Latex Inner Tubes: More Than They're Worth?
Señor Blues
This is funny, because I'm a monkey with mechanical stuff and never had these issues with Vittoria or Michelin latex tubes. Yank out the existing rim tape and use a double wrap of Stan's, and wide enough that it goes from wall to wall (not whatever's recommended). Slightly pre-inflate the tube prior to installation. Ensure the tube is entirely within the tire before locking the second bead, and ensure the tube is not pinched. I can all but guarantee you that will work, reliably, for as long as you care to use them.
Note also that those are the best practices for butyl tubes as well.
Quoted: 425 Post(s)
Liked 454 Times
I've been off and on latex tubes over the past few years. Apart from what has already been mentioned about the ride quality and installation concerns, I will say that the latex will creep out of any holes or cuts in the tire or sidewall, whereas a butyl tube would not. This may be the source of otherwise unobvious "spontaneous" punctures.
The other thing I will say is that latex tubes tend to stretch out over time. If I had used a latex tube in a 25mm tire for some time, there is no way I will be able to reuse that tube in a 23mm tire in the future.
Finally, I will echo that latex tubes are much less prone to typical punctures due to their increased flexibility. I recently found a thorn and a staple that made their way through the tire tread, yet the latex underneath held up.
Perceptual Dullard
Quoted: 915 Post(s)
Liked 1,131 Times
That's true; however, note that the Continental tubulars we can buy are different than the Continental tubulars that pros get. Consumer Conti tubulars have butyl tubes. Damn them.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Yes! Frustrating! Still not sure how they get away with the Pro LTD version and not go afoul of the UCI general availability/whatchamacallit rule.
Bikes: 2017 Ridley Noah SL - Candy Apple DA9000, 2011 CAAD10 Berzerker Ult6800, 2013 FOCUS Mares CX Ult6800
Quoted: 26 Post(s)
I roll latex in my race wheels and they seem smoother, faster, or perhaps that is the wheels.....
Perceptual Dullard
Quoted: 915 Post(s)
Liked 1,131 Times
Funny that Conti makes such nice consumer-level clinchers and such maddening consumer-level tubulars.
And this is why I only ride Veloflex Tubulars. None of that bull**** about messing around with clinchers and tire beads. And I switched to the Efetto Mariposa tape and it's been great so I don't even deal with glue anymore...well only my spare tubs have a layer of Mastik on them, just enough to get me home until I replace the tire. Arenberg and Vlaanderen are the best
https://www.bicyclerollingresistance...eless-clincher
Quoted: 24 Post(s)
I found some little cuts in the side of my tyre. I came unstuck on a ride today, when I noticed knobs of inner tube sticking out of the tyre. I was still quite a few miles from home, so there was not much I could do about it at the time. I was hoping my luck would hold out, and I could see to it when I got back - it didn't. Going round a corner closer to home I started hearing a hissing noise, and the tyre went down. I had to take the tube out and put a new one in. I checked that the tube wasn't coming through before I set off again, and hoped it would be enough to get me home. Fortunately it was.
Are the tyres trashed now, or is there something I can do fix it? I'm not that happy about it as I only bought the tyres a few months ago.
I'm going to have to swap back to my other tyres I guess. They're Grand Prix 4 Seasons. Is it worth trying out the latex tubes with them, or are they too heavy duty to make it worth it?
Quoted: 1975 Post(s)
Liked 232 Times
The watt savings seems to be less than that, closer to 2 watts per tire. According to this test anyway.
Quoted: 645 Post(s)
Liked 797 Times
As to the other question, you might feel a difference using latex tubes in a supple high-thread-count tire like an Open Corsa, but I suspect that any "latex effect" will be lost in a heavy duty tire.
Quoted: 24 Post(s)
They're toast - if you're seeing tube protruding out through the tire, a temporary boot - a wrapper or folded dollar bill - might suffice to get you home, but they're done after that, and an explosive flat waiting to happen.
It's only a small hole, can't I just put one of the those Park Tool tyre boots in it or something?
Quoted: 645 Post(s)
Liked 797 Times
sure you can - at the end of the day, it’s your call. If you consider the the hole(s) to be sufficiently small that a permanent boot will fully support the surrounding tire, then go for it, but give them a good hard look before each ride to ensure that the boot hasn’t moved or the holes haven’t grown. That being said, were I in your shoes, I would consider the tire to be compromised, and I would rather eat the replacement cost than run the risk of eating asphalt somewhere down the line
Quoted: 24 Post(s)
I just examined the tyre off the wheel and you can hardly tell there is a cut there - I had to search for it - it's so very, very small - in fact I felt the need to mark it with a pen so I can find it again later. I don't see that it's something that the whole tyre needs to be replaced over. In fact it's only on a recent ride that the butyle tube found its way through, before that it was fine, and the only way I knew it was there was because the latex tube kept popping when I installed and tried to inflate it. I'm thinking some kind of tyre boot would sort it out. What do you think? Surely it's not worth ditching an otherwise unblemished almost brand new tyre because of the minutest of nicks?
