Sweat dropping on iPhone screen
I use a Topeak case and mount for my iPhone 7 and love it. The only problem is that when I stand up, leaning slightly forward, sweat drops on the screen and sometimes hits the "pause" button. This morning, a second drop of sweat hit the "delete" button. Fortunately, there was an "are you sure?" pop-up so I didn't lose the entire ride -- but it did stop recording for a few minutes until I noticed.
One easy solution is to turn my screen off before standing, but I don't always remember to do so. Has anyone else come across this issue, and if so, how did you solve it?
Also, I am curious why a drop of sweat can hit a button, but my sweaty finger often doesn't work.
Thanks.
Thanks.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I can't answer the question but my Polar GPS has a lock screen feature for this very reason.
Thanks so much!!!
- Soli Deo Gloria -
Liked 736 Times
Perfect.
Sometimes posting or writing or just vocalizing a problem helps one to think it through.
-Tim-
-Tim-
Quoted: 7348 Post(s)
Liked 2,469 Times
I think that will have no effect. I've had a vinyl cover, and I was still able to use the touch screen with my finger.
Liked 2,469 Times
Right. Which means if a finger can activate the screen with a cover, the same may be true if there is cling wrap. In other words, I don't think your suggestion will help.
Liked 2,469 Times
Bikeforums member: My bike isn't working. What should I do?
fietsbob: Give up cycling? Take a walk on the beach?
Fair enough. On my typical ride, I have to watch out for deer or foxes more than traffic, but I get your point. Overuse of any device can be dangerous, and knowing when to glance down and when not to glance down requires common sense.
Quoted: 2952 Post(s)
Liked 3,106 Times
Are you using your phone as a computer?
Gravel Rider
Bikes: 2019 Trek Checkpoint ALR5 | Trek Farley 5
Quoted: 93 Post(s)
Thanks.
Thanks.
shimoyjk
2
10-22-15 06:50 AM
northerntier
27
04-25-13 01:17 PM
