Tips on putting a rear rack or front basket on my newly acquired beater?
かわいいサイクリスト
Bikes: Eighth Inch Scrambler v3
bought this disc brake converted old school mtb for a steal, but i'm having a hard time figuring how if possible to mount a rear rack since the disc brake tab has been added. What are my options for a rear rack or front basket?
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
I had a Specialized HardRock with disk brakes. Can't remember the brand, but someone does make a rear rack that will fit over disc brakes. My boy claimed the bike but I could find out what make/model that is.
'10 Specialized Hardrock
just add a spacer and a longer bolt and any rack will spread wide enough to clear the disc caliper..
go to a Bike Shop and you can test fit a rack before you buy.
and level that saddle..
Bikes: Treks and a Moulton
Quoted: 64 Post(s)
This front rack idea is interesting, and it would support a basket.
Azor/Steco Pickup frame mounting front rack
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
It looks like the rear disc brake mounting tab replaced the left rack eyelet, so the OP no longer has two lower eyelets in the same place.
@guitarmankyle, you could use a rack that mounts to the QR skewer, like the Axiom Streamliner.
https://www.amazon.com/Delta-Children.../dp/B004UMFAWW.
1 caveat: use 2-part epoxy to adhere it to the seat post, otherwise it can shift side to side,
and put it at the lowest place on the post.
Bikes: 2006 Falcon Explorer Hybrid, 2008 Landrover Visalia Crossover, 2010 Cargo Cycles Senton, 2010 Cargo Cycles Capability, and a 2001 AVD quad pedi-van, 1980 Peugeot Carbolite 10sp racer
Quoted: 21 Post(s)
Liked 24 Times
Rubber lined stainless steel P clips will be your friends for fixing the rack to the bike frame.