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
5 watts?
I've never seen test that indicates you'd save 5 watts per wheel. Where did you see that?
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
"The fit. files were processed and the inertia was corrected for each tyre. The result was that latex tubes were five to 5.5 watts faster per tyre"
Not saying that it's credible. Just that I'd pay extra for that much, if it weren't so much extra hassle.
Quoted: 11 Post(s)
I'm curious about the pressure issue.
If you need to pump them up from one day to the next, would you notice a difference from the start to the end of a very long ride?
Quoted: 40 Post(s)
Liked 9 Times
The OP's experience with latex tubes is all too familiar. After several customers demanded their money back on the "defective" latex tubes we stopped bringing them in. Nothing defective about them, total operator error. Tires are tougher to seat with them, that's all. When done correctly they don't go "BANG!"
Latex tube posts are kinda like carbon vs steel, Campy vs everything else, aero vs weight weenies, etc. with lots of strong opinions on both sides!
I tried the Latex on clinchers.... after riding tubulars for 12 years... thought I'd get the ride feel back. No go. Same result as OP. My theory ....Latex goes bad when exposed to light. How are they stored before you purchase them (unknown)? In tubular tires latex tubes never see sunlight, except to repair them. Not really any weight savings. Went back to Conti Race Light about 70grams... the same weight as latex. Can anybody tell the difference? Clinchers are so good now, not like 40 years ago.
Best Bang For The Buck?..... not IMO
Quoted: 24 Post(s)
I tried patching the tyre, but when I tried inflating it the crack started expanding and it was very obvious. I also noticed it was bulging slightly at that point when I felt it (this was with the latex tube). I decided that I wouldn't be happy riding it like that, so I took it back off and put the 4 Seasons back on. It looks like I'll have to fork out for a new tyre next spring..........
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
So much in here and so frustrating to read knowing there’s a lot of misinformation on here but only a few will take the time to read this far down.
Op - you installed the tubes incorrectly. Period. Whenever you get a flat with any tube simply perform an inspection of that flat. The shape and position of the hole will tell you the cause. Large holes (opening that run along the tube and have a jagged edge (butyl - smooth on latex) in the center are caused by the tube not being contained. You didn’t keep it under the bead of the tire. Sorry.
Mounting a latex tube Can be subtly harder. It flops around a lot easier........BECAUSE it’s more supple. The whole point. It conforms easier and even though you think you have it tucked away in the tire you could easily pinch it or have a small edge of it between the bead and rim without realizing it.
Ok next...
latex tubes are are more durable in the same conditions and are more likely to conform to an intrusion than they are to yield to it. BUT - it’s still a tube holing air. Sure it can be popped. So what. Anyone’s personal anecdotal history of a flat or two is meaningless in a way because they don’t have any idea what they rolled over or hit, etc.
this is akin to the same situation you run into while wrenching in a shop. “I got a flat. You just changed my tube so it must have been you or the tube.” “Let me look. Nope - look you ran over something causeing this hole. Let me check your tire- yup piece of glass is still there. Sorry you ran over glass.”
to the person with the tube tube sticking out the side - your tire’s purpose in life is to hold your tube in. If it’s not doing that then it needs to be fixed. Outside of temporary booting - there’s not really a fix. Get a new tire. Don’t like it? Sorry I guess. Don’t run over stuff that can cause a hole in the side of your tire.
Not noticing the “performance aspect of latex tubes” while riding on anything made from continental but gatorskins in particular is a facepalm moment. A latex tube there is like putting lipstick on a pig: At the end of the day it’s pointless and you probably should explain your motivation for doing so to a therapist.
Yes the majority of tubulars (of which I mount hundreds of annually) have latex inner tubes. Yes this is for the performance. Are they a performance enhancer when used in clinchers? Of course. For the same reasons. Will they turn any clincher tire into performing like a tubular? Of course not. There’s more to a tubular than the inner tube. The casing, the tread compounds, etc. same with clinchers. See above reigs and lipstick.
TLDR- it’s a tube. It works. If it isn’t working for you then all roads point to you doing something wrong.
Ok next...
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
^^^ Thank you for this.
-Tim-
-Tim-
