Improving (increasing) friction in Cinelli 1R stems
Bikes: many
Quoted: 1447 Post(s)
Liked 1,396 Times
I have a couple bikes with Cinelli 1R stems. I've always been afraid to really honk on the allen bolt for fear of breaking the little internal clamp part. Consequently, they sometimes slip, always when I'm braking on the hoods and you get that back-to-front weight transfer. No problems so far, but it gives me the willies when it happens. I worry about it slipping during a hard stop (like, to avoid ramming a boneheaded driver who cuts me off).
It occurred to me that maybe I could increase the friction a bit. Don't the carbon fiber geeks use some sort of assembly paste for their seat masts (and maybe cf handlebars) to reduce the amount of torque they have to apply to their bolts? Alternatively, might a little drop of oil on the surface between the nut and the clamp piece improve transfer of torque from the bolt through the clamp to the bar? Where the red dots are in this image.
Bikes: 2012 Moots VaMoots-74 Peugeot Mixtie U018-73 Peugeot U018
Quoted: 17 Post(s)
Liked 9 Times
Hi Skip, Here's what I used to correct the slippage on the Cinelli 1R stem:
https://www.amazon.com/Safety-Walk-A.../dp/B001NH3WZ4
See you on the road, Mike
Moots VaMoots 2012-Peugeot Mixte 1974-Peugeot Mixte 1973
Quoted: 1609 Post(s)
Liked 2,216 Times
@Drillium Dude likes 1R stems a lot. He may have a suggestion. I think you could easily grease the mating parts as well as the fastener. The later may back out but give it a try. Note that the torque will be reduced with increase in applied pressure to the bar.
Quoted: 569 Post(s)
Liked 589 Times
I keep carbon paste around for just such situations, works great, takes very little. Much better than in the old days mixing valve grinding compound and grease.
Quoted: 91 Post(s)
a 1000 or 1200 grit wet paper should fit. if you work it down a bit, but you might get a 800 grit in there.
it works ...
