Are Hookless compatible tires cheaper to produce?
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
I’m told that hookless rims are cheaper to manufacture, wondering if same goes for tires?
i just can’t help but notice that quite a few places are offering the new Conti 5000s for much less than the prior version was selling for now that the S is “TR, tubeless Ready” vs prior TL Tubeless”. Supply chain constraints are still around and supply is still tight so I wouldn’t think that retailers would have to dump them or lower their margins so I’m wondering if the cost of these is lower from a manufacturing stand point and thus lower price to the dealers themselves?
in other news, I decided to ride into a pool of glass on our group ride this morning. Basically brand new tires heard the hiss and pulled over, sealant worked beautifully spurting out for a few seconds. Probably lost about 25lbs used the C02 and finished the additional 25 miles. I’m hoping that the cut is sealed well enough that I don’t need to think about patching or replacing?
thoughts?
thoughts?
Quoted: 6199 Post(s)
Liked 4,816 Times
Somehow I can't see that there would be any vast amount of difference for cost of manufacture. Certainly not enough for us to realize it in our wallets. And besides, many manufacturers don't price just on what it takes to manufacture and add on their desired profit, they also sell stuff by what the market bears and demands.
Don't know about your tire since I don't do tubeless yet. But the cut or puncture looks like a plug might be a good idea. But I'll defer to other tubeless users that know better.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 418 Times
Any time sealant makes it outside one of my tires, I pull it off and put a patch on the inside.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Likes For bbbean:
Quoted: 429 Post(s)
Liked 248 Times
I think I’ll take a look at a patch I side perhaps. I have plugs for road side repairs when sealant won’t work but since it did I figured I’d either leave it be or patch or replace depending on recommendations. I’d hate to replace though since they have less than 400 miles
Liked 4,816 Times
I'd expect it to be much the same for tubeless.
Thread Killer
Quoted: 3151 Post(s)
Liked 1,716 Times
That’s a pretty good sized cut, and having lost about 25psi affirms that, though I also suspect (based on my experience) that the sealant could have done a better job.
As for the future of the tire, I’d have preferred to leave the sealant glob on the outside— it looks like maybe you picked it off for the pic— just to block debris getting in there and being worked in enough to cause another leak. I’d probably dab some vulcanizer in there now and not worry about it beyond that.
Sure, the cut is a risk factor, but to whatever extent that additional risk is, it’s only risk of annoyance, not risk of catastrophe. If it reopens, the sealant will reseal it. Unless you roll without a pump, I’d say the odds of that cut leaving you stranded approach zero.
if workable, moving it to the front would further mitigate running risk and avoid immediate replacement.
Quoted: 4806 Post(s)
Liked 3,932 Times
i just can’t help but notice that quite a few places are offering the new Conti 5000s for much less than the prior version was selling for now that the S is “TR, tubeless Ready” vs prior TL Tubeless”. ...
Dropping the tire from "TL" to "TR" says to me they are loosening their standards and/or protecting themselves from hookless blowoff suits - to save themselves money and liability. (Personal opinion here - hookless rims are a boost to stockholders (company gets to sell lighter; hence more attractive, wheels at the same or higher prices while building them at lower costs. For the rest of us, no real advantage and if we are not careful, they can be a real danger.)
Liked 3,932 Times
And on a more pedestrian note - with that gash, watch for a bulge developing. If threads were cut, they will probably be the outer threads which run diagonally under the thread in one direction. If they fail, the tire will take a weird asymmetrical bulge. Now only the other layer of threads running at roughly right angles to those cut are holding your tire together. This can be fixed by gluing in a structural boot (not a tire patch!) on the inside. I've had great success with sailmaker's dacron sailcloth (not the JoAnn's Fabrics stuff) glued with contracter's contact cement; the stuff countertops are glued down with. There are lots of other good fabrics. I used to sail and build sailboats so I was handed a great piece of sailcloth decades ago and have looked no further.
