Steel Frame Bike Options?
#51
Señor Blues
#52
More importantly though...custom is not better. Heck, I bet in many cases custom would be objectively WORSE due to less refinement and practice in design and construction. Modern producers of bike frames are very good at what they do, and from what I can tell also very rarely make mistakes.
What custom is, is custom. You can get something you cant get anywhere else. At least not pre build anyway. Shaped like a chimp? Custom could accomodate your comically long arms. Got a thing for a blinding paint job nobody else has? Custom. NEED 4 flask holders brazed on? Custom.
I just wouldnt expect the bike to be lighter, ride better, or last longer if you dont require anything unique though.
Likes For Abe_Froman:
#53
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Not sure how that could be viewed as worse since its, you know, better.
As for fabrication- custom frames often have smooth thinned lugs, or beautiful carbon and titanium exo-grid tubes, or braze-ons positionally where you want.
I can't remember ever seeing a handbuilt small batch frame that was sold and not of excellent quality.
Not sure how any of that is less refinement since its, you now, not less.
Fully agree that modern bike production is in general very good and few mistakes are made.
#54
Quoted: 4806 Post(s)
Liked 3,929 Times
If you can forgo the discs, there's another option. Don't know what you will find but, stop regularly at coops and used bike stores and look for older bikes. Most will be built up and ready to ride. You will probably want to make a few changes but the price will be so much lower that won't matter so much. There are many older bikes from small builders out there being sold at prices way below their ride quality.
Ben
Ben
#55
I love my Surly Cross Check. It's very versatile. You could put 25mm tires and have a fast bike, or you can put 32mm tires and rack and panniers to do grocery shopping or touring.
Likes For fuji_owner:
#57
Quoted: 1743 Post(s)
Liked 1,281 Times
How are you defining "better?" There are people who have worked for decades at their craft and for companies like Indy Fab, Seven, Zen, Guru, Waterford, Gunnar, etc. who will make a custom frame to your dimensions. To me that would be "better" than some "small, medium, large" off the shelf size. Unless you happen to be one of those people that perfectly fit that generic sizing. But, I'm not sure how you were defining "better" so we may be looking at two different aspects.
#59
Thus isnt meant to denigrate custom frame builders...its both an art and a craft. I just dont believe that, assuming good fit, a custom artisan frame will outperform a good quality mass produced one in any way. There is value in other places...but not performance.
I would assume custom frame builders would agree with that. Their bikes are one a of a kind. Handbuilt. With an aesthetic the customer chose, and whatever odd niceties he wanted brazed on. And, if a customer had odd body proportions, custom frame tube lengths can overcome that problem. But only to the point to make the bike as good a fit as most people have on stock bikes.
Its like having a tailor make a suit for a 1 armed person. It's not objectively better, it just has 1 less sleeve.
#60
So I would forget about titanium bikes if your total budget is $3500.
If you don't need a custom build, I strongly suggest looking at Surly Cross Check, as I said earlier. Surly makes great frames, and they have a good network of dealers all over the US. Cross Check is more of a touring style but not "sluggish" by any means.
#61
Señor Blues
#62
My main point was that a custom bike does not mean better. It's just a different size. Or different options and spec thatyou wouldnt normally be able to find.
Having a tailor made suit is the definition of an objectively better product for the person for whom it's being made. The tailor is not hand-waving, he's taking actual "objective" measurements of the person to make the product fit the person most optimally.
You don't need to have odd proportions to get a custom frame. It's just the question of how much you are willing to compromise on performance or comfort. I might be fine with jeans that are a bit too tight or a bit too loose at the waist (and use a belt). Or I might want to get my jeans altered to fit my waist perfectly. Obviously, the altered jeans would be better. If I could get jeans made for my specific measurements, then that would be best.
With a bike, there is only so much that can be altered and adjusted on a stock size. I definitely see the reasoning behind custom frames, but they can also get really expensive. I got one custom Ti frame, and I can't afford to get another custom bike. I still have 2 cheaper stock size frames that are not as ideal as my custom bike for performance or comfort, but I still love riding them.
It's just as with custom tailored suits, you probably have one expensive custom tailored suit that you like the best, but at the same time, you have other stock size suits of different styles that are cheaper but still look good.
You know, it's funny, there was a time when getting clothes meant going to a tailor who would take your measurements and stitch something for you. That was the only way. So in the original supply chain model, everyone always got custom clothes, and they weren't "more" expensive, they just cost what they cost. When mass production began, that's when they had to compromise because they couldn't make clothes for every single person, so the customers had to compromise/choose between stock sizes.
#64
In regards to fit...sure I'm completely fine with using a 'belt' on my bikes. Raising the seatpost...sliding the saddle the 10mm forward of center on the rail to the ideal position. I dont think avoiding those types of adjustments is reason alone for a custom frame.
#65
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
As I do think it unlikely there will be much on the shelf to look at, much less find in your size to try out, that online makes some sense.
I'd be perhaps looking at the Holdsworth line from PlanetX, eg
https://www.planetx.co.uk/i/q/CBHOLC...stom-road-bike
or the Ribble offerings previously mentioned, eg
Ribble CGR 725
Ribble CGR 725
#66
Thoughts on this Jamis Renegade
#67
Quoted: 20810 Post(s)
Liked 9,456 Times
I really like Jamis (I used to own a Xenith), but $3k seems high to me (steel, SRAM hydro 1x). I know that you want a steel bike, but hell - I'd *much* rather have the carbon fiber Renegade Expert with 105 Hydro for $400 less.
#68
Sunshine
Liked 7,491 Times
The escapade frameset for $850 is a great deal.
The built escapade...meh. SRAM 1x isnt what I want in a road bike(that's this forum) and don't want for a gravel bike or bikepacking bike.
But that's me.
#69
I really want to stay with disk brakes. If I want to upgrade soon the Surly Midnight Special also is a possibility.
#70
When we had a Jamis dealer here I almost got a Satellite I think it was called.
Bianchi Orso w/105 is $2100. I almost got that but it didn't come in celeste.
Trek 520 is $1700. Frame $699. I looked hard at the Trek but decided that if I was going to build a frame I'd go Crosscheck.
#71
Sunshine
Liked 7,491 Times
Oh, and the Surly is designed to be a 650b road+ bike. Not sure if that matters to you, but FYI in case you hadnt noticed.
Likes For mstateglfr:
#72
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
I don't see it as avoiding those things, it's more like when adjusting 'the belt' isn't enough. Or you have enough experience to communicate riding experience and handling preferences that may lead towards something custom. Or you have the desire to have something unique and singly yours. Or all three.
