Electronic Shifting - What's the Point?
#126
Bikes: Canyon, Bowman & Colnago
Quoted: 132 Post(s)
Liked 39 Times
I'm not sure there's even a market for Chorus electronic system. Who would that sell to, given that it would likely be priced above at Force/Ultegra? Basically, the market is someone who wants electronic shifting technology (not a traditionalist), but doesn't want Shimano or SRAM. I suspect the European market may be different, in the US Campagnolo is only for custom bikes.
To me, Campagnolo is to bikes what Apple is to computers. The stuff is expensive, it's beautiful to look at and works, for the most part, however it doesn't always play nice with others, parts are expensive and it has a very solid fanbase who drools over anything and everything it puts out. Sure, some of the fans are traditionalists in the sense that all their bikes are Eroica bikes and then there are others who are simply after the exclusivity, the "cool factor," they feel they get with owning a "high end" groupset such as Campagnolo.
Seriously, I know people who are such Campy fanatics that Valentino could roll out a carbon coated alloy turd (which he did, minus the carbon, and he called it Potenza) and they'd stand in line for days to spend a years' salary on it.
Likes For mrblue:
#127
Quoted: 636 Post(s)
Liked 1,490 Times
Every new technology is always received with resistance by some. I'm sure when pneumatic tires were introduced for cars, some people said "What happens when the tube goes flat and you don't have a pump?" My wooden wheels have worked fine, why should I change?
I got my first Di2 back in December of last year and don't expect I'll ever buy a new bike without electronic shifting again. Ease of shifting, synchro shifting, no cable replacement, etc. A don't expect to ever catch myself with a discharged battery and I'm not worried about it failing and stranding me somewhere. I know that it's possible but probably no more so than being stranded by a mechanical issue.
I had a 3 X 9 105/Ultegra setup before and was perfectly happy with it till I tried Di2. I won't miss anything about it. I also do not miss points and distributors, or carburetors, or downtube shifters
Likes For Ogsarg:
#128
Quoted: 132 Post(s)
Liked 39 Times
#129
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
#131
Quoted: 3906 Post(s)
Liked 7,182 Times
Complaining About Electronic Shifting – What's the Point?
Likes For tomato coupe:
#132
On Your Left
Liked 2,433 Times
#133
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
As for SRAM's crap shifting, I don't feel like it has too much effort, but the Doubletap mechanism definitely has a couple of drawbacks - it's easy to shift to a smaller cog by mistake when you're shagged, which absolutely sucks when it happens. And the shift feel is okay when you're dropping the chain to smaller cogs, but it feels like arse when you're going the other way and you've gotta pull the shift mechanism past that release click.
Escapement mechanisms all feel a bit crap if you ask me, next to Ultrashift, or whatever the original Ergo mechanism is called with the G springs - basically the same deal as a countersprung indexed downtube lever, pretty much the apex of shift feel. Unlike an escapement mechanism, you can feel what the chain is doing when you release the cable as well as pulling it.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
#134
Quoted: 4717 Post(s)
Liked 1,882 Times
Actually, come to think of it, they could increase that radius without increasing effort (if you increase cable pull, you're increasing the amount of cable friction felt, but nothing more, since you're still moving the RD the same distance), by reducing the lever throw so the cable pull is the same.
JMO, but frequent replacement of very inexpensive part, is a fair trade off for smooth and light effort shifting. I suspect that is why Shimano hasn’t redesigned the shifter.
#135
bike whisperer
Liked 716 Times
Bit nervous about all that complexity
#136
bike whisperer
Liked 716 Times
when you decrease the cable pull, there’s less room for error(cable stretch/housing shrinkage).
But I seem to recall Shimano's marketing bragging about reduced lever throw, so hey, twofer.
#137
Quoted: 132 Post(s)
Liked 39 Times
I think selling the bike at this point is a little extreme. I never said I hated it and/or regretted buying it. Over all, I actually like it and may learn to appreciate all its bells & whistles in the future. Maybe if a long time goes by and I find myself never using it I will revisit the selling option. It's more akin to buying a really cool power tool you've been eyeing at Home Depot, then one day it goes on sale so you jump at it. Then when you get it home, you're scratching your head trying to figure out what to use it on.
#138
Quoted: 6100 Post(s)
Liked 4,732 Times
A bike with electronic shifting isn't going to have a benefit over another bike that simply is more enjoyable to ride. So one shouldn't just buy a bike to get electronic shifting.
#140
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
I've ridden a R8000 Di2 bike a little shy of 4000 miles / 350000 ft since this time last year. By now it would be time to replace mechanical cables and housing, as they would need continuous tweaking and the friction would prevent flawless indexing anyway. Perhaps before now even. Di2... haven't even had to adjust it. My experience has truly been set and forget, and I have bikes to ride them, with no real interest in doing an ounce more work than is strictly necessary to keep them rolling and working well. Same with my Canyon, also R8000 Di2; 1500 miles, 125000 ft since May, and zero indexing adjustments. The writing IMO is on the wall, and when the electric stuff shows up at more sensible price points mechanical groupsets will be relegated to retro hipsterdom.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
#141
Klaatu..Verata..Necktie?
Quoted: 10247 Post(s)
Liked 11,600 Times
It would be so much easier for people to just say, "I like what I have" rather than trying to come up with reasons why others have to agree with them, or why others' choices are wrong. But then, there would be a lot fewer threads on BF.
#142
Liked 11,600 Times
BUT, I've been wrong before. Who knows? Maybe by the time I get around to buying a FIFTH road bike, they'll have 105 Di2 for only a $500 premium over mechanical. If I'm not living under a bridge eating captured rats, maybe I'll try it.
#143
Quoted: 3185 Post(s)
Liked 2,020 Times
I do find it amusing that with mechanical systems, especially those you install yourself and have done so for decades, there's a skill set and knowledge that you acquire, which is used semi-frequently by the need to replace cables and re-adjust the system. With Di2 it's install and forget about it as I have with my 3 year old system.
When I started on a ride today, my Garmin would not connect to my Di2 system. I typically have to manually make the BT connection by putting the A Junction into BT discovery mode, it takes a second to do. I pressed today and got zip out of the LED's, so OK, a dead system. I went mt. biking instead and dealt with it after. I then remembered I had removed the bar and stem a few days ago to check the fork, and when I looked, the battery cable had come out of the A Junction. OK, re-plug and good to go, everything shifts fine.. Except no connection to Garmin so BT seems dead. Then I recalled that the BT WU111 system is inline with the battery in the seat tube, so I pulled the seat post, unplugged the battery, waited 5 sec. re-plugged and the BT reset itself and now my Garmin connects. So a different skill set to troubleshoot and one hardly ever used, the system is that reliable.
#144
Liked 11,600 Times
The Software Engineer says, "Let's get of the car and get back in again."
Likes For genejockey:
#145
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 396 Post(s)
Liked 376 Times
#146
On Your Left
Liked 2,433 Times
#147
On Your Left
Liked 2,433 Times
I also have a (2) 2018 Subarus and both have EFI, AWD and CVT. I'm just glad it doesn't turn off everytime i stop. I'd be concerned that the starter will go quicker than normal.
#149
#150
Liked 7,182 Times
Yeah, that’s a big weakness of electronic shifters - they don’t work if you disconnect the battery wire. Luckily, mechanical shifters are foolproof - they continue to work if you disconnect the shift cable. Oh, wait ...