Likes For 79pmooney:
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
https://www.tradeinn.com/bikeinn/en/...444&country=us
I've used this for my tubeless gravel tires. Not sure if it's different from regular tube patches.
Likes For mstateglfr:
Quoted: 429 Post(s)
Liked 248 Times
Quoted: 672 Post(s)
Liked 418 Times
DO NOT DO THIS! A flat on the front is an inconvenience. A flat on the front is a likely crash. Always put your least trustworthy tire on the rear.
Thread Killer
Liked 1,716 Times
I understand your concern, but think it doesn’t account for tubeless behavior; catastrophic flatting is not really a thing with tubeless. Therefore, my assessment is that flats are more likely in the rear, a cut is more likely to reopen in the rear (due to weight distribution), and the odds of that particular cut reopening on the front are extremely low.
Sunshine
Liked 7,496 Times
Liked 2,981 Times
The cost depends on how the manufacturer's production process. It could be cheaper, but might not be by much once the supply chain side gets involved (demand) .
pick out all the debris, patch the tire, vulcanize the exterior really well, let it all cure & then reinstall the tire for use. If it presents any issues from those repaired areas, replace the tire.
-Oh Hey!
-Oh Hey!
Thread Killer
Liked 1,716 Times
I’m not familiar with these tubeless patches meant to go inside a tire under the tread, but it sounds like a real PITA to do, raising the question why not just use a plug repair, which is a whole faster and easier and just as permanent, if not more so.
I mean, the tire in question is sealed, so I’d be reluctant to do anything more than try to fill the tread cut to keep debris out, but if I were worried about it, I think stuffing a “bacon strip” in there would be my approach to a permanent, durable repair.
Quoted: 429 Post(s)
Liked 248 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
Part of the cost differential may be Conti's decision consolidate the S line and have only one flagship model, as opposed to tubeless and non-tubeless versions. In general, though, tires built to hookless spec to need to have tighter tolerances and tend to be a bit more expensive.
As far as that cut, it looks to be about borderline, IME, for a permeant sealant-only fix. I've had a few of those, right about 4-5mm, and would either just leave it or use a plug on it. Most of the time, it's just fine. One of my cuts like that, though, did re-open after about 1k miles, when I hit a sharp bump just right. It did reseal, losing about the same 25psi. It then went a few hundred miles more before another just-right hard bump made it re-open and re-seal again. At that point, it was towards the end of life, in terms of tread wear, so I just binned it. So yeah, it's probably fine, but if you want to be proactive about potentially avoiding another roadside inconvenience of topping off, you can plug it.
Likes For WhyFi:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
thoughts?
thoughts?
Last puncture I had, the sealant didn't clog it. I put a patch (regular tube patch) inside, poured fresh sealant and pumped it. It still holds very well.
Quoted: 1461 Post(s)
Liked 1,486 Times
I think they are still selling the regular non-tubeless GP 5000, correct?
I'm also curious to hear what kind of prices people are seeing. I haven't shopped tires in a while, but a quick glance at online suppliers shows the S TR selling for around $70-$80/ea, and the regular GP 5000's selling for around $50-$60. This doesn't seem to be all that different than what I recall these tires selling for 9-10 months ago.
Sunshine
Liked 7,496 Times
1 is half as much as 2. If 1 is a PITA, what is 2?
Liked 9,456 Times
Did Continental drop the TL version of this tire? It seemed weird to me that they were selling both the S TR (tubeless and hookless ok) and TL (tubeless, but not hookless ok).
Excel was selling two-packs of 25mm S TR for... I want to say $120 or so. If they would have offered that in 28s, I probably would have picked some up.
Likes For WhyFi:
Quoted: 672 Post(s)
Liked 418 Times
Liked 3,932 Times
Flats on the front have nothing to do with tubed/tubeless/tubular. A flat on the front frequently results in a dramatic loss of control, and is many times more difficult to control than a flat on the rear. FWIW, I've been running tubeless on my road bikes for a few years and have flatted at speed. Not an experience I'm eager to repeat..
