Performance Wheelset Decision on New Tandem?
#51
It has been 6 years since this thread about tandem rims started. The world has changed a bit since then, including recently finding our 1998 Co-Motion stolen from our locked Explorer in our driveway. We found a nice used Carrera, but want to upgrade the wheels since they were optimized for a heavier couple.
Just like Woodcycl, we are right around 290lb to 300lb. Six years after he posted the question, we have the same question regarding today's high-end tandem wheelsets. We run 32m tires and are looking at Spinergy and Rolf. We are a bit shy about the Rolf limiting inflation for 32 tires to 80lbs. We have found that around 88 to 89 is great on the old rims. We would love to get your input on Rolf vs Spinergy for modest speed paved roads and trails.
#52
pan y agua
Quoted: 1459 Post(s)
Liked 735 Times
Personally, I do not like the Rolf paired spoke design. It requires higher spoke tension raising issues with both hub and rim failures.
We had the Aluminum Rolfs, and over a few years, both rims and both hubs failed. All were spoke pull throughs resulting form the higher spoke tension.
Admittedly, I haven’t ridden the carbon Rolfs, and the rims may be stronger but I’d still worry about the hubs.
Also if you break a single spoke on Rolf it’s going to likely be unrideable. Whereas with a conventionally spoked wheel you can get home one or even two spokes down.
You could get lost and die.
You could hit a tree and die.
#53
pan y agua
Liked 735 Times
We’ve had good luck with custom built lightbicycle wheels. Ours are 65mm Falcons, 28 spokes, Dt240 hubs, and the extra strong rim option, which adds 100 grams of carbon to the rims. ( which is likely over kill)
6 years, 20,000 miles on those wheels, team weight 350lbs, and zero issues. Also cheaper than the Rolf’s.
#54
Just cleaned the tandem after finishing the New Forest Sportive yesterday, I found the rattle that started halfway round was a chunk of wheel broken where two spokes go into the rim. (Rolf tandem) We did hit a couple of big pot holes, they were hard to spot under the dappled sunlight. Any way, has anyone used a gravel or mountain bike wheel on their tandem I am thinking they would be stronger.
#58
Still successfully running our Rolf carbon 60mm wheels(3 years), we’ve had great luck with other Rolf wheels over the past 10 years with our other tandems also. The hubs have been bullet proof(White Industries supplies them) and share components with our other WI/Zipp 404 wheels. We’re about 280lbs and typically use these wheels when we travel and are lighter than the Zipps, currently using 28mm conti gp4 season tires, will change to 32mm soon.
Likes For MRacing:
#59
So, just adding a bit more information and familiarity with wheelbuilder.com. I have know the owner for about 20 years. He is a great guy and knows more about wheels than anyone I have ever met. I have purchased 3 sets of tandem wheels from Rich over the years they have been flawless. I have also purchased parts to build wheels for my 1976 Jack Taylor restoration. Again Rich was very helpful. Got the last set of Phil Wood hubs that would take a freewheel for the Jack Taylor.
#60
#61
The Bingham IS perfect! Light, stiff, compliant and comfortable, and ridiculously impeccable build quality. Brad is an artist with his craft, I can’t recommend him highly enough.
#62
Quoted: 7 Post(s)
fantastic photo AND bike!
#63
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 115 Post(s)
Liked 65 Times
#64
Most newer frames come with the correct bb spacing to accommodate a standard Gates belt drive. The belt is lighter, zero maintenance, long life durability, clean, and since it’s installed with a slight preload tension any typical chain slack is eliminated. It’s a win.
