bike sizing, colango dreal lux, trek 5200, cannondale caad 3, merckx alu team
Bikes: bianchi pista, charge plug, pista brera
BIKE SIZING , colnago dream lux, trek 5200, cannondale caad 3, merckx alu team
Hi , i m looking for a new bike and i found three bike and I found four bikes that could fit but im scared about sizing.
i ride a bianchi pista which is a 53 with a 53.5 top tube length and a charge plus 59 with a 53cm top tube length. im 172cm...5'8"
i found good deals on those bikes. :
1. the eddy merckx alu team which is a 50 cm but i m scared it's gonna be too small and i can' find a geometry chart for this bike.
2. The colllnago dream lux. size is 54.
3. The cannondale saeco teal replica caad3 52cm
4.the trel oclv 5200 in 54 cm ...
So , could you tell me which bike could fit me regards of the size? Some advices about those specific bikes. i m new to road bike.
thanks a lot for your help....sorry for my bad english.
Pierre
Pierre
Falls Downalot
Bikes: Now I Got Two
Quoted: 5 Post(s)
None of us can help you more than you plugging your measurements into this bike fit calculator at competitive cyclist that will at least tell you which of those bikes fit you best....meanwhile, check bikepedia and research the geometry of those bikes
ok at competitive cycle they said seat tube cc 52cm and top tube 53. regards to those size : can i eventually consider the 54cm trek 5200 which has a top tube of 54,6? if i use a shorter stem ?
But my principal concern is about the top tube length. i don't really understand the importance of the steerer?
Quoted: 1873 Post(s)
Liked 692 Times
I have three very close friends that are all 5'8". Two ride 54cm and have longer legs than torso and the third has even legs/torso length and rides a 52. The top tube will determine how stretched out you feel. All that being said, if you get a bike in the 53-54cm range you can make it fit with the correct length stem and proper adjustments.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 692 Times
edit: on second thought I recall that those era treks have a slightly longer tt than st. Something like 54.8cm tt for a 54cm st frame. I would double check on that because approaching 55cm on the tt might be pushing it.
2019 Salsa Warbird
2019 Salsa Warbird
Yeah that's a good deal. Make sure there are no cracks in the carbon.
Liked 692 Times
Well not necessarily. A 60mm stem is really really short for a road bike.
2019 Salsa Warbird
2019 Salsa Warbird
yeah it's a short stem for sure but i was just using my bike from my house to my school (it's fixed gear). i started to ride 70 km every sunday with this bike and now i want a proper bike to make bigger distance. on longer distance i felt that the stem was a big too small. i m gonna go to try the trek and see if feel right on it. i guess they let me try the bike for 30 minutes.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
I'm 66", fairly short legs, love my 5200 52cm. A 54 is a little big for me.
Liked 1,939 Times
Trek measured those frames a little oddly IMO. 52 is center to top of seat tube. C-C on the top tube is only 52 cm. I ride another bike that works fine and measures 52 C-C and 54 C-C on the top tube, with a 110 stem, so quite a bit larger bike than the 5200 52cm. If that bike were measured to top of seat tube it would be a 56. So I think the 54 would be the choice.
Liked 1,939 Times
If the bike is at hand, measure it yourself and compare to your Bianchi. However, riding it is the thing.
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
It would be a much better idea to buy a bike that puts you on a 100mm stem, or thereabouts. That way you have a reasonable size stem, and you can adjust shorter or longer as needed. If you try to stretch on to the 54cm bike with the shortest stem available you're SOL if it's too much of a reach because there is no way to go shorter.
You could get lost and die.
You could hit a tree and die.
On the other hand, when going with a larger frame, steerer length is not a problem as long as you are not looking for a lot of drop, but there is a limit to how short you can go with the stem before the handling starts to suffer.
When going for a smaller frame, it is easy to gain additional length by changing stems, but it is not so easy to gain additional front-end height if the steerer is too short.
pan y agua
Liked 728 Times
Theoretical limit is 30mm, but it's typical for road stems to come in sizes from about 80-130mm.
You can find longer than 130 and shorter than 80, but beyond those the pickings get slimmer.
Lots of people will argue that very short stems make for twitchy handling.
Personally, I would try to aviod going below 80mm for aethsethics, stem selection flexibility, and to a lesser degree handling.
