Strava/Garmin/bluetooth/android smartphone?
I have an LG5 smartphone with Stava installed and I have the Garmin GSC 10 installed to work with my Garmin edge 800 when I'm not using my Smartphone with the Strava app. What I'm trying to do is get the cadence data to pair with the strava app allowing me to see my cadence on the phone screen as I ride. I'm led to believe that the GSC 10 should work through blue tooth signal with the smartphone but I'm unable to get it to work. I've installed the ANT + Plugins Service on the phone but that did not seem to fix the problem.
Randomhead
Liked 3,698 Times
I don't think there are any LG phones that support Ant+. You can do your own search at this website: https://www.thisisant.com/directory/filter/~/60/~/
From what I can tell, the GSC 10 is not equipped with bluetooth.
So if I'm right, this sensor is not going to work with your phone unless you get an Ant+ dongle for the phone. Better to get a wahoo or other bluetooth/Ant+ sensor
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
Do you have Strava premium? I believe live stats (cadence, etc.) are available only with subscription (I think it's now called "Summit" - but the paid options).
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Garmin speed and cadence sensors are ANT+ only. They don't do Bluetooth.
I can't help with ANT+ setup as I'm on the Polar platform which is Bluetooth only and I'm using an iPhone.
-Tim-
-Tim-
Quoted: 551 Post(s)
Liked 277 Times
I could be mistaken, but, the LG G5 smartphone is not ANT+ compatible. You can download ANT+ apps all you want and it still will not turn your LG phone into an ANT+ compatible device. You may have to root the device, but it will be very buggy and unreliable. Check out the ANT+ directory if your device is compatible here:
https://www.thisisant.com/directory/...115%7C118/~/~/
Quoted: 24 Post(s)
Due to the mount, I'm using for my LG5 phone I'm unable to mount an ANT+ dongle to the usb port on the phone. I did download a ANT+ app and you are correct it does not work with the phone.
