Di2....issues...
Di2....issues...
Hi, here's one that has me about to chuck the bike in a ditch.
I have lost synchro, it just stopped working on a ride.
So i went to the junction box and did the two quick pushes to check, and had the 3 flashes.
still nothing.
Went to the app, the app tells me all is well.
I disconnect the battery and reconnect after a few minutes.
I disconnect the junction box for a few minutes.
I then go into the laptop and hardwire the bike to the pc, do all the updates (none required), reset to defaults and then select synchro.
Upload to the bike and disconnect.
Still nothing. No semi or full synchro, just regular shifting although the software is telling me I'm in full synchro mode.
Am I missing something blindingly obvious?
I have searched the forums but cannot find a similar problem with a solution.
Thanks!
still nothing.
Thanks!
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,589 Times
Here's a link to a Di2 tips site. https://di2center.com/
Which mode does the e-tube software show the system is in? Do you have a Garmin or othe head unit that can read and verify the mode? It seems like the mode isn’t actually set, but it is difficult to tell from the information supplied.
Hi, thanks, yes I have a Garmin, I will set that up to read it. Just to say, the app, the laptop and the junction box all tell me its in synchro mode - I guess the Garmin will say the same as its just taking the same info that is being transmitted to the app and laptop?
Hi Bitpuddle, I set up the Garmin and switched between shifting modes M, S1, S2 and it had no effect.
Regardless of what the app, laptop, junction box and Garmin say, it is stuck in manual.
Haha, yeah, dont think they saw a PC till last year...culprit was the app. I repeated disconnecting everything, avoided all bluetooth, reconnected by cable, reset everything, set defaults and started again. Sorted it.
All I can say is never use the app. I left the appropriate review in the app store. What a load of crap it is.
I’m glad you got that sorted. I was going to ask if you were using Bluetooth. Sometimes there are issues if you don’t completely disconnect from the app (like turn off Bluetooth on the phone) where the settings changes are not saved. Using a cable is definitely ore reliable.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
When you wiped the profiles and started fresh...did you reprogram the synchro modes?
Quoted: 152 Post(s)
Liked 173 Times
Glad you got it back to working again. I've been relying on the app on my iPhone because the only PC I have is an 11 year old laptop that runs Vista. Unfortunately, the version of etube that supports 8050 won't run on Vista. Everything I read says the app is wonky and definitely don't use it to upgrade firmware. I've been thinking about picking up a cheap laptop to use for etube and your issues have pushed me to do go ahead and order it.
Yes, I did that Marcus, I'll admit I was doing it blind - I just couldnt figure the problem so I decided to treat it like a new set up. I even deleted and reinstalled then E tube program on the PC and deleted and reinstalled the app. So I cant say what the problem was but as bitpuddle suggests it was likely the bluetooth issue.
Hi August, I had to do exactly that. I initially was using a Windows 7 laptop that was a decade old and previously my daughters. I had to hack her password using a clever youtube post and then it only worked the once with E tube!
I found a refurb Acer with windows 10 (my wife needed an email/browser laptop anyway so that was the excuse to her!).
I use a chromebook which as you probably know is no good, the only other things lying around is an ipad.
Its not easy having di2, and I'm not sure its that much of a leap anyway....but that's another debate!
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
Good to hear you got it fixed! I wonder if somehow the bike changed all shifting modes to 'manual'.
And yeah, closing the app without disconnecting bluetooth will leave the bike in Bluetooth mode until you start the app and properly close the connection.. unfortunately
