Handle bar lenght
Bikes: Specialized diverge, trek multitrack 750
Handle bar lenght
Just wondering what flat bar length you guys are riding with on your hybrids. I recently bought a used trek 7.3 fx and its 23in feels a little short but maybe i just need to get used to it.
Bikes: Giant Escape 1
Quoted: 136 Post(s)
Are you referring to the width of the bar? If so, then I think the best width of the bar is the width of the shoulders. Hands directly in front.
Yes, the width. Its pretty much right on with my shoulders so i guess im good. Thanks for the reply
Ha ha ha ha ha
Bikes: 2004 ORBEA Mitis2 Plus Carbon, 2007 Cannondale Bad Boy Si Disc, 2012 Trek Gary Fisher Collection Marlin WSD 29er Aldi Big Box (Polygon) 650b
Quoted: 8 Post(s)
Liked 11 Times
I personally prefer wider than the shoulder guide. If it feels OK now though I wouldn't change it.
My centre to centre (sockets) is 400mm. My bars are 680mm
Quoted: 576 Post(s)
Liked 1,001 Times
Bar width depends on what type of bar: risers are the widest, followed by flat, and drop bars are the narrowest. Only drop bars are directly shoulder width + 2 cms. The rest are much wider, especially if you run a modern setup with shorter stem and riser bars.
For example, my shoulder width is about 32cms (less than 13") but my riser is 23.5" and flat bar is 23".
Modern setups are already using 700mm to 800mm wide bars. If your shoulders are really 23" wide, you should really look at a wider setup
Quoted: 1581 Post(s)
Liked 1,189 Times
The "best" width is the one you prefer -- simple as that. If you want something wider than 23" (around 580 mm or so), go for it. My preferred width (flat bar) is 620 mm (both mtb and flat-bar road bike). Some prefer wider, some narrower. Experiment (bars are relatively cheap)!
Bikes: 2016 Specialized crosstrail comp disc
