo Dual, 2008 Cannondale Caad8, 2010 Kona Unit, 2013 Trek Superfly 100 AL Pro, 2014 Trek Crockett 9, 2017 All City Nature Boy 853
Will a Park Tool TS-2.2 truing stand fit a 29+ with the tire installed?
yes it should , it what the up grades were for from the 1.5 model .
Sr Member on Sr bikes
"...29+ wheel with tire?" Well maybe not. If by "29+" you mean bigger than a 29" wheel...with tire...it might not. Park website says it'll accommodate "...up to 29" with or without tire."
https://www.parktool.com/product/pow...ruing%20Stands
Dan
Dan
Randomhead
Liked 3,714 Times
I am pretty sure it will.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,444 Times
29+ = 700 x 3-inch, with a 'normal' 29er tire being 700x2.1" or so, and 'fat' being 700x4" or more.
Quoted: 141 Post(s)
Liked 163 Times
For the record, almost all fat bikes use 26" rims (559 BSD), with some of the very newest using 27.5 (584 BSD), with widths, as you say, 4" and more. I'm not aware of a 29er (622 BSD) in anything wider than the "plus" width of about 3."
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,444 Times
Never hard to remove, but a pain to reinstall if it's tubeless (which a 29+ tire almost invariably would be nowadays)
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,444 Times
Quoted: 141 Post(s)
Liked 163 Times
Hmm, I wasn't aware of that. So probably 29+ is the biggest you can get (without going Dirty Two or Dirty Six?)
A 26" x 5" fat tire is at least as tall when inflated as 29+, maybe a little taller. There are fat bikes that are advertised to be compatible with 26 x 5 and also a 29 x 3, because of the similar outside diameter of the inflated tire sizes.
