Definition of a Mechanical
Bikes: Specialized Secteur, Specialized Roubiax,S-Work Roubaix, Specialized Amira S-Works
Quoted: 24 Post(s)
What constitutes a mechanical to qualify for a free lap in a Crit? I had a seat come loose...didn’t break. I was allowed to finish the race, but some are questioning whether it was a true mechanical. I did not podium for what it’s worth.
Cat 2
We've been having this discussion over in the Race Stories thread. Give that a read to get a start.
https://www.bikeforums.net/showpost....&postcount=244
Quoted: 24 Post(s)
Thanks!
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Who questioned it? Other racers?
I'd pull over for a free lap for that, personally. I'd hope the officials would grant it, but don't know.
Well today I learned that thinking you have a flat when you don't actually have one is NOT a valid mechanical. Who'd a thunk it?
Quoted: 1851 Post(s)
Liked 675 Times
Per USAC Rulebook:
2B5. A legitimate fall, a puncture, or the breakage of an essential part of the bicycle shall be considered recognized mishaps. All others incidents are considered un-recognized mishaps.
and
Mishap: A crash or a mechanical accident (tire puncture or other failure of an essential component). However, a puncture caused by the tire coming off due to inadequate gluing is not a mechanical accident, nor is a malfunction due to miss-assembly or insufficient tightening of any component. A recognized mishap is a stoppage that meets the above conditions. An unrecognized mishap is a stoppage where the above conditions are not met. A broken toe strap or cleat is a mishap. A worn or misadjusted cleat or toe strap is not a mishap. If more than one toe strap is used on a pedal, breakage of one is considered a mishap. Any mishap not immediately inspected by an official is unrecognized.
Based on that, a loose saddle is not a legitimate mishap. Had the saddle bolt broken, it would have been.
and
commu*ist spy
my common sense tells me it's a mechanical if it's because a hole or bump in the course caused it to be knocked out of position. but if it's because you were tweaking the saddle before the race, and forgot to tighten the bolt (I've done it), then it's your own fault. but the officials would not rule a loose saddle as a mechanical, because of the rule book, and rule books are dumb objects that don't have the capacity to account for different circumstances. you'd think officials have that capacity but don't count on it.
It was always my impression from what it looks like the rulebook says that free laps can be granted for mishaps outside of the riders control. It also seems like the only logical spirit of the rule. If you bay a brand new bike and adjust and tighten everything 100% perfect, would you be having the issue? If yes (and believable), free lap. I would not expect an official to believe that my saddle just loosened on it's own after being torqued properly, or that my chain jumped off with the derailleur adjusted perfectly and an unworn draivetrain. Sure, it COULD happen, but it's unlikely. I guess they technically should give a free lap for the chain thing cuz they can examine and verify. But then again one could easily abuse that and just take the chain off. The only way to fake a flat is to puncture it on purpose.
commu*ist spy
a bike that's well adjusted isn't immune to mechanicals other than flat tires. yes, they're unlikely, but they could happen. and yea, a bike that's ACTUALLY poorly adjusted can be made to seem like a legit mechanical. it's a big grey area.
Also, the area isn't very grey at all. If something breaks, free lap. If nothing is broken, no free lap.
A dropped chain is a failure of an essential component. In some cases it is not user error and should be recognized based on my opinion of the rules (but is admittedly hard to verify). A broken cable doesn't warrant a free lap just cuz something broke. A broken cable means the race was started with a worn out cable.
**** that
Quoted: 1099 Post(s)
Liked 104 Times
Per USAC Rulebook:
and
and
I'm glad there's a rule book, or this would be confusing and up for endless debate.
This isn't a debate. You've seen the black letter rules; I've told you how USAC officials (at least in my district) are trained to interpret them. You don't have to like them, but if you race in the U.S., this is the system you'll be racing under.
Liked 675 Times
And that's the rub. Doge used to go on and on about this, but the rules aren't consistently applied. I agree that a dropped chain isn't a mechanical, but I've seen at least one person get a free lap for it. And when the rules aren't consistently applied, and racers don't read the full rule book, it creates confusion and anger - as is the case with Spec, who didn't get a free lap for a dropped chain.
yeah and the rules DON'T say "only flat tires or broken parts count as mishaps" unless I missed that part
neo-poster
Bikes: 2018 Specialized Allez Sprint, 2018 Specialized Tarmac SL6 Pro; Cannondale Slice RS
Quoted: 23 Post(s)
I just love the fact that in 2018 they use toe straps as example, and couldn't be bothered to put in anything about electronic shifting.
Liked 675 Times
Yes, officials make mistakes, but an official's error is not a precedent to rely on for a new interpretation of the rules. You're on much firmer ground understanding the correct interpretation and following it, than making up your own version and then arguing with the official that you're right and she's wrong.
Yeah. It pretty much says anything that breaks is a mishap. Anything that doesn't break isn't.
The mishap example comes from the track racing section, where toe straps are still widely used and electronic shifting doesn't exist.
One rider that got caught doing in a Pro race this is apparently running for office in PA. The official in the pits (who happened to be the same official for my defunct race series for many years) pumped up the tire, totally fine. No free lap, disqualification or something like that.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
Any chance you could point me to it or quote it? Cuz I looked it up recently after spectastic's issue, and didn't see it. What topflightpro quoted said nothing of the sort. Where is it??
Re checked. Not in the road section nor in the definition of mishap. Failure of essential component not due to missassembly or insufficient tightening. This doesnt come close to implying something has to break.
