So lame- tires don't fit the frame.
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
I have no idea why I assumed 32mm tires would fit the '88 Schwinn Premis I've been slowly working on, but I decided to try em out and they arent even close to fitting. The tires hit the brake bridge and fork crown quite substantially. The pics are with both tires only half inflated.
good news is there is plenty of room along the chainstays and bridge.
The plan was to strip the paint and rust, braze on some brake cable guides, then get it powder coated and built with modern 105 and modern cockpit.
No idea why I assumed 32s would fit and no idea why this has me all annoyed(maybe because i have these 32s that arent used for any bikes!).
If 28s fit, then I should continue with the plan, but man that's annoying I didnt even think to check clearance before putting in the work and planning.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
I find that to be common with most Japanese bikes made in the late 80's. My Miyata 312 won't take 28's let alone a fender, for which there's frame attachments. I'm assuming the Premis is also Japanese?
Likes For CO_Hoya:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Looks like a candidate for 650B conversion.
Likes For JohnDThompson:
Sunshine
Liked 7,485 Times
All the more reason that it's odd I would just assume they would fit.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
To me this was a ridiculous trend for which i see no upside. Its why i prefer frames designed for 27s.
Likes For 52telecaster:
Quoted: 3810 Post(s)
Liked 6,690 Times
650b ftw.
Likes For nlerner:
Quoted: 796 Post(s)
Liked 522 Times
Had this issue on an a 89 Allez with 28s so I ended up buying 25s
Likes For ryansu:
I had that problem fitting 700x28s on my '86 Miyata 710. Only 1mm of clearance - maybe...
There's a bit more room in the rear, so maybe next time 25s in front, and 28 rear...
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Grand Prix 4000 is known to inflate bigger than stated, while other brands/models are just the opposite.
These tires won't work, but now to find out what will!
I prefer 25's myself.
Only my old carbon Epic and my Rigi seem to have any problem mounting GP4000 25mm.
Likes For dddd:
Quoted: 5888 Post(s)
Liked 3,471 Times
Sunshine
Liked 7,485 Times
Liked 3,471 Times
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
That year really marks a change between a more traditional “sporting” bike and a “racing” bike. I don’t know why they kept the eyelets on the ‘86 model, I don’t think you could fit fenders with anything bigger than a 23mm (possibly (but doubtfully) a 25mm) tire.
Quoted: 1221 Post(s)
Liked 629 Times
Would it be worth getting a little wild, grinding that bit of excess under the crown and doing a bit of braze work on the bridge?
Quoted: 457 Post(s)
Liked 462 Times
A Premis, in stock form can't run a tire bigger than 25c, maybe some small 28's can fit, but it would be VERY VERY close, cigarette paper clearance.
Quoted: 3464 Post(s)
Liked 2,829 Times
The 1980's : splash tape, clearance for 23's MAX.
You could take a halfround file to the crown, find a builder to move the bridge up.
The frame is naked. $$
650b, good, but brakes and wheels....$$$
Smaller tires..$
Smaller tires..$
Quoted: 457 Post(s)
Liked 462 Times
It will fit 25c tires reasonably, I just built up the exact same frame.
I would like to shift my asphalt bikes to 28c tires, but I'm plenty happy on 25c tires too, but the Premis will forever be a 25c bike. I do have the tools and skill to move the brake bridge up, but I'm fine with it as it sits.
Sunshine
Liked 7,485 Times
What's funny is that this really isnt some impressive frame. The Tenax tubing is ok but nothing incredible, and the tube joining all around has an obvious focus of being as quick and cost effective as it gets.
Sunshine
Liked 7,485 Times
I dont have 650 wheels and while it would be neat to try, this isnt the time or frame for that.
It would be neat to try out though.
Sunshine
Liked 7,485 Times
Then I tried some 28mm GP4k tires that measure out to 30.5mm and they are really razor edge thin on fitting.
Bikemig and I will swap some tires and I'll try out some Panaracers that I've read are a true 28mm and that would then most likely be OK.
But at worst, I'll toss the 27mm true size GP4k tires on and call it a day.
Always funny when something throws you for a loop even though you know about it well in advance.
Quoted: 457 Post(s)
Liked 462 Times
I fit some 25mm GP4k tires tonight that measure out to 27mm and they fit fine with enough clearance that I would be comfortable.
While frames that can't take a tire bigger than 25c are absurd, I'm glad I have one in my fleet, it was a trend in cycling that in retrospect made no sense, but is still a vaguely interesting footnote.
Likes For jackbombay:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Just me but I would take a half round file to the fork and a BFH to the brake bridge. If you are doing brazing that brake bridge is an easy job while in a bare frame state.
To dimple some chain stays I took a large cast iron cylinder about 2.5" in diameter and hammered it between the stays, flattened them enough I could fit the tires I wanted.
Regards the fork and brake bridge, you might also have to file the brake caliper a bit if you go the file direction and or BFH.
Quoted: 457 Post(s)
Liked 462 Times
The brake bridge + BFH? No way.
To be clear, I LOVE problems I can solve with a hammer, and I have a large assortment of hammers to solve all sorts of problems that may unfortunately cross my path, but, as the OP has the capacity to braze, he should move the brake bridge properly, IMO.
